saw horse rebuilding
Discussion in 'Garage / Workshop' started by 07TacoRidah, Feb 12, 2012.
  1. Feb 12, 2012 at 1:19 PM
    07TacoRidah
    07TacoRidah [OP] SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
    Got a pair of sawhorses from the homies dad yesterday. Took them apart today to get some sanding and painting (also want to replace all the bolts/washers/etc. due to the original ones being very rusted). These are fairly old sawhorses BUT the good thing is that they are all metal but the top cross bar (it was made from 2x4 wood), now being all old and well unable to use them anymore, want to replace the wood pieces with some decent aluminum cross bars. anyone know where to get some? the length of the original crossbar (well one that somewhat survived through the years) isn't that long. Also can't go that long anyhow seeing is that the side support plates aren't that long either. the maker of these is Hirsh.
  2. Feb 12, 2012 at 1:22 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    Could you use a steel wall stud cut down to length?
  3. Feb 12, 2012 at 1:22 PM
    07TacoRidah
    also considering making the support pates longer if I can find the aluminum.
  4. Feb 12, 2012 at 1:24 PM
    JimBeam
    JB
    2015 Tundra
    Or something like this
  5. Feb 12, 2012 at 1:24 PM
    07TacoRidah
    would that be okay to use? I will be mainly using this to cut down mdf and such. I want to counter sink the holes for the bolts to go into so it sits flush and won't have to worry about the mdf or what Im cutting lifting a little due to the bolt sticking up.
  6. Feb 12, 2012 at 1:27 PM
    07TacoRidah
    NICE, going to have to see where I can pick that up around where I'm at. Thanks :cool:
  7. Feb 12, 2012 at 1:30 PM
    JimBeam
    JB
    2015 Tundra
    If you cant find them...you could probably take steel studs, and rip down a 2x4 and make your own
  8. Feb 12, 2012 at 7:02 PM
    07TacoRidah
    did some sanding but ran out of sand paper :( got both disassembled except for one - has a rusted bolt. picked up a drill from the homie, yet another freebie, even came with a counter sink bit :D).
    here's how they were before I got sanding. and the drill I got kicked down with (just picked it up a couple of minutes ago when the homie got to his pad).
  9. Feb 12, 2012 at 7:14 PM
    07TacoRidah
    lol YEAH for the freebie, but have to buy a chuck wrench at HF if I want to be able to swap out the counter sink bit for reg. drill bits and such
  10. Feb 13, 2012 at 12:10 PM
    07TacoRidah
    went to the hardware store and bought a bunch of new screws and nylon washers for the support plates as well as the chuck wrench from HF. no pix yet, just got to it since it's raining. WOOO on a adrenalin rush right now :D
    Put them both together for mock up and looking good!!! have a homie that is kicking me down with some 2x4's so all I have to do is get the wall studs. Other than that, all that's left is a little more sanding, primer and paint
  11. Feb 13, 2012 at 12:31 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Just my $0.02 but my old man as an old set of metal saw horses with wooden tops and the wood top is one of the best features. If you happen to screw up and knick the top with a blade, it doesn't do any damage to the blade and only leaves a small mark in the easily replacable 2x4. Just me, but I wouldn't want a metal top on a saw horse.
  12. Feb 13, 2012 at 1:38 PM
    07TacoRidah
    what threw me off the wooden tops is the wear and tear from the yrs. I took one look at the original ones that was already on the sawhorse ... I damn near got disgusted and didn't take them. But looking at them more I started to see how easy they were to fix. I'm getting hooked up with some 2x4 from the homie, so I have yet to buy the reg. steel wall studs.
  13. Feb 13, 2012 at 1:40 PM
    07TacoRidah
    here is how they look as of now. bought all new support brace screws and nylon lock nuts, just reused the lock washers since they weren't so bad imo. Just waiting for more funds so I can sand more, primer and then paint them and slap a decal on them just for the hell of it. :D
  14. Feb 13, 2012 at 1:42 PM
    07TacoRidah
    16 new screws and nylon lock nuts. will be swapping out the older ones up top too, just put them all together for mock up so I have room in the garage as well as a look at how they hold up. VERY happy right now :D
