Scanguage Tranny Temp code ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wiscdave, Apr 10, 2012.
  1. Apr 10, 2012 at 5:50 AM
    wiscdave
    wiscdave [OP] Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    For the Scanguage on 2005-2009 tacomas
    Transmission Fluid Temperature (Degrees F)
    TXD: 07E021D9
    RXF: 032180000000
    RXD: 2810
    MTH: 00070065FE70
    NAM: TFT
    How awesome, I totally missed that this came out. Way to go Scanguage!!
    Does this xguage feature represent Pan or Converter Temp? Which temp should I be more concerned about? If there is another please link or share - thanks in advance!
  2. Apr 10, 2012 at 6:17 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Nice...
    Now, it probably won't work on mine because I haven't upgraded the software since I bought it. :( But we'll see....
  3. Apr 10, 2012 at 6:41 AM
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    I hope it works on mine - it should if you have the xguage feature (gona plug it in at lunch) and see - not sure how to find out what verision I'm running its been awhile since I've messed with my scanguage. Very dependable and does what I need it to do everyday.
    Is this code Pan or converter and is the converter code available and work? Probably the better code to monitor right?
  4. Apr 10, 2012 at 7:32 AM
    mudthedoor
    mudthedoor Sconnie
    Alex
    Forestville, WI
    00 4Runner
    Does anyone know if ultra gauge suppprts this
  5. Apr 10, 2012 at 8:35 AM
    wiscdave
    Northern Wisconsin
    Tundra Rock Warrior
    Posted from another thread:
    2005-2009 I believe..
    The data is there for both sensors. One is the pan temp and one is the torque converter output temp. they are sent on the same address in different bytes. You may get it to work with the following:
    TXD: 07E021D9
    RXF: 032180000000
    RXD: 2810
    MTH: 00070065FE70
    NAM: TFT 1
    TXD: 07E021D9
    RXF: 032180000000
    RXD: 3810
    MTH: 00070065FE70
    NAM: TFT 2
    I hope the bottom one monitors Converter temp - that is what I want
