ScangaugeII burning ignition fuse.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mvega1969, Jul 15, 2008.
  1. Jul 15, 2008 at 8:09 AM
    mvega1969
    mvega1969 [OP] Well-Known Member
    Laredo
    '17 Tacoma DC LB 4X4 TRD Off Road.
    This is for all the SCANGAUGEII users.
    Has anyone else had experienced a problem between the ScangaugeII and the Ignition fuse?
    My self, twice and I think I have found how to trigger it. (I will not do it again)
    Well these are the facts; once you turn off the engine the Scangauge will be on for several seconds and the turns off completely, but if you like to verify any gauge or trip values for several seconds (how much? I do not know) before it turns off start pushing the proper buttons to get your data or follow the complete "FILL-UP" procedure, then start your engine and try to shift... there is no way to do it. PROBLEM: The ignition fuse has been blown.
    With some experience in this (twice) it took me like 10 minutes to change it, but if there is no prior info or experience this means that you will need to be towed.
    Remember there are two spare fuses that can be used under the hood fuse panel. To replace the damaged fuse you will need to remove the panel under the staring wheel it is located at the middle of the secondary fuse panel.
    I hope this can be taken as a reference for any future incident.
  2. Jul 15, 2008 at 8:56 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    I've never heard of anyone having this happen before. :eek:
    I've been using my scanguage II since March and often (almost daily) check my trip data with the truck off. I also do the fill up procedure with the engine off before I leave the pump every time and havn't had any problems. The OBD port is always live and the scanguage draws what little power it needs from the port.
    I'd get in touch with the people at Scanguage and let them know what happened.
