SCANGAUGE USERS ATTN!!!!!!!!!!!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by reloader403, Mar 21, 2020.
  1. Mar 21, 2020 at 4:51 PM
    reloader403
    reloader403 [OP] Well-Known Member
    Acworth, GA
    2003 RC 2wd 2.4 auto
    I have been a huge fan and user of the scangauge 2 in my tacos, but over the last few days Ive noticed that it causes my gauges to bounce and lights to flicker across the dash and my radio to reset. I thought maybe my battery was weak, load tested fine. Checked connections and they were tight, no corrosion. It also caused my remote to stop unlocking and locking the truck, making funny beeps etc. Anyone else seen this? I had the sc2 set up to read TF1, TF2, MPG, Water Temp. I changed the mpg to current gear on the display and it slowed down the jumping needles on my gauges. Im not saying theyre all going to blow up and cause issues, just wanted to through this out there for others incase they start seeing it, they can unplug it.
    RushT likes this.
  2. Mar 21, 2020 at 5:04 PM
    reloader403
    Acworth, GA
    Throw **
  3. Mar 21, 2020 at 5:32 PM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    so your dash gauges don't show same symptoms if you disconnect the sg2 from the obd??? Send it back to SG for a fix or replacement.
  4. Mar 21, 2020 at 6:57 PM
    Tacoman97
    Tacoman97 Well-Known Member
    andrew
    new york
    2018 Calvary blue TRD PRO
    idk how long youve been running it but ive had it connected and reading TF1 EOT voltage and FPD (fuel pump duty ratio) because of the recall. and ive had no problems. had it in for about a month and a half now
  5. Mar 21, 2020 at 7:03 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    My Scangauge has been hooked up for six years I have never had any problems. Trans temp, Water Temp, MPG and Voltage.
  6. Mar 21, 2020 at 7:07 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Same.
    I have one in my Tundra and Tacoma. I forget how long. 2011 it so?
    TomTwo[QUOTED] likes this.
  7. Mar 21, 2020 at 8:45 PM
    reloader403
    Acworth, GA
    I've had this one hooked up for 3 years and on my 2nd gen for 5+. It's been sent back to get the software update prior to puting it in my 3rd gen.
    It's definitely causing issues that aren't explained with any other variable at this point. It's so weird driving around with out it. Feels like I'm driving around naked. I also had in a Jeep and a Tahoe for a while. Love the damn things but it's up to no good right now.
  8. Mar 21, 2020 at 8:54 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Sorta sounds like something inside it is shorting 12V to ground momentarily and maybe resetting the cluster/flickering lights/etc.
    Or maybe a bad cable.
    TomTwo likes this.
  9. Mar 21, 2020 at 8:56 PM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    What forum am I in?
  10. Mar 21, 2020 at 9:22 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Why do you even need it?
    Chew likes this.
  11. Mar 21, 2020 at 9:31 PM
    reloader403
    Acworth, GA
    Funny you ask, I tow a small 5x8 enclose trailer and a 19 foot camper pretty regularly. I liked knowing my trans temps but after almost 90k miles with that thing plugged in I've learned a few things, a big one being my trans temps have never been outside normal limits and I would constantly glance down and look at things like I'm driving a grenade. In short; I don't need it anymore , just letting anyone who cared to know, this thing is doing weird shit out of no where.
    hiPSI[QUOTED] likes this.
  12. Mar 21, 2020 at 9:37 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    It's likely has fretting damage on the OBD2 connector. These connectors were never designed to have stuff plugged into them long term.
  13. Mar 21, 2020 at 9:39 PM
    reloader403
    Acworth, GA
    Sounds plausible. I'm leaving it unplugged for a few tanks to see if it doesn't anything funky again. Like I said a moment ago, I probably won't use it for anything but scanning for codes if I cant use my scanner.
