ScanGauge II coming today!
Discussion in 'Performance and Tuning' started by ndub86, Jul 23, 2013.
  1. Jul 23, 2013 at 1:24 PM
    ndub86
    ndub86 [OP] Well-Known Member
    Neal
    Dallas, TX
    '13 Double Cab 4X4 TRD Sport
    So I ordered the ScanGuage II mostly out of curiosity in wanting to know what temp my engine operates at, transmission, my MPGs over various trips, etc. and to detect any problems before it becomes a problem...
    It's supposed to arrive today. I always feel like a kid on Christmas morning when I order a new gadget and it shows up! :yay:
    Hoping I'll have no problem with getting it to read the transmission temp. Saw some threads here where people had issues, but it seemed that 2011+ didn't have that issue anymore.
  2. Aug 4, 2013 at 11:58 AM
    AFTaco
    AFTaco Well-Known Member
    Doug
    Anchorage, Alaska
    TRD Off-road
    Just curious, what problems did you read about? I have an 09 and was thinkin on getting one to read my tranny temp.
  3. Aug 4, 2013 at 4:12 PM
    lasllc
    lasllc Well-Known Member
    SW Denver Burb
    13 SuperWhite DCSB Sport 4X4 Tow Pack
    SnugTop Super Sport, BedRug mat, Redline Tuning hood lifts, LED interior lights, 3D carpet protectors.
    I just traded up from my 09 with man trans, so no trans temp available there, to a 13 DBSB sport and put on a new SG II. You will need to get the code specific to tacoma for trans temp. Mine works perfect with no probs at all. Runs in the mid 150's around town with 80+ outside temp.
    Let me know and I will post code I used, if you need it.
  4. Aug 4, 2013 at 11:53 PM
    Ryan Tucker
    Ryan Tucker Do it Dont talk about it
    Terrell Texas
    13 DCLB MGM Tacoma
    TRD Sport Camper Top
    Anything you could post to help read the trans temp would be great. Ive read the entire scan gauge book and been on here 3 hours reading through threads from the search feature, and not found it yet.
    Ive got about 4 days driving now on my new SG II and love it so far, its a great tool. I tow a lot and really need to monitor the trans temp, its the main reason I choose it over the other couple options. Thanks
    Tucker
  5. Aug 5, 2013 at 5:58 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
  6. Aug 5, 2013 at 9:03 AM
    lasllc
    SW Denver Burb
    The codes and to what vehicles they apply are on the scan gauge website.
    The booklet only tells you how to enter them
    this coding is what worked for my '13 AT and is what is referred to above.
    Transmission Fluid Temperature
    TXD: 07E021D9
    RXF: 032180000000
    RXD: 2810
    MTH: 00070065FE70
    NAM: TFT
    In degrees
  7. Aug 5, 2013 at 11:11 AM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    Ndub86,
    Can you post some pictures when you get it installed? I've been contemplating getting a SGII but not sure where I'd mount it yet.
  8. Aug 5, 2013 at 12:09 PM
    lasllc
    SW Denver Burb
    I will put up a couple pics also; mine is over the mirror using a blend mount .
  9. Aug 5, 2013 at 12:17 PM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Also to be clear, 10+ have TFT1 and TFT2 for pan temp and torque converter temp, 09- is TFT1, pan temp only.
  10. Aug 5, 2013 at 12:20 PM
    lasllc
    SW Denver Burb
    Blend mount and Scangauge. '13 DBSC Sport.
    About 30 mins to run cable and configure mount.
  11. Aug 5, 2013 at 4:10 PM
    RacecarGuy
    Houston, Texas
    '12 DCSB OR
    I really like this setup but I've relocated my rear view mirror higher, so the scan gauge won't fit on top.
  12. Aug 6, 2013 at 5:33 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Search, there is a thread on scanguage mount options that people have used.
    I don't have pics, but one of the ideas that I picked up (since I also have the mirror relocate bracket), is to take the belt clip from a measuring tape (or somesuch) and a small screw (need to be careful to screw it back far enough that it doesn't hit the SG electronics), remove the SG back cover, screw in the clip to the back cover, then I added two pieces of the hook part of velcro to the either side of the clip. Then I clipped the SG to the top left of my headliner, and just have the cable routed down the A-pillar.
  13. Aug 6, 2013 at 9:44 AM
    Ryan Tucker
    Terrell Texas
    13 DCLB MGM Tacoma
    Thanks guys, I bet Ive spent 3-4 hours reading on the subject. That thread and data dated a ways back and didn't come up through my searches but appreciate you posting it. I have all that wrote down I will go give it a try. Thanks again
  14. Aug 6, 2013 at 4:09 PM
    Ryan Tucker
    Terrell Texas
    13 DCLB MGM Tacoma
    Worked great, no problem once you have the correct codes, thanks guys.
  15. Aug 6, 2013 at 9:22 PM
    lasllc
    SW Denver Burb
    That's because you selected instantaneous MPG instead of average. Check the code list at the front of the book.
  16. Aug 8, 2013 at 5:32 PM
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    This code worked for my 09. Mounted on the steering column plastic with some velcro.
  17. Aug 30, 2013 at 4:26 PM
    lasllc
    SW Denver Burb
    When SC is in norm op mode, 4 gauges displayed, whenever you push a button it advances that display to the next gauge.
    You need to post the four 3 alpha codes that the gauge displays when motor is running and the position on gauge (lower left, upper right, etc)
  18. Aug 30, 2013 at 5:12 PM
    lasllc
    SW Denver Burb
    At each of the four corners the display is a number and a 3 digit alpha code for example : 68.0 MPH is you speed ad reported by the ECU. 2114 RPM is engine rpm.
    You did set this up according to page 4 - 13 right?
  19. Aug 30, 2013 at 5:20 PM
    lasllc
    SW Denver Burb
    Referring back to YOUR post #15. How do you know if your mpg is jumping around if you don't even know if SC is displaying mpg as you are unaware of the 3 digit alpha codes that tell you what you are looking at ?
  20. Sep 1, 2013 at 9:41 AM
    lasllc
    SW Denver Burb
    Page 26 of the manual. This thing is not exactly plug and play, you know.
