Scan guage II vs ultra guage
Discussion in '1st Gen. Tacomas (1995-2004)' started by smmarine, Feb 13, 2014.
  1. Feb 16, 2014 at 4:56 AM
    smmarine
    smmarine [OP] Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    So I think I'm going to go with a ultra guage. Any recommendations on the mounting hardware/brackets I should order with it. Without seeing it in person I am unsure as to where I will mount it
  2. Feb 16, 2014 at 5:18 AM
    Lastplace
    Lastplace Well-Known Member
    Southeast VA
  3. Feb 16, 2014 at 5:23 AM
    smmarine
    Melbourne FL
    It's in my profile. I don't. I'm a 99 with no abs
  4. Feb 16, 2014 at 9:01 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I need to correct myself on this, I think.
    I assumed I didn't have a tranny temp sensor, since my UG did not list it as an available display item. I just checked my FSM (the electrical diagrams), and it shows that sensor ! Maybe the sensor is sending a signal to the ECM to affect something, but the ECM is not storing it ? Just don't know.
    So, still not sure if the Scan Gauge will pick it up or not :confused:
    Where would the sensor be, if there was one? On the tranny pan? Cooling line?
  5. Feb 16, 2014 at 11:04 AM
    PhdNPrerunners
    PhdNPrerunners Well-Known Member
    Justin
    The Woodlands, TX
    1999 4Runner SR5 4WD
    I would think that a 99 would have a trans temp sensor because I know my 99 4runner had one.
  6. Feb 16, 2014 at 4:05 PM
    smmarine
    Melbourne FL
    I'm gonna send a PM to BamaToy1997. He'll probably know
  7. Feb 16, 2014 at 4:47 PM
    smmarine
    Melbourne FL
    He doesn't know
  8. Feb 16, 2014 at 4:58 PM
    smmarine
    Melbourne FL
    It appears my truck does have a sensor that is sending a temp signal to the ECM. If the scan guage can pull trans temps off some first gens, I'm thinking it will pull mine
  9. Feb 16, 2014 at 7:24 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    IIRC, it has something to do with the lock up clutch primarily. To keep the fluid from getting too cold with it engaged too long.
    Not located in the pan. Not sure where, but this link def shows it mounted on the outside of the trans:
    http://www.moranbahweather.com/toyota/lc_trj12/rm/rm1017e/m_40_0016.pdf
    Worth a try I guess. If it doesnt work, send it back and get the UG.
  10. Feb 16, 2014 at 7:43 PM
    smmarine
    Melbourne FL
    You make a good point. I can a scan guage off Amazon. They will take it back no questions asked
  11. Feb 16, 2014 at 7:46 PM
    smmarine
    Melbourne FL
    And to Tan4x4, that pic looks like it's on some sort of line. Maybe the line that sends it to the radiator?
  12. Mar 17, 2014 at 3:06 PM
    smmarine
    Melbourne FL
    So I still haven't decided what to get. I emailed scanguage and they cannot confirm if it will work or not. They actually don't have a x-guage code for tacoma trans temp before 05, but told me there's codes on forums that work. They just could not confirm if it would work on my 99
  13. Mar 30, 2014 at 7:24 PM
    OffsetPlayer2
    OffsetPlayer2 Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    Did you ever decide on getting one of these? Im on the fence about getting a scan gauge and trying to see how others like it. Can get it from my local advance auto for $48 off, but im trying to see how others feel about it first.
  14. Mar 30, 2014 at 7:45 PM
    smmarine
    Melbourne FL
    I haven't yet, I'm still trying to find out if it will read my trans temp cause that is really what I want. I'd really love an ultraguage, but they do not read toyota trans temps. Scanguage does, but nobody can tell me if it will read it older then an 01. How are you getting it at $48 off!? I was gonna order off Amazon so I could send it back no problems if it doesn't work for me
  15. Apr 16, 2014 at 1:31 PM
    #35
    smmarine
    Melbourne FL
    I ended up getting the scangauge, and input the x-code I found on here that worked for a 2002. It's reading something, and according to scanguage that means it's working. It's the one labeled TRA
    A9C5ED9E-38D4-4661-8111-26044A9EA200_zps_3488484b2cb43f14eda90f374b02c0db05642786.jpg
  16. Jul 25, 2014 at 3:26 PM
    #36
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    The X-Gauge Code for ScanGauge Auto trans temp is as follows:
    Trans Temp
    TXD: 68 6A F1 01 B4
    RXF: 04 41 05 B4 00 00
    RXD: 28 08
    MTH: 00 09 00 05 FF D8​
  17. Jul 25, 2014 at 6:28 PM
    #37
    smmarine
    Melbourne FL
    I got it working. Thanks!
