Scary drive this morning WTH PLEASE READ AND HELP
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rhowell, Jan 12, 2012.
  1. Jan 12, 2012 at 9:04 AM
    rhowell
    rhowell [OP] Well-Known Member
    Robert
    Canada
    08 Indigo TRD Sport 4x4 DCSB
    -Leather with Heated seats -AFE cold Air Intake -DE-jr Rims -Upper and Lower grills from Black Diamond Fabrication -Light bar behind grill -Hella Black Magic Rallye 1000 lights. -OME lift cw Dakar leafs -LR Upper control arms -Rosen duel DVD headrests -Nfab steps -leer canopy
    Ok, so I was driving to work this morning on the highway travelling around 60km/hr and accelerating when I noticed a really bad vibration that seemed to travel the same direction as the truck (front to back and back to front). You could actually see the passenger side seat rocking back and forth.
    I slowed down and it seemed to reduce the vibration. Then I came back up to highway speed and the truck vibrated really bad. In the rear view mirror it looked like the box was rocking back and forth. I googled a couple of things this morning and it appeared really damn close to what they call a 'death wobble'.
    Anyone else experience this.
  2. Jan 12, 2012 at 9:07 AM
    JayLeah
    JayLeah Well-Known Member
    Jessica
    New Orleans
    08 SR5
    Yeah, but in a jeep not ever a Tacoma.
  3. Jan 12, 2012 at 9:11 AM
    hellrazor004
    hellrazor004 Well-Known Member
    Rob
    09 DCSB
    Have you checked your lug nuts?
  4. Jan 12, 2012 at 9:12 AM
    foxmotox7
    foxmotox7 We'll see said the zen master
    Fox
    Goin where the wind don't blow so strange
    '05 TRD-OR
    aFe Pro Dry Filter; Weathertech Digital Fit Mats; BFG AT/TA KO 265-75-16; Weatherguard Black Saddle Box; Truxedo Tonneau Cover; DeeZee Bed Mat; AVH-4300DVD w/ SiriusXM, Backup Camera; AMP Moto X-Tender; Adventure Truck Tent
    I would start by getting under the truck and going over everything. Check your lug nuts and make sure they are all torqued properly. Look for play or any signs or damage in your front end. Check all four tires and make sure they aren't warped or bubbled. Beyond that, I'm at a loss. Could be any number of things. I wouldn't hesitate to get it to your mechanic and have a professional look it over. That is definitely not normal and doesn't sound safe to be driving. Good luck, keep us updated.
  5. Jan 12, 2012 at 9:16 AM
    Joe D
    Joe D .
    First thing I'd check is where the drive shaft attachs to the u joints. Make sure at each connection the hardware is tight. Also examine the u joints for tightness when trying to rotate.
    Beyond that I'd check out the wheels, tires & lug nuts.
    Let us know...
  6. Jan 12, 2012 at 9:16 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    X2
  7. Jan 12, 2012 at 9:23 AM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    could be anything..like what has already been suggested, look over the obvious stuff..bent or dented driveshaft, make sure all the lugnuts are there etc etc...
    maybe a rim is bent or even the wheel wieghts are missing from a wheel making the vibrations..too many variables to what can make the truck shake like that which makes it hard to diagnose over the internet
  8. Jan 12, 2012 at 9:24 AM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    I agree with the others on checking things. Generally speaking a vibrating mirror is from problems in the rear and a vibrating steering wheel is problems in the front.
  9. Jan 12, 2012 at 9:27 AM
    TMW
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Another thing to try is jack up the rear either use a floor jack on the differential or jack stands on each side and run it in gear and watch for vibration signs. Get your buddies to help, be carefull you don't want an accident.
  10. Jan 12, 2012 at 9:35 AM
    Rosesplus
    Rosesplus Well-Known Member
    Broken engine/gearbox mount?
  11. Jan 12, 2012 at 9:47 AM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    1. Check tires/wheels. (I'm betting it's a tire delam or wheel weight was thrown)
    2. Driveline
  12. Jan 12, 2012 at 9:50 AM
    Skycam3
    Skycam3 Waiting to see...
    Tony
    Nashville
    2012 Tacoma DCLB TRD Sport 4x4
    Flyzeye, Redline hood struts, Demello Sliders, Pelly wrap around light bar, Roll-N-Lock tonneau cover, 2 Hella 700FF, DIY LED light bar(10,000 lumes), LED bed lights.
    I had a GSXR that used to do this above 90 mph. Front tire was starting to separate.
  13. Jan 12, 2012 at 9:54 AM
    CalgaryRider
    CalgaryRider Well-Known Member
    Shayne
    Cranbrook, BC
    09 Access Cab SR5
    2009 Tacoma SR5 Too many to list, but its a SR5 with a TRD Sport Heart
    Have you had it in the shop recently? Maybe something wasnt torqued to spec?
    +1 on checking your lugs on your rims, and checking your tires for damage.
    I did have something similar and it was the rear pinion seal starting to go, but it never got that bad.
  14. Jan 12, 2012 at 9:57 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    I'd start by checking the lugs, u-bolts and drive shaft bolts/connections for play. Make sure none of the tires have bubbled or warped. Next could be a bent rim or you could have thrown a wheel weight (or strip of wheel weights). Did you recently have any work done on the truck? If so, I'd start by double checking that. If you can't determine what's causing it, I agree with others that a mechanic should have a look.
  15. Jan 12, 2012 at 10:01 AM
    silver taco
    silver taco Well-Known Member
    Los Angeles
    07 4X access cab
    Icon 2.5 ext travel, Camburg 1.25" uca's, All-pro leafs, Icon 2.5" rear shocks, LR jounce front and back, breather mod, KR Fab rear bumper, Kenwood 2m radio, All-Pro sliders, Front bumper by Surfinferno (Dylan), Glassworks fenders, 4:56 gears, gusseted spindles and coil buckets
    Make sure to keep us posted as to what you find.
  16. Jan 12, 2012 at 10:11 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    Check the carrier bearing on driveshaft.
  17. Jan 12, 2012 at 10:31 AM
    rhowell
    Robert
    Canada
    Stupid question. But what is the carrier bearing?
    I am going to swing into the tire shop and have them tighten the lugs on the way home. I will inspect the tires for any issues as well.
    I ordered the OME lift and new Dakars so I will be getting under the truck soon.
    This problem is not occuring often and it appears very random. Last time it happened was about 2-3 weeks ago but no where near as severe.
  18. Jan 12, 2012 at 10:39 AM
    buck
    buck Don't sweat the petty - pet the sweaty
    Ontario, Canada
    08 DC V6 4x4 TRD Indigo Ink
    High-flow coconut smiley-face air freshener.
    Could be anything! Start by inspecting wheels, drive shaft components, suspension.
    My random highway speed vibration ended up being a worn outer tie-rod.
  19. Jan 12, 2012 at 10:51 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    What ever you do don't try this.
    1. not a good idea to lift by the diff
    2. raise the rear in the air on jack stands, spin the rear wheels at highway speed until it vibes and jumps off the jack stands and launches into whatever might be in front of it.
  20. Jan 12, 2012 at 10:57 AM
    TACOMA TRD
    Tom
    PA
    You have a 2 piece driveshaft, its held in the center by a bearing which is held up by 2 bolts. One or both could have backed out. That would be violent enough to cause your issue
