Scangauge II can it read oil pressure??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco Man 06, Jul 16, 2010.
  1. Jul 16, 2010 at 10:19 AM
    Taco Man 06
    Taco Man 06 [OP] Member
    Can someone tell me if their is a program for the scan gauge II for reading oil pressure on my 06 Tacoma. If so where do you get that program or can someone please tell me it. Thanks
  2. Jul 16, 2010 at 11:16 AM
    JKD
    JKD Well-Known Member
    I would be surprised if the Tacoma had an oil pressure transducer. More likely, it has a simple switch that it uses to sense whether or not the oil pressure is above or below the minimum point (usually 5-10 psi).
    Of course, it wouldn't be the first time I was surprised about something on the Taco, so please correct me if I'm wrong.
  3. Jul 16, 2010 at 11:42 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I don't think so. It doesn't read transmission temps either.
  4. Jul 16, 2010 at 11:44 AM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
    No, it doesn't read oil pressure or trans temp.
  5. Jul 16, 2010 at 11:45 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    :popcorn:
    I wish! Maybe someone has the code?
  6. Jul 18, 2010 at 2:14 AM
    808hiker
    808hiker Taco addict
    Justin
    Big Island, Hawaii
    No ATF temp or oil pressure scangauge x-gauge for the Tacoma? That's pretty lame.
  7. Sep 29, 2011 at 3:21 PM
    integlikewhoa
    integlikewhoa Active Member
    JAMES
    ARCADIA
    06 4.0l Double 4X4 offroad
    Maybe not at the time but Trans temp is now working on my 06 4.0L V-6 with the following info:
    Transmission Fluid Temperature
    TXD: 07E021D9
    RXF: 032180000000
    RXD: 2810
    MTH: 00070065FE70
    NAM: TFT
    In degrees F
    White_Pearl TRD likes this.
  8. Sep 29, 2011 at 4:34 PM
    shawnd2
    shawnd2 Well-Known Member
    Shawn
    Toronto, Ontario, Canada
    08 Tacoma Access Cab 4x4 TRD Offroad
    Anyone else have any luck getting this to work?
    I'm not home to try it out.
    Shawn
    yonah likes this.
  9. Sep 29, 2011 at 6:28 PM
    JKD
    Just tried it in my 2009 4.0 V6. Doesn't work. Displays blank/no data.
  10. Sep 30, 2011 at 6:53 AM
    integlikewhoa
    JAMES
    ARCADIA
    I'll post pics or vid. of it working on my 06 today
  11. Sep 30, 2011 at 7:04 AM
    integlikewhoa
    JAMES
    ARCADIA
    Have you guys tried calling scanguage recently? That's where I got the info from. I had tried several online and was always blank. I called and gave him my info. Working like a charm. It's on 7:00am here in Cali I''ll take a quick Vid on my way into work in my 06 4.0l
  12. Sep 30, 2011 at 9:30 AM
    integlikewhoa
    JAMES
    ARCADIA
  13. Sep 30, 2011 at 10:34 AM
    shawnd2
    Shawn
    Thanks for taking the time to post the video.
    I'm flying home tonight, and will give it a try on my 08. I'll have to look up how to enter the "X gauges" again as it been a couple of years. I'll post the results.
    Now if only you could tell me how to get it to post in deg C!
    Shawn
  14. Sep 30, 2011 at 11:30 AM
    GAtrd
    GAtrd Member
    Georgia
    11 TRD OR
    Thanks for the video. Unfortunately this code is not working for my 2011.
  15. Sep 30, 2011 at 11:37 AM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Will try on my '07 in when i finish work and will update. I will be a happy little school girl if it does work :D
  16. Sep 30, 2011 at 12:03 PM
    MTL Tacoma
    MTL Tacoma Well-Known Member
    Montreal, Canada
    2016 DC LB TRD Sport
    Just tried it on my 2008 and unfortunately it doesn't work!​
  17. Sep 30, 2011 at 6:16 PM
    integlikewhoa
    JAMES
    ARCADIA
    I'm here where are you?
    So far I have heard 08, 09 and 10 doesn't work. Still waiting to here from the older guys as to what the cut-off was.
  18. Sep 30, 2011 at 7:16 PM
    shawnd2
    Shawn
    I just got home from Kansas City, I'll give it a try on my 08 just to double check.
    Shawn
    Just tried it on my 08, no luck either.......
  19. Sep 30, 2011 at 10:44 PM
    integlikewhoa
    JAMES
    ARCADIA
    2nd video after the truck was normal operating temp. I found city streets I'm in the 140's, After freeway driving I got off and got it up to 180's today. Here's a city drive at night. Showing water temp, intake air temp, trans temp, and voltage.
    http://www.youtube.com/watch?v=pTRfLcGJM7s
  20. Oct 3, 2011 at 9:42 AM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    Not working on my '07, double checked codes.
