ScanGaugeII - 2016 Trans Fluid Temp Codes That WORK!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by damnfingers, Jun 15, 2016.
  1. Jun 15, 2016 at 3:08 PM
    damnfingers
    damnfingers [OP] Well-Known Member
    Gene
    Mississippi
    2016 Limited 2x4 DCSB
    SEE POST 12!
    Does anyone have workable codes for the Transmission Fluid Temperature on a 2016 Tacoma? I've tried all three on the ScanGauge site and I don't get a reading from any of them.
    Also, the water temperature is reading 198 at idle (haven't looked at it while driving yet since I'm still trying to figure out the ScanGauge) but it seems a lot higher than the water temperature on my 2012. It ran normally at 185, creeping up to 192 or so when I was towing my car trailer. Can anyone with a ScanGauge verify the 198 number?
    Thanks!
  2. Jun 15, 2016 at 3:15 PM
    Clearwater Bill
    Billy
    Largo Florida
    On the coolant temp, find out the t stat rating. I'll bet your '12 had a 180* and the '16 has a 190*. Hot is good for emissions.
  3. Jun 15, 2016 at 4:00 PM
    damnfingers
    Gene
    Mississippi
    Clearwater...probably right...have to check later.
  4. Jun 15, 2016 at 8:41 PM
    cctk2
    cctk2 GLACIERBIRD
    Chip
    NorCal and Alaska
    '68 FJ40, '16 TRD AC OR A/T WHITE
    Accessories: SnugTop Rebel canopy AVS Window Rain Deflectors TACOMA 6' Bed Mat Weathertech Mud Guards (4) Scanguage (re-installed from the '02) Tekonsha Voyager Brake controller (Chalet A frame pop-up.) Vinyl letter insets for tailgate. Garmin CS60 GPS mounting. Other misc décor in the form of decals.
    Mine shows 200 to 202 on an extended idle. The faster the engine runs the more air gets pulled through, depending of course on the load being pulled. Happy though that I have the little tool.
  5. Jun 15, 2016 at 8:46 PM
    damnfingers
    Gene
    Mississippi
    Thanks...took mine down the road this evening and it varied between 191 and 200. Any luck getting it to read the transmission fluid temps?
  6. Jun 15, 2016 at 8:51 PM
    cctk2
    cctk2 GLACIERBIRD
    Chip
    NorCal and Alaska
    Negative on the xmission temps. I even went so far as sending mine in to Linear Logic for upgrade, and to pursue the xmission temp desires. He gave me two possible codes, neither of which worked. As far as I know, either 1) Toyota will not release the codes, or 2) There is no sensor for there to be a code for.
    htgreen3 likes this.
  7. Jun 15, 2016 at 8:53 PM
    Bishop84
    Bishop84 Well-Known Member
    trans temps are often proprietary, I have a bluetooth easy diag that required license payment for me to read Toyota's trans temps when they are idling above me.
    The tech stream actually will show one trans temps but my easy diag shows two AT Temp 1/2 both are usually within 3 degrees of each other.
    There is another secret method that I never use.
    You jump pin CG and TC and bump the transmission back and forth from P to D until the D light illuminates, when its flashing its too hot.
  8. Jun 16, 2016 at 4:57 AM
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
    if I remember, Toyota usually tracks 2 temps for trans. 1 at the converter and 1 at the pan.
    that how it was on the 2012 Tacoma and 2014 4runner.
  9. Jun 16, 2016 at 7:27 AM
    damnfingers
    Gene
    Mississippi
    The codes for the 2nd Gen don't appear to work for the 3rd Gen transmission...and Bishop84's "secret" method is hard to do when you're pulling a trailer at 65 mph and start wondering about the transmission fluid temp :thumbsup:
  10. Jun 16, 2016 at 8:52 AM
    NoDak
    JR
    Minot, ND
    the pids for the new engine have not been found so right now its a guessing game. they didn't re use the old pids from the previous engine.
  11. Jun 16, 2016 at 8:53 AM
    cctk2
    cctk2 GLACIERBIRD
    Chip
    NorCal and Alaska
    Yeah, it would be great to have the codes for the scanguage
  12. Jun 16, 2016 at 11:05 AM
    damnfingers
    Gene
    Mississippi
    Okay!!!!! Got 'em - at least these transmission fluid temp codes worked for me this morning!!!
    :bananadance::bananadance::bananadance::bananadance::bananadance::bananadance::bananadance::bananadance::bananadance::bananadance::bananadance::bananadance::bananadance::bananadance:
    Gene,
    We are currently testing XGauge codes for the 2016 Toyota Tacoma as the ones listed on our website do not work. This is due to the new transmission installed in this model. We have had positive feedback from our customers regarding these codes. We have not listed these codes on our website yet as they are still in the testing phase.
    Please enter the following codes and let me know if they work.
    Transmission Temperature 1 (Degrees Fahrenheit)
    TXD: 0701221AAA
    RXF: C462051A36AA
    RXD: 3008
    MTH: 00090005FFD8
    NAM: TF1
    Transmission Temperature 2 (Degrees Fahrenheit)
    TXD: 0701221AC0
    RXF: C462051A36C0
    RXD: 3008
    MTH: 00090005FFD8
    NAM: TF2
    If you have any questions, please let me know.
    Regards,
    Cristina Bollinger
    Repairs and Technical Support
    Linear Logic
    1.888.433.5664
  13. Jun 16, 2016 at 11:11 AM
    cctk2
    cctk2 GLACIERBIRD
    Chip
    NorCal and Alaska
    Awesome. I'll plug them in when able, and report back. WTG
  14. Jun 16, 2016 at 11:39 AM
    usadaytrader
    usadaytrader Well-Known Member
    All this b/c a dipstick is missing. haha. Too many gizmos biting into my wallet.
    mojavejohn likes this.
  15. Jun 16, 2016 at 11:41 AM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
  16. Jun 16, 2016 at 11:45 AM
    damnfingers
    Gene
    Mississippi
    No, I need it because I tow a car trailer and I like to monitor the water and transmission fluid temps while I'm in the road. Still won't know if the level is correct but if it starts running hot it'll be a place to start looking.
    deergetr likes this.
  17. Jun 16, 2016 at 3:36 PM
    usadaytrader
    Yea sorry. I forgot about that. Id just use it for level checking
  18. Jun 16, 2016 at 3:39 PM
    Shellshock
    Iowa
    Just plugged these into mine and they seem to be working. Ive got some towing to do this weekend so the timing is perfect.
    Thanks!
  19. Jun 16, 2016 at 3:40 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    What temps are you getting?
  20. Jun 16, 2016 at 4:03 PM
    damnfingers
    Gene
    Mississippi
    I've only driven less than a mile but they started out about even at 118dF and one worked up to 157dF, the other to 164dF. I'm sure a longer run would generate higher temps but they are both lower than the water temp which quickly jumps into the 180+ range.
    Herniator likes this.
