Scary? Short U Bolts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by D Soulman, Aug 19, 2018.
  1. Aug 19, 2018 at 3:52 PM
    D Soulman
    D Soulman [OP] Well-Known Member
    Dan
    Fargo, North Dakota
    So I installed a shim from Toytec today and discovered that the existing U bolts are a bit short. I have ordered longer ones but need to drive this as is until I get them and install them. Anyone think this is really scary to drive around the street?
    Thanks, Dan.
  2. Aug 19, 2018 at 3:55 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    You’re gonna want at least a thread or two past. I install bolts backwards and go swaybarless. I wouldn’t let this go though.
  3. Aug 19, 2018 at 4:01 PM
    FuzzysTacos
    FuzzysTacos Well-Known Member
    Corey
    Wichita, KS
    Sold: 2017 TRD OR/2012 TRD Sport
    You're supposed to torque and then recheck torque after driving X, but you may not get that second opportunity if you lose them. If you're asking, you know its sketchy. Do what you're comfortable with. Don't drive, don't drive far, or pull the shims in the meantime. I imagine you're talking the angled one to correct the drive line?
    Tango Bravo, Gunshot-6A and TomTwo like this.
  4. Aug 19, 2018 at 4:02 PM
    DrFunker
    DrFunker Well-Known Member
    I'd be extremely cautious running that.
  5. Aug 19, 2018 at 4:04 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Thread engagement + proper torque is fastener strength 101. You have neither. Good luck.
  6. Aug 19, 2018 at 4:08 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    It’s going to be this all over again:
    Don’t do it. Those bolts loosen a significant amount in the first couple days.
  7. Aug 19, 2018 at 4:09 PM
    DrFunker
  8. Aug 19, 2018 at 4:09 PM
    DrFunker
    :laugh:
    :fistbump:
  9. Aug 19, 2018 at 4:11 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
  10. Aug 19, 2018 at 4:25 PM
    Wsteven
    Wsteven Well-Known Member
    2018 Tacoma TRD Pro
    Working on them
    You might really want to exercise extreme care with that - always run 1.5 times the diameter of the bolt in threaded holes or thru the Nut part of the reason is the starting threads on a bolt are not always fully formed.
    bv8ma and tacotech72 like this.
  11. Aug 19, 2018 at 5:07 PM
    D Soulman
    Dan
    Fargo, North Dakota
    What would make you think that? I torqued them to 75 Lb Ft, drove to the grocery store, and re-torqued them again. As I said, I have already ordered longer replacements, just driving to work and back in the mean time. I'm actually not terribly worried, but I do appreciate the input. Thanks guys!
  12. Aug 19, 2018 at 5:10 PM
    D Soulman
    Dan
    Fargo, North Dakota
    That makes sense too. Thank you.
  13. Aug 19, 2018 at 5:10 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Fuuuuck that noise. I wouldn't drive that. I'd pull the shims in a heartbeat.
  14. Aug 19, 2018 at 5:14 PM
    Stocklocker
    17TRDORDCSBAT
    Might want to avoid any potholes. In my opinion, that’s still super janky. If your axle comes off, hopefully it’s not on the interstate with a busload of lawyers behind you taking their kids to bible camp.
  15. Aug 19, 2018 at 5:19 PM
    goldentaco03
    goldentaco03 Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    I don’t understand why people continuously push the limits of the nuts and bolts. I just worked in a fastener plant as a mechanical/fastener engineer and having the correct thread engagement along with the proper torque ARE the two most crucial things. A fasteners strength is based on full thread engagement. The end of a bolt has roughly 1-2, sometimes more, partial threads (not fully filled out due to runout on the die or the machine). These 1-2 threads are useless, they won’t be engaging the nut at all. Since the end of the bolt isn’t even protruding past the nut I would say that’s there not more than 2 full threads engaged. I’d say u-bolt nuts have around 4-6 full threads in them depending on the size and the truck.
    If you’re only at 2 full threads you’re looking at half of the necessary strength or less. If you were to over torque in order to compensate for the lack of length you’ll end up stripping the threads. In most fasteners this size the threads are what fail first and that is considered and “ideal failure”. Just my two cents. In my opinion don’t drive it, could just take one wrong turn or pothole for something to go wrong.
    TacoCat, Dravnx, CanisLupus and 6 others like this.
  16. Aug 19, 2018 at 5:47 PM
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    I would not run like that, there are two exposed threads on the nut that's most visible. Basically the bolt is unable to seat correctly in that nut and leaves the risk of play and wallowing. Couple that with the stress that u-bolt encounters you are running a real risk of loosing those nuts. I personally would recommend that you can see at least 2, preferably 3-4+ threads of bolt past the end of the nut, that allows you some extra room if anything comes loose. Where you're at now, if it came loose you wouldn't have any threads to run down before the bolts came off.
  17. Aug 19, 2018 at 5:54 PM
    OrangeJulius
    OrangeJulius Well-Known Member
    2017 Orange TRD off-road WIP
    How big is the spacer? I did an add a leaf and still had plenty of thread left all around.
    roguegs likes this.
  18. Aug 19, 2018 at 6:00 PM
    -40
    -40 Well-Known Member
    North Dakota
    01 DC Camburg LT & 17 OR OME BP-51
    1 st Gen TRD Supercharger. URD 7th Inj. Camburg 4x4 LT Kit. Tundra Brakes. 3rd Gen just get’n started, OME BP51 Dakar HD, Camburg UCA & various armor.
    And we wonder why insurance premiums are so high. Did you use extra extra Loc Tite ?
    Can you imagine the OP as exhibit A at the trial...
  19. Aug 20, 2018 at 6:31 AM
    D Soulman
    Dan
    Fargo, North Dakota
    Yes I have considered removing those very thick washers too. I understand the concern to a degree, but as stated, I have torqued then to spec- twice. My drive to work is about 2 miles on a deserted 25 mph road. I think I’m going to drive it for two more days until my new bolts arrive. OR, maybe check into some from Napa, etc and swap them sooner
    Running Board Man likes this.
  20. Aug 20, 2018 at 6:36 AM
    D Soulman
    Dan
    Fargo, North Dakota
    Napa is no help. Where would I find the specs for U bolts- diameter and stock length?
