Scan Gauge Correction Factor
Discussion in 'Technical Chat' started by bigred_d, Feb 5, 2011.
  1. Feb 5, 2011 at 4:14 PM
    bigred_d
    bigred_d [OP] Active Member
    Darren
    Vancouver, BC
    10 DC V6 TRD
    I haven't seen a thread on what people set their correction/calibration factor to.
    I'm not sure if every truck if different, or if every SG is different, but I have set the correction factor anywhere between 12.6% and 13.8%. Currently it is at 13.0%. This is for a 2010 V6 double cab automatic.
    I figure if I calibrate a number of times in different temps and locations after different driving scenarios, I should come up with an average. Right now the average of the above 3 is 13.13%.
    What are other people's values?
    ;D
  2. Feb 5, 2011 at 4:19 PM
    andrew862
    andrew862 Well-Known Member
    Andrew
    Fayetteville, NY
    DCLB 4x4 Limited
    Downey SST Tonneau, DeeZee Bed Mat, TRD Exhaust, ScangaugeII
    Hi, I just got a scangauge and have performed 4 fill-ups thus far. I have adjusted the correction factor at each fillup to a value between 8.6% - 12% As of this afternoon, my most recent fillup, it is set at 10.5%. I am curious to see what other say as well. I have specifically used the same fuel pump as recommended by Scangauge and still always have to adjust the value a little bit each time. Hope this helps.
    Oh, BTW, I am a 2010 Double Cab V6 TRD Sport
  3. Feb 5, 2011 at 4:22 PM
    2KTacoPr3runn3r
    2KTacoPr3runn3r Well-Known Member
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    Bilstein 5100 adjustables, 2 inch top plate spacer, bilstein 5100 rears and 2 inch blocks. Flowmaster super 10 with dual 4 inch tips.
    ive had mine for about 2 months and my correction factor is down to about 6% now. it started at around 13 or 14 i believe
  4. Feb 5, 2011 at 4:26 PM
    503TRD
    503TRD Trucker
    Chad
    Tualatin, Oregon
    '10 4x4 DC TRD Sport
    Front Bilstein 5100's Set @ 2.5", Rear Bilstein 5100's, Rear TSB, Rear 1.5" ToyTec AAL, 1" CB Drop Kit, N-Fab Nerf Steps, WeatherTech All Weather Rubber Floor Mats, Grillcraft Grill(Upper/Lower), Blacked Out AC Condenser/Radiator, Tinted Front Windows, Vision X H4 SuperWhite Headlights, Halo H10 Solaris Yellow 45w 3000k Fog Lights, K&N Air Filter, Removed Front Mud Flaps, 18" MagnaFlow Muffler, Chrome Exhaust Tip, TRD Logo Leather Shift Knob, LED License Plate Lights, LED Interior Lights, LED Reverse Lights, LED Auxiliary Reverse Lights, Chrome TRD Badge on Tailgate, Redline Tuning Elite Hood Struts, Disabled Seatbelt Chime, Foglights Anytime, ScanGauge II, 13" Stubby Antenna, Flyzeye Design LED Light, Cobra 19 CB Radio/Firestik II Antenna, 18x9 Raceline Raptors, LT275/70/18 Hankook Dynapro ATm, 1.25" Sidertrax Wheel Spacers, Heated Front Seats, LED Tailgate Bar, 11" Double Row LED Bar Behind Grill
    I haven't mounted mine yet so i haven't been driving with it plugged in, except I did it today for about 4 miles to the gas station and back, but I didn't understand the fill up part at all..its confusing what do you need to do?
  5. Feb 7, 2011 at 9:14 AM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    Mine goes down to 6-8% when using 91, and up to 12-13% on regular 87.
