Scangauge2 Settings
Discussion in '1st Gen. Tacomas (1995-2004)' started by ScottyB, Jul 6, 2010.
  1. Jul 6, 2010 at 6:41 PM
    ScottyB
    ScottyB [OP] Well-Known Member
    Scott
    Kailua, Hawaii
    01 PreRunner TRD V6
    Bilstein 5100's
    After looking for a good code checker on the forums I found a lot of praise for the Scangauge2. I recently ordered one and just received it. Setup sounded pretty simple so I followed the instructions and got it hooked up. However it does not get past the "connecting..." screen. I have heard that you can force it into certain modes to work with certain cars and I am wondering what modes you guys are using with your scangauges. I also have an email to the Scangauge guys and will try calling them tomorrow but I thought I'd try here as well.
    thanks,
    Scott
  2. Jul 6, 2010 at 9:26 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Did you try starting your truck? And when you hooked it up was the key on "acc"? I heard it has to be on "acc".
  3. Jul 6, 2010 at 11:36 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Unplug and plug it back in again.....
    There's really no mode to deal with. Atleast, not that I remember. Just plug & play.
  4. Jul 7, 2010 at 12:18 AM
    ScottyB
    Scott
    Kailua, Hawaii
    01 PreRunner TRD V6
    Bilstein 5100's
    I've tried at acc, on, and with the truck running and replugged it in several times and got the same thing every time: "connecting..."
  5. Jul 7, 2010 at 12:19 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    it takes a minute tho
  6. Jul 7, 2010 at 4:13 PM
    ScottyB
    Scott
    Kailua, Hawaii
    01 PreRunner TRD V6
    Bilstein 5100's
    Well something must be wrong with the connector or computer in the truck. Hooked it up to a 01 Highlander and a 97 Maxima and it fired right up with the readings and only was "connecting..." for a couple seconds.
  7. Jul 18, 2010 at 7:12 AM
    NormInOakley
    NormInOakley New Member
    California Delta
    stock PreRunner
    None
    Is the cigarette lighter fuse blown? Check that as the problem as the OBDII is powered from there! This is my first post, hope it helps!!
    N i O
  8. Jul 18, 2010 at 8:22 PM
    ScottyB
    Scott
    Kailua, Hawaii
    01 PreRunner TRD V6
    Bilstein 5100's
    Sadly it gets power, it just never connects.
    Welp, just got a replacement gauge so it's not the gauge :(
    Anyone want to check their OBD2 plug and tell me if theirs has got 4 wires? I'm not really sure what to do at this point. I've also tried 2 obd2 codecheckers and they don't work either. This is rather annoying because I'd like my check light to go away.
  9. Jul 20, 2010 at 5:58 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Yes - 4 wires would be the correct number leading to / from the DLC3 connector.
    My guess is a wiring fault in the white (data) line leading to the ECM, though I suppose a fault with either of the ground lines (white / black; brown) might also explain it.
    If the ScanGauge is powering up, then the power connection (violet wire to the 7.5A OBD fuse) appears to be fine.
  10. Jul 20, 2010 at 11:35 PM
    ScottyB
    Scott
    Kailua, Hawaii
    01 PreRunner TRD V6
    Bilstein 5100's
    Well I can stick my multimeter + into the violet and - into the ground lines and find out if they're grounded. If one doesn't work, then fixing it would be easy. I don't (yet) know where the ecu is on these trucks to worry about the data line. Never imagined I'd be trying to wire an obd2 connector.
