saw 2.0's and spacers?
Discussion in 'Suspension' started by tacoma44x44, Feb 17, 2009.
  1. Feb 17, 2009 at 5:24 PM
    tacoma44x44
    tacoma44x44 [OP] Well-Known Member
    Jamie
    Calgary, AB
    07 Dc trd
    hey was wondering if i ran the saw's at just under 2.5inches of lift and ran a 3/4 top plate spacer kit to get the full 3 inches and not have to worry about maxing the coilover out. or should i just run the coilover at full 3 inches of lift.
    thanks
  2. Feb 17, 2009 at 5:28 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    I was warned about getting the 2.0s on my 05+ Taco... they'll heat up faster as there is less fluid inside...
    Chris will know what I'm talking about...
    I ended up getting Camburg (SAW) 2.5 C/Os
  3. Feb 17, 2009 at 6:01 PM
    tacoma44x44
    Jamie
    Calgary, AB
    07 Dc trd
    any suggestions chris4x4
  4. Feb 17, 2009 at 6:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Unless you are gonna run aftermarket UCA's, I wouldnt.
  5. Feb 17, 2009 at 6:08 PM
    tacoma44x44
    Jamie
    Calgary, AB
    07 Dc trd
    ya all be running tc uca's is this a totally bad idea or a good one. and what are some of the negatives u have heard about the saw 2.0 co are they worth keeping?
  6. Feb 17, 2009 at 6:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have never tried a 3/4" spacer on top of a coilover, so I cant give an opinion on if its bad or good. Like Del said, the 2.0's have a smaller body diameter than the 2.5's, so they dont hold alot of oil, and will heat up fast and fade in hard/fast off road use. They are a fine shock for light to medium off roading. Depending on what you do off road, I think they are definatly worth keeping.
  7. Feb 17, 2009 at 6:17 PM
    tacoma44x44
    Jamie
    Calgary, AB
    07 Dc trd
    thanks chris much needed help
  8. Feb 17, 2009 at 6:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yw. :proposetoast:
  9. Feb 17, 2009 at 11:12 PM
    Cramer@Down-South
    Cramer@Down-South Cramerism
    San Diego
    Black '08 Tacoma PreRunner Lifted Beautifully
    Lifted with Fox 2.5 Black & Chrome coil-overs, rear has Fox 2.0 Black & Chrome piggyback shocks, KMC 17" wheels wrapped with 285/75/17 BFG All Terrains, Total Chaos upper control arm, Alpine DVD doubledeck, and Volant cold air intake.
    I have the Fox 2.5 coil-overs on my truck with the Total Chaos UCA. A good rule of thumb is once you have around three inches of preload in the spring go up in spring weight. I really wouldn't recommend putting a spacer on the top of the shock to achieve this. It will change the overall and compressed length on the shock and could result in damage to the uniball from maxing out and the shock when it bottoms before the truck.
