SAW 2.5 Valving
Discussion in 'Long Travel Suspension' started by austinramsay, Nov 1, 2012.
  1. Nov 1, 2012 at 12:46 PM
    austinramsay
    austinramsay [OP] Well-Known Member
    Austin
    Yuma, Arizona
    2002 Tacoma TRD SR5
    I have 2.5 camburg coilovers that i want to revalve. What would you guys recommend to run for mostly sand dunes, small jumps, woops, small ruts, etc
  2. Nov 1, 2012 at 1:05 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Call Sonny or marco at DSM. You dont want to run the same valving as LT, the angles and leverage is different so valving is probably different too
  3. Nov 1, 2012 at 2:27 PM
    austinramsay
    Austin
    Yuma, Arizona
    2002 Tacoma TRD SR5
    Alright thanks ill give them a call! :thumbsup:
  4. Nov 1, 2012 at 3:20 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    what jd said, for what you want to do, whoops, jumps, ruts, i would go for a little on the stiffer side.
  5. Nov 1, 2012 at 3:54 PM
    austinramsay
    Austin
    Yuma, Arizona
    2002 Tacoma TRD SR5
    What would you say for rebound? More or less than factory for that?
  6. Nov 1, 2012 at 7:38 PM
    Anthony250
    Anthony250 E-Fabber
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    TC Kit, Methods Double Standards, Sway Away, King Shocks. Prp Seats, 35's
    Thats a pretty broad spectrum of terrian. Gonna have to ask Sway away and DSM. And see whats currently in your shocks. And tell them your driving style, types of offroading your going to do, and all other specs, ex. wieght.
  7. Nov 10, 2012 at 1:28 AM
    TC yota
    TC yota Well-Known Member
    Tyler
    Escondido
    Ha
    Without knowing specs, I'd start somewhere around 15comp/12 rebound, 2 bleed screws in, maybe a flutter stack if needed
