Scangauge Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by grammy, Sep 13, 2009.
  1. Sep 13, 2009 at 7:29 PM
    grammy
    grammy [OP] Well-Known Member
    Newfoundland, Canada
    4x4 v6 X-Cab
    Can anyone tell me if the Scangauge II X can display the outside (ambient) air temp? This would be for an 09.
    Thanks
  2. Sep 13, 2009 at 7:34 PM
    gavonder
    gavonder She's Kickass!
    Bethel, Ct
    08 TRD Sport Access Cab
    Sunroof, Leer Cap w/ Thule rack, Factory Running Boards, Fog Light Mod, Hood Struts, Scangauge, w/homemade mirror mount, AC/Defrost mod, Rear Spring TSB, TRD Center Caps
    no, it does not.
    GA
  3. Sep 13, 2009 at 7:36 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    On my 05, it can display the air intake temp, which uses a different sensor than the compass/temp gauge.
  4. Sep 13, 2009 at 7:37 PM
    Snyperx
    Snyperx Seniore Marcos
    It only displays the intake air (IA) temperature. That's as close to outside ambient temperature you are going to get.
  5. Sep 13, 2009 at 9:55 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    If you have the gauge set on intake temp. and check it after the engine has been shut off for a long while, the reading is actually very accurate. Also at highway speeds it will give you a close enough "ballpark" figure.:)
  6. Sep 13, 2009 at 11:37 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    With the stock intake my intake temp is usually 4 to 10 degrees higher than the overhead temp display.
  7. Sep 14, 2009 at 4:22 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    X2
  8. Apr 28, 2010 at 7:27 AM
    swbimny
    swbimny Member
    San diego
    4X4
    I found someone with a 2010 toyota yaris had entered ambient air temperature in Xgauge and was successful getting outside air temp. I tried the same values for CANSF as he did but no luck. Wondering if anyone else has tried this. It matches the Scangauge website.
    Ambient Air Temperature (F)
    07DF0146 04410546 2808 00090005FFD8
    AIR Degrees Fahrenheit
  9. Apr 28, 2010 at 7:34 AM
    Jeff3004x4
    Jeff3004x4 Well-Known Member
    Jeff
    East Killingly CT
    Timberland Mica
    Stock for now
    Scangauge is basically a scan tool, it reads sensors on your vehicle. Your vehicle would have to be equipped with a outside air temp sensor for scan gauge to read it. The Ambient Air Temp function on scan gauge is basically useless. If your vehicle had an outside air temp sensor, it would have a thermometer already. Why would anyone need their scan gauge to read the sensor to display the outside air temp on the scangauge when they already have a thermometer?
  10. Apr 28, 2010 at 7:51 AM
    swbimny
    swbimny Member
    San diego
    4X4
    With my access cab configuration the thermometer display was not an option to purchase. But learning from other posts, I found the temp sensor in front of the radiator by the horn and the wiring harness that goes to the display console above the mirror. Someone said the sensor was also used by A/C so it's needed even without having the display. Can't believe everything we read but just hopeful. Thanks for the reply
  11. Apr 28, 2010 at 7:51 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    If you have it set to read you intake temp you can use it to show the outside air temp first thing. I check mine before I head to work to see the temp every morning. Once u start driving it won't be accurate
  12. Aug 14, 2015 at 11:23 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    if the truck has A/C
    scangauge will work
    it is a matter of figuring out the codes for the xgauge for outside temp
    old Yaris codes don't work
    old and new prius codes don't work
    I haven't tried any others. any toyota with a/c has an outside temp
    sensor specifically for the a/c system and it sends temp to cansf bus.
    my yaris scanguage shows outside temp and I got the codes from a prius forum
    scangauge can pick anything up off this bus....but they keep changing
    stuff year to year and outside temp...could be any of 16 possible txd/rxd/mth combos
