scangauge problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by deerslayer75, Aug 28, 2011.
  1. Aug 28, 2011 at 7:09 PM
    deerslayer75
    deerslayer75 [OP] Well-Known Member
    Tim
    jersey shore
    11 TRD sport Dblcab Lngbed
    pop-n-lock, mcgard tailgate lock, chrome tube steps, bed extender, chrome brush guard, Fold a cover (G-4) tonneau, weather tech floor mats and rain gaurds, sock monkey: TRD 3rd brake light and whitetail decals, LED bed lights, blue map & dome, 3rd brake light and license plate LED mod, illuminated 4x4 switch, fishing rod holder mod, scangauge II, Remote start & alarm, TW sticker, Flyzeye cupholder light mod
    I just plugged in my new scangauge and mph and mpgs aren't working. Has anyone else had this problem or know how to fix it?
  2. Aug 28, 2011 at 9:13 PM
    JKD
    JKD Well-Known Member
    Since you say you "just plugged in" the scangauge, did you go through the steps in the instruction manual that tell you how to set it up for your vehicle? You know, telling the scangauge the size of your fuel tank, that sort of thing?
    Here you go.
  3. Aug 29, 2011 at 1:50 PM
    deerslayer75
    Tim
    jersey shore
    yes I set it up just not registering the two functions
  4. Aug 29, 2011 at 8:43 PM
    JKD
    Never heard of that problem before. I'd contact the maker of the Scangauge, either something is odd about the 2011 (perhaps your truck is really new and there was a mid-year change?) or your scangauge is defective.
  5. Sep 4, 2011 at 9:12 AM
    deerslayer75
    Tim
    jersey shore
    Problem solved. I had the cluster out to replace the led's with all blue ones (done by yosh2000) and for whatever reason the scangauge wouldn't read those two things without the cluster plugged in.
  6. Sep 4, 2011 at 11:26 AM
    Hayes
    Hayes Well-Known Member
    Brandon
    Denver, CO
    2011 Regular Cab Tacoma 4x4
    That's weird. I am having a problem with the avg reading ridiculously high (read: 55-60 mpg) and some other weird readings. I used to have the scangauge II set up in my old Impala and it worked fine, it's like it wont switch to the new truck. I am about to look over the manual again to see if I need to do something more to get it to work.
