Saving weight vs looks
Discussion in 'Wheels & Tires' started by JackJoachim, Jan 25, 2022.
  1. Jan 25, 2022 at 9:26 AM
    JackJoachim
    JackJoachim [OP] Well-Known Member
    Jack
    North MS/Memphis
    ‘22 Barca Red TRD Off Road 6MT
    Would you rather run a smaller tire, albeit slightly larger than stock, and drop 5lbs a corner?
    Or run a larger tire, but gain 9lbs a corner
    I was dead set on 285/75/16s until I did this math and the weight saving and money savings is looking quite attractive.
    What does TW think?
    Data for anyone who cares.
    Wheel Weight
    Enkei RPT1 16x8 ET0 18lbs
    Stock TRDOR Wheel 25lbs
    Tires
    Cooper Adventurer XLT 285/75r16 54lbs
    GY Wranger UltraTerrain 265/75r16 40lbs
    GY Stock Tire 265/70r16 38lbs
    Option 1
    Cooper Adventurer XLT 285/75r16 54lbs Enkei RPT1 16x8 ET0 18lbs
    Total: 72lbs
    Difference per corner 9lbs
    Difference overall 36lbs
    Option 2
    Total: 58lbs
    Difference overall -5lbs
    Difference per corner -20lbs
    Stock
    Total 63lbs
    Steamy Longbottom likes this.
  2. Jan 25, 2022 at 9:29 AM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    I vote for option 1 - Cooper Adventurer. I like the look of the tire (not too aggressive, has a good street tread for a quieter ride, and it's lighter). Plus I'm a fan of white lettering.
  3. Jan 25, 2022 at 9:39 AM
    Borracho Loco
    DFW, Texas
    There are some great Amazon reviews about the Coopers: Long lasting, very quiet ride, great handling in the rain, etc...
    https://www.amazon.com/Cooper-Discoverer-All-Terrain-Radial-Tire-LT285/dp/B07D12FWCJ?th=1
  4. Jan 25, 2022 at 9:42 AM
    bzzr2
    bzzr2 Well-Known Member
    You have to look at the truck a lot, you should like the way it looks after spending the money on it! 9lbs isn’t a big gain, you won’t notice much of a change. Go for it!
    JackJoachim[OP] likes this.
  5. Jan 25, 2022 at 9:45 AM
    saltybum
    saltybum Well-Known Member
    Bob
    Space Coast
    2022 Tacoma Access
    If you're really concerned about weight...go on a diet.
    Montana_Actual likes this.
  6. Jan 25, 2022 at 9:46 AM
    saltybum
    Bob
    Space Coast
    2022 Tacoma Access
    Duck :crapstorm:
    99TacoDriver likes this.
  7. Jan 25, 2022 at 9:49 AM
    JackJoachim
    Jack
    North MS/Memphis
    I agree with this. Just thought I’d ask other peoples opinions on it. Thanks!
  8. Jan 25, 2022 at 9:51 AM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    Im currently going though this process as well. What I did was pick 3 wheel and 3 tire finalist that I liked in my desired size, Then I chose the lightest of the 3.
  9. Jan 25, 2022 at 9:53 AM
    Clearwater Bill
    Billy
    Largo Florida
    9lbs per corner of unsprung weight is a lot. In the auto-x world it could easily be the difference between podium and also ran.
    While I'm sure the impact on a truck isn't quite the same, there is still something to be said for nimble.
    If your usage is 90+% pavement, I'd wager lighter is better. And if you could do back to back same condition testing, you'd notice it. Easily.
    Lucario Runner, mallege and Chris(NJ) like this.
  10. Jan 25, 2022 at 9:54 AM
    JackJoachim
    Jack
    North MS/Memphis
    This will be my daily driver, so that why I’m leaning towards the lighter setup.
    skeletron likes this.
  11. Jan 25, 2022 at 9:55 AM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    What performance characteristics do you need vs want. If you want superior durability you may need more weight. If you want bad ass tread you may need to adjust your driving experience. I found my decision on this spectrum to favor some characteristics over others. In the end, the tires will wear out so even a miscalculation will be correctable next time.
    Clearwater Bill likes this.
  12. Jan 25, 2022 at 9:55 AM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    My experience is that tire weight really doesn’t make that big a difference. I had 53 lb E load tires in 265 70 17. Once they wore down I bought the same tire in C load 45lbs. I only gained 1 mpg. I went from 16.5 mpg comb to around 17 or 18 mpg comb.
    If you don’t need lots of protection then go Sl or C load for sure.
    285s look really good on our trucks. Way better than 265s.
    Mark77 likes this.
  13. Jan 25, 2022 at 9:59 AM
    JackJoachim
    Jack
    North MS/Memphis
    I love the looks of 285s on the trucks. Thanks for the insight.
  14. Jan 25, 2022 at 10:03 AM
    DavesTaco68
    North Thompson, BC
    2013 Tacoma TRD
    They look really good, I went with a C load 285.
    There are some 34 or 33 inch x 10.5 tires out there as well if you want additional clearance.
  15. Jan 25, 2022 at 11:29 AM
    eurowner
    eurowner Duke Sky
    Scoty
    9lbs per wheel x 4 wheels equals 36lbs of rotational/sprung/braking mass which roughly (going off the 10lbs R/S/B mass equals 100lbs C weight) equates to 360lbs of Chassis weight. You Will Feel It.
    Lucario Runner and mallege like this.
  16. Jan 25, 2022 at 11:53 AM
    JackJoachim
    Jack
    North MS/Memphis
    I like that math a lot. For a daily it’s a no brainer to go lighter.
    mallege likes this.
  17. Jan 25, 2022 at 12:47 PM
    Clearwater Bill
    Billy
    Largo Florida
    Hmmm. Do I detect another auto-x'r?
  18. Jan 25, 2022 at 12:51 PM
    bzzr2
    this is def an important factor, no off road get the lightest tires you want. If you like exploring and getting far into the wilderness light means less rubber that is more likely to puncture.
    On YouTube search ‘cooper tire puncture test’. Don’t think they talk about sidewall strength just tread
  19. Jan 25, 2022 at 2:33 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Don’t care about weight, never will.
    Mark77 and Montana_Actual like this.
  20. Jan 25, 2022 at 3:12 PM
    JackJoachim
    Jack
    North MS/Memphis
    Thanks for the response
    skeletron, Chris(NJ) and eurowner like this.
