scanguage 2 question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 05TRD4WD, Jul 18, 2009.
  1. Jul 18, 2009 at 5:43 PM
    05TRD4WD
    05TRD4WD [OP] Well-Known Member
    Taylor
    Chesapeake, VA
    05 TRD OFFROAD 4X4
    ; 17 x 9 xd revolvers wrapped in 295/70-R17, volant cold air intake, Gibson exhaust, BHLM, Yellow fog covers, access rollup tonneau, kenwood dnx-9960, all jl audio, jl stealth box, 900/5 amp, Fab Tech 6" lift
    hi
    i've been thinking about one and was wondering about the vehicle speed function and does it go off the speedo in the truck or does it go off of itself
    e.i. if the speedo in the truck was off from larger tires will the scangauge also be off
  2. Jul 18, 2009 at 6:06 PM
    gavonder
    gavonder She's Kickass!
    Ct
    08 TRD Sport Access Cab
    Sunroof, Leer Cap w/ Thule rack, Factory Running Boards, Fog Light Mod, Hood Struts, Scangauge, w/homemade mirror mount, AC/Defrost mod, Rear Spring TSB, TRD Center Caps
    It gets the signal from the computer, so I think it would be off if the tires are a different size.
    GA
    it actually reads more accurate than the speedo
  3. Jul 18, 2009 at 6:17 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    it reads the info from the computer, but you can input a percentage into the SG2 for your larger tires. It will then display the correct speed on the unit(not the factory speedo though, it'll still be off) and the trip functions on it will give you an accurate distance traveled as well.
  4. Jul 18, 2009 at 6:17 PM
    littledvl
    littledvl ride BMX!
    Eric
    Saint Leonard MD
    08 taco dc 4x4 / 15 tundra dc 4x4
    Too many to list
    Well I just installed the scangauge II today and its reading within 1-2mph off my speedo. according to my gps if im doing 65mph, my scangauge is reading 59, and my speedo is reading 60.
  5. Jul 18, 2009 at 6:19 PM
    05TRD4WD
    Taylor
    Chesapeake, VA
    05 TRD OFFROAD 4X4
    what is the percent you enter the percent larger height of the tire
  6. Jul 18, 2009 at 6:19 PM
    RDAY
    RDAY Well-Known Member
    NY
    07 Tacoma SR5 4x4
    ahh man i had a big misunderstanding on this i was about to order one i thought it would read ur correct spped on ur speedometer. what do i need for that because i don't want to be racking on extra miles with diffrent tires.
  7. Jul 18, 2009 at 6:24 PM
    RelentlessFab
    Eric
    Sparks, NV
    the stock tires are 30.5", and say you are running 33's, the you'd take 33/30.5= 1.08 which means you'd want to bump the reading by 8%.
    How would you be racking up extra miles on the odo? If you run larger tires, you'll travel slightly farther than the odometer would tell you so you'd actually get more warranty. :)
  8. Jul 18, 2009 at 6:26 PM
    05TRD4WD
    Taylor
    Chesapeake, VA
    05 TRD OFFROAD 4X4
    thanks
  9. Jul 18, 2009 at 6:29 PM
    RDAY
    NY
    07 Tacoma SR5 4x4
    oh my bad i had it backwards it would just be nice if it corrected the speedo as well
  10. Jul 18, 2009 at 6:38 PM
    05TRD4WD
    Taylor
    Chesapeake, VA
    05 TRD OFFROAD 4X4
    yea that would be nice
  11. Jul 19, 2009 at 4:52 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Changing the speedo on the dash and/or the data in the computer would require a change of whatever 'mechanicals' that reads the data and inputs it into the computer.
    For example - in Jeep Wranglers.... there's a gear inside the transfer case that is removable. Depending on your tire size & gears (in the diff), you need a different teeth count to make the speedo read correctly. The Jeep dealerships actually sell the different gears to install to correct the speedo.
    I have no idea how Toyota's work. Do some research...maybe someone has some ideas on how to mechanically change the input to the computer. Or maybe it can't be done at all. That's where the Scangauge comes in.....it's probably the best bet aside from buying an expensive programmer.
