Scan Gauge
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Devilfan, Aug 25, 2024.
  1. Aug 25, 2024 at 6:47 PM
    Devilfan
    Devilfan [OP] Well-Known Member
    I've been thinking about getting a Scan Gauge for my truck. Will it compute the fuel economy even though my truck does not show the MPGs?
    koditten likes this.
  2. Aug 25, 2024 at 6:55 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Yes it will, and a whole lot more. It will take a few fill ups to calibrate it, but it will give you the info you want.
    Hint: do not tell it to track the dollars per miles. It will only depress you.
    inwood customs likes this.
  3. Aug 25, 2024 at 7:21 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Yes, you have to train it though by filling the tank each time and telling it how much you put in.
    Once it's trained it's pretty accurate, mine is rarely off more than 0.3 gallons when I fill up.
  4. Aug 26, 2024 at 10:44 AM
    Devilfan
    Thanks. Seriously considering one
  5. Aug 26, 2024 at 6:23 PM
    Macbugs23
    Macbugs23 Active Member
    Ephrata, PA
    2006 Toyota Tacoma SR5 4x4
    Will it do transmission temperature as well? My Innova 3040RS won’t..
  6. Aug 26, 2024 at 6:25 PM
    02hilux
    Planet: EARTH
    Glueman and koditten like this.
  7. Aug 26, 2024 at 6:26 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Not by default but there's x-gauge codes for trans temps.
    Enigma8246 likes this.
  8. Aug 26, 2024 at 6:26 PM
    Enigma8246
    Enigma8246 Well-Known Member
    Lee
    Central Arkansas
    2007 4Runner Limited 4WD V8
  9. Aug 26, 2024 at 6:31 PM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    I don’t have a 2nd gen but I do love my scanguage.
    Stuck in VT likes this.
  10. Aug 26, 2024 at 6:34 PM
    koditten
    Kirk
    Central Michigan
    Yes, it will, but it takes a bit of programming. My inner geek liked the challenge. I only opted for the pan temp, I didn't feel the need to program in the TConverter temp.
  11. Aug 26, 2024 at 6:37 PM
    koditten
    Kirk
    Central Michigan
    I wish I had side by side view of the #2&#3 SG. I like the size of the numerals of the SG2. Are the SG3 readouts smaller? Might be a deal killer for me.
  12. Aug 26, 2024 at 8:03 PM
    02hilux
    Planet: EARTH
    SG3 readout are larger with more options. The unit is much bigger and the display color are changeable. Downfall, it’s 3x more.
    i didn’t like the 2
  13. Aug 26, 2024 at 8:08 PM
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
    I vote for scangauge 2. It’s cheaper smaller and more simple. I like simple and it only blocks my headlights on dash light and cruise control on dash light when mounted on my steering column. I monitor avg mpg, trans temp, rpms, and coolant temp.
  14. Aug 26, 2024 at 8:33 PM
    Louisd75
    Louisd75 Well-Known Member
    Northwest Washington
    '02 Xtra Cab, '15 DCSB
    I had the Scangauge 2 on my 1st gen. I've had the Scangauge 3 on my 2nd gen for about a year now. It will track mpg, instant and average. It will also do AT temps in/out. There are three pages worth of parameters that can be accessed by swiping left or right. Each page can have info displayed, up to a 3x3 grid, it's all user selectable. You can also add alarms. For example, you can set an alarm for if the AT fluid gets above a certain temp.
    koditten and 02hilux like this.
  15. Aug 27, 2024 at 12:36 AM
    kwanjangnihm
    kwanjangnihm Timeout Terminator
    Jeff
    Central Florida
    13 DCLB TRD SP PR OTT
    "If it ain't a longbed it ain't shit! :)
    Just added one on my 2013 to monitor tranny temps. Adding a larger trans cooler soon.
  16. Aug 27, 2024 at 9:29 AM
    Smills91
    Smills91 Well-Known Member
    Scan gauge looks like a fabulous accessory. However, can one get all the same or at least most of the same Intel via an android head unit (like a Joying or dasaita)?
  17. Aug 27, 2024 at 10:27 AM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    Man, I've had my Scangauge II for almost 18 years now. I like to display my mileage and trans temp info. It's definitely helped me improve my mileage more than anything else.
    I thought about switching to the SG III, but it's too large to fit where I want it to.
  18. Aug 27, 2024 at 12:17 PM
    kwanjangnihm
    Jeff
    Central Florida
    thats not what she said!! :anonymous:
    Musubi3[QUOTED], 1schoir and koditten like this.
  19. Aug 27, 2024 at 12:43 PM
    risethewake
    risethewake Well-Known Member
    Will
    '15 MGM Sport AC
    Basics. Tires, painted headlighes, UHLM, baby winch in the bed, and heated mirrors :)
    FWIW I considered getting a scangauge, but then I upgraded my head unit to a Pioneer with the idatalink RR module that plugs into the OBD port. That gives me all the info I need on-screen(multiple pages actually, but all user-configurable), at the touch of whatever steering wheel button I want to program it to.
    Including average and instant fuel mileage, TPMS pressure/temp readings per-tire, and even reads CEL codes. And no need to mount an additional screen.
    Not sure if the scangauge may be more suited to your specific needs, but worth a thought if you also happen to want to install a new HU. As said above, there are also droid-based and other head units out there with app capabilities, but I have no experience with those
    koditten and kwanjangnihm like this.
  20. Aug 27, 2024 at 1:21 PM
    koditten
    Kirk
    Central Michigan
    This is the rabbit hole I'm resisting going down.
    Wanting to change out the head unit on my '21. I know I'll be getting a head unit that can gather all the info that the scan gauge can.
    kwanjangnihm likes this.
