Scangauge on 2016
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 0311K1LL, Apr 26, 2016.
  1. Apr 26, 2016 at 11:09 AM
    0311K1LL
    0311K1LL [OP] The Old Breed
    Curt
    Jupiter, FL
    2016 SR AC 2.7L 4X4
    OME 887 w/Bilstein 5100's, 1.5 AAL, SPC LR UCAs 285/75/r16 Toyo AT2s!
    Just wondering if anyone has a Scangauge or knows the normal operating temp for this years new transmission? Also is it worth buying one for monitoring mpg? I have a base SR with no LED display, just a simple LCD with no fuel monitoring features.
    Thanks!
  2. Apr 26, 2016 at 11:14 AM
    Clearwater Bill
    Billy
    Largo Florida
    Transmission operating temps should not change, regardless of the trans. The fluid is the limiting factor, not the number of gears or control mechanism.
    I have one in both my vehicles. While nice for MPG, it's even better for voltage, coolant temp, verifying MPG and RPM calibrations, etc. Not to mention if you ever have a CEL pop up you're already wired to read and clear it.
    In todays world of gizmo nonsense, an OBDII monitor is one of the better accessories one can add.
    Not to mention you can reinstall it on any 1996+ vehicle, should you trade. So it's a transferable mod.
    0311K1LL[OP] likes this.
  3. Apr 26, 2016 at 11:29 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    I had a Scangauge. It's definitely a great tool to have. That being said I just sold mine not too long ago. I found myself forgetting it was there and stopped looking at it unless I took highway trips. I bought it to monitor fuel economy, but now I've just reverted to hand calculation. If I towed a lot I would have found more use for it. Eventually I'm just going to buy an Ultragauge at some point down the line. The plus side of the Scangauge though is you can disconnect it to put it away out of sight and can change the backlight colors to match the dash.
  4. Apr 26, 2016 at 11:31 AM
    Clearwater Bill
    Billy
    Largo Florida
    I should have added that while I 'use' it to monitor fuel, I don't record those numbers. I still enter a log and do it by hand. As it's more accurate.
    I like it more for the other benefits it brings.
