Scan Gauge II
Discussion in '2nd Gen. Tacomas (2005-2015)' started by StormTrooper, Sep 2, 2010.
  1. Sep 2, 2010 at 5:20 PM
    StormTrooper
    StormTrooper [OP] Well-Known Member
    Ron
    Maryland
    08 Base Flowmaster Super 44 w/ K&N drop in
    Bed Cap,K&N Air Filter,Chrome Pieces,Flowmaster Exhaust,Neon on inside, Heavy Duty Custom Floormats ( Tacoma ), Tint 20%, Blue license plate lights, Various decals, LED Projector Halos headlights, JVC head unit stereo
  2. Sep 2, 2010 at 5:31 PM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    installation 10 minutes...i love it cause its easier to trouble shoot problems cause your able to pull engine codes...
    you can also monitor different parameters of the vehicle...I have my SG2 set at monitoring IAT (intake air temps), AFR (Air Fuel Ratio), MPG (Miles Per Gallon), and Water Temps (coolant temps)...sometimes I will change water temps to Engine Load...
    there are tons more stuff that you can monitor...custom parameters like HP, transmission temp, oil temps, oil pressure etc...
  3. Sep 2, 2010 at 5:35 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    This is not true. Those 3 readings are not available.
    But, I am still happy I bought mine. I use, Altitude, MPG, Water Temp, Intake Air Temp and some times Throttle Position.
  4. Sep 2, 2010 at 5:47 PM
    StormTrooper
    Ron
    Maryland
    Idk i saw a video.. the guy entered a code to unlock Horsepower
  5. Sep 2, 2010 at 5:50 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    no he didn't otherwise everyone with a tacoma would have one
  6. Sep 2, 2010 at 5:51 PM
    MurphyZ
    MurphyZ Well-Known Member
    I HATE SPICYTACOS
    Alaska
    97 4runner, 08 Tundy
    89 SAS 3.4 1st gen 4runner- Sold 3.4 swap cut hood for clearance exhaust x-over and magnaflow muffler lockright in the rear SAS 83 toy axle (Wab-Fab) 4xinnovations sliders roof rack from 2nd gen for kayak.
    i like it, never seen altitude??? but it may be in there...
    water temp, mpgs,tps,intake temp.
    never had an issue and you can use it to turn off codes that pull up every once and a while.
    PO101 sucks...
  7. Sep 2, 2010 at 5:52 PM
    MurphyZ
    I HATE SPICYTACOS
    Alaska
    you you have one??? show me the codes for those parameters???
    hp
    trany temp
    oil temp
    and oil pressure
    i have one and can not find those anywhere.
  8. Sep 2, 2010 at 6:06 PM
    myname150
    myname150 Well-Known Member
    Sheez. 160$?!?! Anywhere cheaper?
  9. Sep 2, 2010 at 6:07 PM
    CopDoctor
    08 335i
  10. Sep 2, 2010 at 6:11 PM
    T0LLPHR33
    BSP TRD Off-Road
    whippersnapper02 is correct...not all the codes/parameters work on every vehicle...
    I was just merely listing some of the things that the SG2 can do...sorry if I mislead anyone here...that was not my intentions at all...
  11. Sep 2, 2010 at 6:13 PM
    Floki
    Floki Old Sheepdog
    St. Louis, MO
    2024 TRD Sport
    Mud on the tires
    Would the intake air temp be the same as the outside air temp? I don't have the compass/thermometer.
    edited to add:
    Eric, thanks for the quick reply.
  12. Sep 2, 2010 at 6:13 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Yeah, the code for HPR works on the Tacoma as I have it and use it every once in a while. ;):cool:
    And to the OP- I love my scanguage- wouldnt give it up. I use it every time I hop in the truck and love using it to monitor actual speed w/ my oversize tires as well as true distance since my odo on the truck is also off due to them. I monitor MPG's, and actual fuel level all the time too.:cool:
  13. Sep 2, 2010 at 6:15 PM
    RelentlessFab
    Eric
    Sparks, NV
    Very close when at highway speed, but any slower than that and the heat from the engine bay warms the intake and therefore the intake air temp. Stopped at a light on a hot day you might see IAT around 140+ degrees:eek:
  14. Sep 2, 2010 at 6:18 PM
    Bobo_1
    Bobo_1 Well-Known Member
    Bobo
    Maryville, TN
    09 TRD Sport L-Bed
    I see anywhere from a 2 to 8 degree difference from the outside temp as read from the temp/compass gauge in the overhead console.
  15. Sep 2, 2010 at 6:20 PM
    Bobo_1
    Bobo
    Maryville, TN
    09 TRD Sport L-Bed
    Got an almost new one on ebay for $120 shipped. Set up a search on ebay and have it emailed to you daily. You will find one much cheaper.
  16. Sep 2, 2010 at 6:20 PM
    Floki
    Floki Old Sheepdog
    St. Louis, MO
    2024 TRD Sport
    Mud on the tires
    How accurate are the numbers you get for the various settings?
  17. Sep 2, 2010 at 6:20 PM
    Bobo_1
    Bobo
    Maryville, TN
    09 TRD Sport L-Bed
    More codes using the XGauge feature:
    Altitude Gauge (Feet)
    TXD: 07E02133
    RXF: 04610533
    RXD: 2808
    MTH: FEEE00016B08
    NAM: Alt
    Air to Fuel Ratio (Lambda)
    TXD: 07E02144
    RXF: 04614544
    RXD: 2808
    MTH: 006400800000
    NAM: AFL
    Air to Fuel Ratio (True Air to Fuel ratio)
    TXD: 07E02144
    RXF: 04614544
    RXD: 2808
    MTH: 05BE00800000
    NAM: A/F
    Atmospheric Pressure (PSI)
    TXD: 07E02133
    RXF: 04610533
    RXD: 2808
    MTH: 000A00450000
    NAM: PSI
  18. Sep 2, 2010 at 6:24 PM
    Bobo_1
    Bobo
    Maryville, TN
    09 TRD Sport L-Bed
    From what I can tell, meaning I only have one source to compare with, the air temp is spot on as it should vary as much as I wrote earlier since those readings are in the engine bay with the temp sensor sitting right over the top of the engine.
    Also, when I monitor the water temp is seems to be spot on too as I can tell when the thermostat opens which is about 185 degrees and that is what the gauge is reading at this time. Not that I know the firmware and ODBII intimately, but, AFAIK, it is only broadcasting what is sent to it via the sensor via the ODBII cable. So, it is as accurate as your sensors. If they are not accurate then what the gauge reports won't be either - garbage in then garbage out.
  19. Sep 2, 2010 at 6:34 PM
    JAG
    JAG Well-Known Member
  20. Sep 2, 2010 at 6:37 PM
    JAG
    Yes. They call it the ear gauge.....
