Scanguage 2
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cleveland48, Feb 24, 2013.
  1. Feb 24, 2013 at 12:44 AM
    cleveland48
    cleveland48 [OP] Well-Known Member
    Andrew
    Belmont, Mississippi
    2012 TRD Off Road
    5100's set at 1.75, 1.5 in. AAL, 265/75/16 Cooper ST tires.
    I've noticed a lot of u are running these. How do u like them? Thinking about pulling the trigger on one. But will it disable the seatbelt warning on my 2012? I always wear my seatbelt on the road but checking my land at 5 mph I won't wear it cause I get I and out a lot. Any help would be appreciated guys
  2. Feb 24, 2013 at 12:57 AM
    DoorDing
    DoorDing Intentionally obtuse
    Bodie, CA
    2017 RC Off-Road 3.5WD
    yes
    The ScanGauge products are all pretty much passive scantools. Other than clearing DTCs, they don't affect the ECU. A dealership may be able to disable the seatbelt chime using techstream, the Toyota scantool. Whether they will of not seems to depend on the dealership.
  3. Feb 24, 2013 at 1:15 AM
    cleveland48
    Andrew
    2012 TRD Off Road
    Ok thanks. They read mpg and trans temp and other things like that right? It seems like it would be a good investment though. Doesn't most people really enjoy there's
  4. Feb 24, 2013 at 1:20 AM
    DoorDing
    Bodie, CA
    yes
    I think it's a handy tool, and I keep it in the truck. The SGs can read many different sensor outputs, and can calculate real time fuel economy. UltraGauge is another option, but I don't think it has as many functions.
  5. Feb 24, 2013 at 1:46 AM
    ROGU3 PR3DATOR
    ROGU3 PR3DATOR Space Shuttle Door Gunner
    Jake
    Niceville, Florida
    MGM 2011 TRD Off-Road
    Click my Sig Pic for my build thread. Too many to list here.
    I like mine. Use it mostly for real time fuel readings like MPG and estimated distance to empty. Haven't needed it for any engine codes, but I believe it will read and clear them as well.
  6. Feb 24, 2013 at 3:44 AM
    CantSitStill
    CantSitStill Well-Known Member
    FTR
    CNY
    Got mine used. Love it. Mostly for mpg. Has definitely adjusted my driving habits by knowing this.
  7. Feb 24, 2013 at 6:23 AM
    m32
    m32 Well-Known Member
    Edwin
    2013 DCSB TRD
    Another alternative is the ultragauge. Just got my ultragauge this weekend and like it so,far. I have to calibrate the mpg but its def worth the money IMO.
    Edwin
  8. Feb 24, 2013 at 6:57 AM
    cleveland48
    Andrew
    2012 TRD Off Road
    Ok guys thanks for all the info
  9. Feb 24, 2013 at 8:40 AM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    +1
    I think they look better too... they do the same as a scangauge and are priced way better.
    I'm pleased with mine.
    FYI, both units will not cancel out the seatbelt chime in a 2012+.
  10. Feb 24, 2013 at 8:49 AM
    DoorDing
    Bodie, CA
    yes
    I agree that the UG looks nicer, but I believe the SG can monitor some sensors that the UG can't, such as ATF temp.
  11. Feb 24, 2013 at 8:59 AM
    File IFR
    Central MA
  12. Feb 24, 2013 at 3:45 PM
    DoorDing
    Bodie, CA
    yes
    Thanks for the links, and same here. :thumbsup:
    I have no connection to SG and purchased mine long before the UG was available. I suspect SG will be forced to update their interface to remain competitive with the UG. The main point to remember is that if you want a specific readout, don't assume either one will provide it. Some vehicles may not have a sensor monitoring what you're after, or one gauge may not read an existing sensor's data. I'm just glad that these two products are on the market. I've had a DTC on a long trip and I really appreciated how easy it was to determine how serious the problem was, and to clear the CEL.
