Saw adjustment
Discussion in 'Suspension' started by takern, Oct 10, 2010.
  1. Oct 10, 2010 at 5:58 PM
    takern
    takern [OP] Well-Known Member
    Tanner
    Virginia
    03 TRD Offroad stepside
    Deckplate mod, sliders, uniden cb, toolbox, dakar leaf pack, in search of coilovers, 255/85 16 bfg m/t waiting to go on
    well my coilovers settled and i want to lower them about half an inch and i just need help. where is the set screw that i need to loosen in order to twist the collar? also i have the coilovers where the collar is on top of the spring so do i need to loosen the collar in order to make the ride lower? i.e. the less threading between the top of the assembly and the collar the lower the ride will be? or am i backwards and need to tighten it in order to compress the spring more.... i thought about it for like 2 hours and came up with logic that fit both ways and confused myself. thanks
  2. Oct 10, 2010 at 7:22 PM
    takern
    Tanner
    Virginia
    well i figured out where the set screw was. now i just need to know which way to turn it.
  3. Oct 10, 2010 at 7:31 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    trial and error and lefty loosey righty tighty. Good luck
  4. Oct 10, 2010 at 7:36 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I have the same ones you have, adjustment collar on the top. Reducing the amount of exposed threads above the collar will take lift out of it.
  5. Oct 10, 2010 at 7:40 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Me too. Less threads above the collar = less lift.
    This time, on the last turn, make sure to leave that set screw where you can get to it.
  6. Oct 11, 2010 at 5:11 AM
    takern
    Tanner
    Virginia
    Thanks guys.
