Scangauge...Where is OBD2 port location?
Discussion in 'Performance and Tuning' started by TacoCo, Oct 1, 2008.
  1. Oct 1, 2008 at 7:36 AM
    TacoCo
    TacoCo [OP] Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    My friend is going to loan me his ScangaugeII just so I can check it out. Where exactly is the ODBII port to plug it into? Is it pretty easy to do?
  2. Oct 1, 2008 at 7:45 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    Under the dash in the area above where your left knee would be. There's a marked cover over it.
  3. Oct 1, 2008 at 7:49 AM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    When you look under where roland is talking about it says obdII pull the cap off kind of hard to see cause we are looking for an obvious port.
  4. Oct 1, 2008 at 8:01 AM
    TacoCo
    Colorado
    Found it... that's easy enough. Thanks guys.
    Though it raises another question... what is the "set" button below the steering column for???
  5. Oct 1, 2008 at 8:19 AM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    I think its to reset the tire pressure for tpms sensors.
  6. Oct 1, 2008 at 8:22 AM
    madmic
    madmic Member
    vancouver island
    3" revtek suspension lift
    excactly:)
  7. Oct 1, 2008 at 8:28 AM
    TacoCo
    Colorado
    Good to know. They didn't explain that one to me at the dealership. So, I was debating on whether the Scangauge would be worth the $160... I'm trying to weigh the pros and cons. I suppose that the information will be good for helping me adjust my driving habits to save gas, but the ability to read and reset error codes really seems like the main reason to get one in my mind... If it can save me from a couple of trips to the dealer to be hooked up to diagnostics when the check engine light comes on, it seems like it would pay for itself.
