Scary- gonna build my own sub into console
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mrburns05, Oct 30, 2013.
  1. Nov 2, 2013 at 9:02 PM
    manethon
    manethon TTAS
    Toronto
    Many
    why dont you guys use birch ply, its much better to work with and so much lighter.
    If you know what your doing and have the right products its so easy to have great sub stage. DC audio, Sundown audio both released CRAZY 8 inch subs that will most likely keep up with most 12s without a doubt and take 1000wrms with ease. There are also other companies for you guys that love the shallow mounted subs that you can do the same with. Another little tip, The rear bench backrest can actually be moved forward utilizing only one bolt instead of 2 and a spacer template used for the bottom to extend it forward by 2 inches to allow the seat bench bottom to still move up. This allows for much more room in behind the seat!
    Cheers
  2. Nov 2, 2013 at 9:38 PM
    mrburns05
    mrburns05 [OP] Well-Known Member
    Jake
    Menifee CA
    06 AccessCab SR5 L4
    None yet
    I'm down for using whatever. I got mdf because I've always just used whatever was laying around- usually particle board, which is terrible. I'm not a huge fan of mdf BUT--- I must say it was very easy to to reshape and hone bits of it as necessary using only a bit of sand paper- I DID like NOT having to get out a power sander and sawzall for that part
  3. Nov 3, 2013 at 7:59 PM
    mrburns05
    Jake
    Menifee CA
    06 AccessCab SR5 L4
    None yet
    So. I'm going to make a "step by step" picture tutorial in a downloadable form rather than try to do it in a post here. Apparently uploading pics and such on here isn't all that quick and easy from my phone haha.
  4. Nov 9, 2013 at 9:02 AM
    mrburns05
    Jake
    Menifee CA
    06 AccessCab SR5 L4
    None yet
    Ok, I've decided now that I've built one and mounted and studied the way it fits for a week, I'm gonna build another, it will have slightly more airspace, and angle the sub down a bit more to hopefully change the way it resonates throughout the cab.
    It could be mostly the sub and lack of decent head unit right now but the resonating frequency is too high for my taste
  5. Nov 9, 2013 at 9:55 AM
    ThatMattGuy
    ThatMattGuy Well-Known Member
    Matthew
    Baltimore, MD
    14 TRD Off-Road 4X4 AccessCab
    Could be wrong but to get rid of the high resonating freq's you could try angling it towards the floor more. The closer you get to downward the less highs you should hear from it.
    Out of curiosity what do you have you lpf tuned to?
  6. Nov 9, 2013 at 1:09 PM
    mrburns05
    Jake
    Menifee CA
    06 AccessCab SR5 L4
    None yet
    That's exactly what I'm doing - I'm re cutting a new box, with more of an angle on it to point the speaker downwards- the first box had it facing straight to the rear of cab :)
    The only lpf on it at the moment is the one built onto the amp, the lowest it goes is 32, I turned it up just a little past that. Once I get a new stereo I can have better control over that. For now I'm using EQ apps on my iphone to play music with a bit more precision
  7. Nov 9, 2013 at 5:33 PM
    ThatMattGuy
    Matthew
    Baltimore, MD
    32 is quite low, for a 10 you can go up to around 80-100 which is low and mid low (at least as far as I am concerned). I would stay below 100 though and closer to 80.
    The closer you can get it pointed to the floor the better. If you can get it facing straight down leave 2-3 inches for the sound to come out and plenty of room for the sub to flex.
    I have only done a couple custom enclosures myself (not in a truck without a back wall or room on the floor though) so I am not sure how best to tune it (freqs and where to point). Good luck with your build. I just put two infinity kappa 6x9's in the front door and 6.75 jl components in the rear door powered by a JL audio 400/4 amp (100 watts to each speaker) and the lows are sufficient for now, but I am pretty sure I will get greedy at some point and think about a sub.
  8. Nov 10, 2013 at 10:56 AM
    manethon
    manethon TTAS
    Toronto
    Many
    Double cab tacomas resonate around 55hz. No matter what box I used, tuned to my trucks res freq always remained 55hz
    Changing the angle of your sub from rear ward facing to downward facing will not change ur problem. Your sub plays the freq it's been told to play. Down firing will also reduce ur subs output quite a bit
    My advice, face rear wards, port the box tuned 33hz and you will be fine.
    There is nothing you can do to change the resonant freq of the trucks response ( in terms of box position) but changing the size of the box, sealed vs ported etc will change the response substantially
  9. Nov 10, 2013 at 11:50 AM
    mrburns05
    Jake
    Menifee CA
    06 AccessCab SR5 L4
    None yet
    Thanks guys! I did build another facing a bit more downward, it's about the same sound I guess but it does fit better this time.
    I can't port the box, it's concealed in my center console, but once I get an eq on it I can make it sound better. For now it's ok I guess
  10. Nov 10, 2013 at 1:49 PM
    manethon
    manethon TTAS
    Toronto
    Many
    try stuffing the box, it will help a little
  11. Nov 11, 2013 at 8:09 AM
    mrburns05
    Jake
    Menifee CA
    06 AccessCab SR5 L4
    None yet
    I wondered about that. I thought maybe I shouldn't because I'd lose airspace ? Suppose it can't hurt to try though.
  12. Nov 12, 2013 at 4:06 PM
    fritzthecat
    fritzthecat Well-Known Member
    Virginia Beach
    07 PreRunner Auto AccCab Indigo
    Here is my box:
    I used MDF. Removed the Inverter and used the brackets to bolt in the box. The top of the box becomes the floor for the center console.
    6.5in woofer. Can't remember who makes it.
    Fritz
  13. Nov 15, 2013 at 1:43 AM
    monstajp
    monstajp Well-Known Member
    joshua
    las vegas
    2011 trd sport debadged
    Debadged, Blacked Out Taillights and 3rd Brakelight , Blacked Out Grille, Blacked Out Lower Valence, Hot Wheels Badges, Yellow Fog Lights, Rims and Tires. Undercover Swing Case, Pop-A-Lock on my Tailgate, N-FAB Step Bars, Extang Trifecta Bed cover, Aero Cat- Back Exhaust, PIAA Extreme white 4000k Bulbs, Readylift 2.25 Leveling Kit.
    nice work.
  14. Nov 15, 2013 at 10:47 AM
    FrostyPower
    FrostyPower Well-Known Member
    Calgary, AB, Canada
    2014 DCLB Blue Ribbon
    Lift Kit - Toytec 3" Billstein full suspension lift Tires - 285/70R17 Goodyear Duratrac Rims - 17" 015 Black American Eagle Rims Nerf Bars - N-Fab Black nerf bars Painted Fender Flares - Bushwacker flares OEM skid plate
    Wow! Looks great!
