Scan Gauge drained battery?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by shed_truck24, Jun 11, 2018.
  1. Jun 11, 2018 at 8:24 AM
    shed_truck24
    shed_truck24 [OP] Well-Known Member
    2015 DCSB TRD OffRoad 4x4 MGM
    265/75r16 Cooper AT3s
    I just got back from a week long honeymoon last night. The truck just sat all week and I went out this morning to head to work and nothing... I jumped it off and noticed while driving the scan gauge would just have a blank screen. Any chance the scan gauge drained the battery?
    The truck is a 2015 with the original battery. Any ideas?
    Thanks!
  2. Jun 11, 2018 at 9:20 AM
    Tacosail
    Tacosail Well-Known Member
    Jerry
    Hermanville Heights, Ohio
    '13 white ACLB
    '17 wheels,int. Wipers , bed mat , relocate trailer plug , husky floor liners , Lund nerf bars, wet Okole seat covers- heat & lumbar.
    Could be the scan gauge, but lets broaden the search a little. Could you have left a door ajar? Any electrical mods? Could have anybody tripped the security system, leaving the horn blaring until the battery died? Are the connections on the battery clean and secure? If nothing wrong on this list, I would disconnect the scan gauge for a couple days and then plug it back in.
    wilcam47 likes this.
  3. Jun 11, 2018 at 2:53 PM
    Purpleman
    Purpleman Well-Known Member
    Anaheim
    15 PreRunner
    Have the battery tested, doubt the scan gauge drained the battery.
    Is the scan gauge working or is the screen just blank now?
  4. Jun 11, 2018 at 7:23 PM
    shed_truck24
    Well the battery was bad. Hard to believe since it was only 3 years old
  5. Jun 11, 2018 at 7:58 PM
    2WD
    2WD Well-Known Member
    Pete
    2013 DCSB TRD Off-Road Pre-Runner Taco
    King 25001-119A, JBA HC and superbumps, EL095 leafs with longer overload leaf removed and 2 degree shim, Bilstein 5160 rears with fox roost shield on passenger side, King 2'' bump stops, B&M 70264 trans cooler, CSF FJ radiator, Leer Trilogy X2T bed cover, Scangauge, 34R AGM battery, weathertech floormats, Gold plug on the differential, fancy engine and diff oils, UNI air injection filter mod, Factory antenna chopped 4'', De-badged, Ram mount on A pillar, Cooper ST Maxx 265/75 R16.
    My OEM battery died in 2 years and 7 months. I wouldn't rush to blame the scangauge.
  6. Jun 11, 2018 at 8:33 PM
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    The scanguage only gets power through the obd2 port. If the keys off, the scanguage is off. If your keys off and the scanguage is on then you got some other internal issue going on in your vehicles computer. Just an fyi.
  7. Jun 11, 2018 at 8:37 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    heat is killer on a battery...sometimes they just make crappy products. My nissan titan's battery only lasted 3yrs...
  8. Jun 11, 2018 at 8:50 PM
    2WD
    Pete
    Not sure if this is correct. The scangauge turns itself off when you turn your truck off. But it always has power. I can press the button on mine when the vehicle if off and key out of ignition and it turns on for a little bit then shuts back off. It doesn't have realtime data, but shows the temps when it was last running.
    The OBD always has power. This is why you can buy a OBD cable to cigarette lighter cable when changing your battery to keep all of your memory. You give the OBD power so it keeps your memory, like radio stations, ect. Like this one https://www.amazon.com/gp/product/B01N7T2UWL/ref=oh_aui_search_detailpage?ie=UTF8&th=1
  9. Jun 11, 2018 at 8:55 PM
    Hoangde
    Hoangde Well-Known Member
    Battery is weak, standby is too long, scangauge is always power on regardless the truck is off or not, only LCD is off to conserve the power when the truck is off. Temperature is not ideally. All combination listed above caused your battery drained.
    FYI. On OBD connectors, pin 4 is ground and pin 16 is battery power (battery power is always on, accessories power is off when truck is off).
  10. Jun 12, 2018 at 6:44 AM
    shed_truck24
    I guess I was expecting the battery to last as long as the AC Delco in my 2002 z71 did. 10 years on the original.
    And thanks for all of the insight!
  11. Jun 12, 2018 at 8:45 AM
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    I always figured that it tan 100% off the key because mine will literally never come on unless the trucks running. I will have to check this out later!
