Scangauge II A/F Ratio
Discussion in 'Performance and Tuning' started by ghostboy808, Mar 21, 2009.
  1. Mar 21, 2009 at 1:49 PM
    ghostboy808
    ghostboy808 [OP] Well-Known Member
    Silver Mica Prerunner TRD Sport
    Gibson SS, TRD S/C
    I found these codes on another forum and they give me a readout but I'm not sure if its accurate.
    Air to Fuel Ratio (True Air to Fuel ratio)
    TXD: 07E02144
    RXF: 04614544
    RXD: 2808
    MTH: 05BE00800000
    NAM: A/F
    Can anyone with a scangauge and who has an A/F Gauge hooked up let me know if this works for them. I am getting readings between 13.5-14.5 but mostly 14.5 if this is correct I am running very lean.
  2. Mar 21, 2009 at 1:50 PM
    ghostboy808
    Gibson SS, TRD S/C
    here's the rest of the codes if anyone wants to try. They work on tundras but they say its supposed to work on tacomas 05 and up also.
    Altitude Gauge (Feet)
    TXD: 07E02133
    RXF: 04610533
    RXD: 2808
    MTH: FEEE00016B08
    NAM: Alt
    Air to Fuel Ratio (Lambda)
    TXD: 07E02144
    RXF: 04614544
    RXD: 2808
    MTH: 006400800000
    NAM: AFL
    Atmospheric Pressure (PSI)
    TXD: 07E02133
    RXF: 04610533
    RXD: 2808
    MTH: 000A00450000
    NAM: PSI
  3. Mar 21, 2009 at 2:57 PM
    jaxchrisfla
    jaxchrisfla Well-Known Member
    flooriduh
    lots
    at what throttle position? Up to a certain TPS, your stock maps should be in that range, its when you get into WOT that you should be worried if it is that lean.
  4. Mar 21, 2009 at 3:02 PM
    ghostboy808
    Gibson SS, TRD S/C
    ok just wanted to see if the numbers match up to someone who has a dedicated a/f gauge hooked up. yeah it sits at 14.5 or so idle and low speeds, dips down when at wot to maybe 12.xx Was looking into gettin an a/f gauge but if this is in the range I don't need to.
  5. Mar 21, 2009 at 3:08 PM
    jaxchrisfla
    flooriduh
    lots
    what mods do you have? usually stock n/a it will dip into the 10s. I just added the code to my scanguage and tonight when i go out tonight and hook it up to my X-1 Xtune software. Only thing that is bad about the scanguage is it doesnt read as fast, but i believe if you have all 4 on the display set on the a/f it will read quicker.
  6. Mar 21, 2009 at 3:25 PM
    MotoXFreeStyle61
    MotoXFreeStyle61 Displaced Texan
    San Antonio TX
    06 PreRunner SR5 4Cyl, Access Cab, 5
    Black Head Light Mod, Tacoma All Weather Mats, ScanGauge II, Tonnaeu Bed Cover, 40% Tint, Added Fog Lights, 600W x 1 Alpine MRP-M650 Amp, Alpine 10" Type-R SWR-1022D Sub, Secondary Air Filter Removed, Day Time Running Lights, K&N Drop In Air Filter (oiled), Westin Bullbar (Black Powder), Alpine IVA-W505 w/Nav, JL Audio 6.5" Front Speakers, Toyota SR5 Seat Covers, 2.5" Toytec Spacer
    SO what exactly is "X-gauge"? I know you can add your own gauges but how do you go about doing it? I bought my ScanGauge II prior to July 20th, 2007, so I know I would have to send it in with $25. Is it worth it?
  7. Mar 21, 2009 at 3:27 PM
    ghostboy808
    Gibson SS, TRD S/C
    have the trd charger with ecu flash and gibson exhaust, that's it. I didn't do much driving around yet but was just hoping someone with a real gauge can test this to see if the numbers read close. Yeah the gauge is pretty slow to react but as long as it's ballpark it'll be good enough for me untill I can buy a gauge and pod.
  8. Mar 21, 2009 at 3:30 PM
    ghostboy808
    Gibson SS, TRD S/C
    It just allows you to customize your own options like instant horsepower and stuff like that. on their site you can find a list of different codes you can input to monitor other things that the regular gauge can't.
  9. Mar 21, 2009 at 3:32 PM
    jaxchrisfla
    flooriduh
    lots
    it allows you yourself to add the new gauges they come out with, instead of sending it back in for a update. So send it back in once, and then as they create new features for different cars, they update their site.
    Mine always displays mph, fIA, fWT, and TPS.
  10. Mar 21, 2009 at 3:55 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    If so, anyone try them?
  11. Mar 21, 2009 at 5:23 PM
    jaxchrisfla
    flooriduh
    lots
    Ill be out in a little while, so Ill report back later on how they do.
  12. Mar 21, 2009 at 5:23 PM
    roxspin72
    NC
    Oh Yeah!!!
    Thanks for this info, been needing to hook up an AF guage since installing the APR X-1.
    It works pretty good.
    Hey Jax, let me know what you think when you are done, our mods are similar. After warming up the truck the A/F read right about 14.7ish. While driving around in cloosed loop it never went above 14.8 and depending on TP i'd say it went as low as 13.8. WOT = 12-12.5 ish. I believe this to be pretty close to optimal performance via the APR Tune that was loaded in my unit without any further tuning from myself.
    Reason Im looking for your opinion, is cause I need to know if you think we can trust these readings, and also need to know if you have done any tuning to the unit since installing?
    Reason Im concerned about fuel trims is since studying Gadgets PDF for U-tune; seems the stock computer is always trying to dump more fuel and keep the motor rich. Well, when tuning w/my previous MAF cali, optimal fuel trims were supposed to balance to about zero, w/the short term trims being hardest to maintain. Since installing my X-1, I monitored the trims w/my LM-2. Reading showed short term fighting and holding right about zero... but the Long term kind of hold steady @ -10ish...
    Anybody have any info or knowledge on wether this is optimal. My A/F ratio is right at the sweet spot, just wondering if I should fine tune the fuel trims:confused: And if thats the case, OMG; im dreading messing with the XTune software LOL... Might have to take a trip and visit Gadget:D
    Anyways, if you read all this, Thanks...
  13. Mar 21, 2009 at 6:11 PM
    jaxchrisfla
    flooriduh
    lots
    do you have a laptop rox? to be able to log a file, youll need one. But it allows you to really tune the truck well, and send it over to me i can review it for you and make some changes if youd like.
  14. Mar 21, 2009 at 6:25 PM
    roxspin72
    NC
    Oh Yeah!!!
    Sounds good. I gots to go train for the next three weeks. When I get back I will log the file and send it to you on digits.
    Appreciate the help,
    Thanks...
