SC BR6 17x9 w/33” tires and 6” lift
Discussion in 'Wheels & Tires' started by Dptip, Jul 9, 2020.
  1. Jul 9, 2020 at 8:45 PM
    Dptip
    Dptip [OP] Member
    Anyone know if those rims pair well with 33” tires and on a 6” lift Tacoma? Will there be any figment issues? Offset is -38mm. Thank you.
  2. Jul 19, 2020 at 11:59 PM
    Lunatic209
    Lunatic209 Well-Known Member
    17 Inferno TRD
    I have 34's on the 17x8.5 with 3 inch lift, I'd say you're better off going with 35x12.50 for 6" lift
    You might have to do cmc and upper control arms really help too. I have done cmc and jba upper control arms, clear the 34's pretty good but then my wheels aren't as wide. The wider and more negative offset the more chances of you rubbing the cab mount.
