Scary noise and traction control light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Alament92, Mar 6, 2015.
  1. Mar 6, 2015 at 1:46 AM
    Alament92
    Alament92 [OP] Well-Known Member
    Austin
    Arizona
    2012 Tacoma TRD Sport
    HID's, Rancho quicklift, 295/75/16 Nitto Terra Grapplers, Method Race Wheels, K&N CAI, LED interior dome, map, license plate lights, 30 inch Avec LED light bar, Anti-dark hood lighting kit
    So I was driving around a tight freeway on ramp from one fw to another, and was going around 45-50mph, I started to feel/hear a loud clunking noise and my traction control light was flashing... I put rancho quicklifts and 295/75/16s on a few weeks ago, but no problems since. I never messed with any abs or traction control settings. Scared the he'll out of me, and I haven't had the problem since. Looked at the suspension and it looks like everything is intact and OK. Any ideas what could have caused it?
  2. Mar 6, 2015 at 5:34 AM
    Alament92
    Austin
    Arizona
    I was turning left. Seems like I hear the same noise when turning left over a speedbump but I always just thought it was my tires rubbing.. Looked under the fender well and I didn't see any marks of tire rub so now I'm beginning to think this may be the culprit too. Any ideas?
  3. Mar 6, 2015 at 5:41 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Sounds like your VSC kicked in.
  4. Mar 6, 2015 at 5:45 AM
    medic2230
    Murph
    Bama! Roll Tide
    You sure it wasn't the sound of the traction control doing it's thing? It makes a funky sound when it engages. Mine does this sometime when going around a entrance ramp kind of fast. The yawl sensor gets pushed enough to engage the traction control.
  5. Mar 6, 2015 at 5:47 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    If the traction control light (vsc) was blinking, then it was the traction control kicking in. After lifting it and going into turns it will be more finicky. I've had my vsc almost pull me off the road while driving 'spirited' into turns.
    Unkwn_Vibe likes this.
  6. Mar 6, 2015 at 5:48 AM
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    2023 Tundra Limited Crewmax 6.5' 4x4
    Yeah I hate the VSC and want to disable it.
  7. Mar 6, 2015 at 5:50 AM
    Alament92
    Austin
    Arizona
    Ah good to hear..scared the fffk out of me. Drove like a nun on the way to work this morning. I appreciate all the feedback guys.
  8. Mar 6, 2015 at 5:51 AM
    Alament92
    Austin
    Arizona
    And negative. Is that something I can do myself or does a shop need to?
  9. Mar 6, 2015 at 5:54 AM
    Alament92
    Austin
    Arizona
    Haha thanks man I appreciate it . Don't quite know my way around these front ends yet. Just gotter a few weeks ago
  10. Mar 6, 2015 at 7:34 AM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    why do people freak out when they 'hear noises' then make a new thread about it? its a machine, its going to make machine noises. there are some noises like VSC and Air pump that do not sound abnormal. they sound like any other ancillary system doing its job. yet we see ENDLESS threads on these things.
    if its a 'bad' noise it usually sounds like something 'bad'....
  11. Mar 6, 2015 at 7:59 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    This
  12. Mar 6, 2015 at 8:00 AM
    OZ-T
    Peter North
    British Columbia
    Have you had it happen to you ?
  13. Mar 6, 2015 at 8:16 AM
    Therealwinshady
    Therealwinshady Well-Known Member
    Shannon
    Portland(west linn), Or
    2011 DCLB TRD Sport
    5100's and 885's, AAL, fog light mod, map light mod, viper 5706, OR tow hook, inverter anytime mod, Firestone air bags, devil horns, hood scoop riged light bar, 32 inch bumper light bar,
    Mine does it only on right hand turns, you get used to it after a while and once your tires wear down it becomes less frequent.
  14. Mar 6, 2015 at 8:22 AM
    B737
    Kevin
    Jersey Shore
    stock
    yes
    in more than one model. they all sound the same.
  15. Mar 6, 2015 at 8:34 AM
    moondeath
    Pa, Gardners
    Have you had it pull you off the road when going into a turn?
  16. Mar 6, 2015 at 8:35 AM
    Boone
    Boone, NC
    Airbags deployed
    This^^^^^^^^
    Or into the oncoming lane in a blind curve?
  17. Mar 6, 2015 at 8:47 AM
    OZ-T
    Peter North
    British Columbia
    Like ABS ?
  18. Mar 6, 2015 at 9:08 AM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    You can disable it. Hold the trac button for 5 seconds when you first start your truck before you go anywhere.
    BTW I've had VSC keep me on the road in a sever maneuver. So don't underestimate it's importance. The problem is when it deploys in a situation when you are intentionally trying to induce a near skid condition.
  19. Mar 6, 2015 at 9:10 AM
    B737
    Kevin
    Jersey Shore
    stock
    no.
    it makes noises, and functions like any other system functions. with that comes sounds. they are normal.
    its not rocket science.
  20. Mar 6, 2015 at 9:14 AM
    OZ-T
    Peter North
    British Columbia
    When traction control engages , it pulses the brake pedal like ABS and growls the same and if you are cornering when it happens it can indeed push you into understeer
    Have you had that happen ?
