Scary? Short U Bolts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by D Soulman, Aug 19, 2018.
  1. Aug 20, 2018 at 6:43 AM
    Masterofnone
    Masterofnone 140.85
    Bobby
    Kansas
    2017 TRD Sport AC MT
    Are the washers behind the bolts lock washers?
    If so (and I am going to ruffle some feathers) I wouldn't take it on any cross country road trips, but I'd think you'd be okay for a few days or so.
    I hate auto parts stores. When I'm buying from them I always bring in what I need and say "this." Take one of the bolts to them and say "little longer please."
  2. Aug 20, 2018 at 6:45 AM
    TailHook
    TailHook If You’re Good At Something, Never Do It For Free
    Alan
    Southern UT
    2018 TRDOR 4X4, 2007 Sequoia 4X4
    FYI, factory service manual torque spec for the 3G is 52 lb/ft...
    roguegs likes this.
  3. Aug 20, 2018 at 6:47 AM
    bv8ma
    bv8ma Well-Known Member
    Bill
    MA
    2017 TRD OR
    Why not remove the shims and run without those for 2 days? I'd much rather do that than run on the u-bolts with that little thread engagement.
    MFTAF13 and TacoCat like this.
  4. Aug 20, 2018 at 6:48 AM
    goldentaco03
    goldentaco03 Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    You’re best bet would be to find another truck with a similar sized and shape ubolt that is actually a bit longer. Check the Chevy ford etc... light duty trucks
    Or take a look on McMaster Carr they might have something that’s pretty close.
  5. Aug 20, 2018 at 7:04 AM
    Mountain Minstrel
    Mountain Minstrel Well-Known Member
    Prather, CA
    '17 DCSB MT INFERNO
    OP, why ask for peoples opinions if your going to argue with every one who you don't agree with?
    Skydvrr, Hobbs, cruetes and 6 others like this.
  6. Aug 20, 2018 at 7:12 AM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Just because you torqued them twice where they are does not mean they are good to go. The first couple of threads on a bolt are not true, meaning you are not getting full contact with the inside of the nut. You have now stretched those threads and vibration will allow them to become loose.
    If its only two miles to work I think I would walk that or ride a bicycle for the next two days, but you do what you feel is best for your safety.
    Lawfarin, CanisLupus and elduder like this.
  7. Aug 20, 2018 at 7:13 AM
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    This.
    Removing the washers will allow for more thread engagement. It will also remove the washer that crushes and conforms to the mounting surface, the nut will not do this. You get more threads in the nut providing more stability and you get less stability by removing the washer allowing it to mount with some minor variation in angle.
    Also, some other things mentioned, not bashing anyone, loctite will help keep the nut from rotating but not if its exposed to large amounts of stress on only a couple threads. Torquing to spec is good but again using two or three threads on the nut doesnt provide the same holding force as using or having threads on both sides. The tension is maintained over a smaller area and may not be maintained evenly.
  8. Aug 20, 2018 at 7:49 AM
    TexasTacoLT
    TexasTacoLT Well-Known Member
    Killeen, TX
    '14 TRD Offroad
    3" Lift (ToyTech Coilovers and AAL) Bilstein 5100 Shocks Total Chaos UCAs Method Double Standard 17" BFG All-Terrain T/A KO2 (Removed) 33" BFG Mud Terrain Tires Colormatched Grill surround HomerTaco mesh grill insert Legacy "Toyota" Emblem Shrockworks plate rear bumper All-Pro plate front bumper w/ foglights All-Pro rock sliders Smoked Tail-lights DIY Steel Tailgate reinforcement Locking Tailgate handle Tint (15%) w/ sunstrip Tyger Tonneau cover (Removed) Bestop Soft Topper Bushwhacker colormatched fender flares DIY 8-ball shift knob DIY Amber LED grill lights DIY Debadged WeatherTech floormats Sudued US Flag door decals T-100 style tailgate decal Two way radio w/ 3' whip antenna Warn 8000lb winch CalTrend Neoprene seat covers DIY Bed tie-down anchors
    To answer your question. No, I do not think this is scary, I think this is reckless. Not only are you putting yourself and your truck at risk, you're potentially putting others at risk. If you have to drive your truck on a public road, until you can properly install the shims, don't run with them on. Simple. This is not safe, you seem to already know that.
    Lawfarin, Riding Dirty and TacoCat like this.
  9. Aug 20, 2018 at 8:22 AM
    D Soulman
    D Soulman [OP] Well-Known Member
    Dan
    Fargo, North Dakota
    How am I arguing with anyone? I have added some facts that I thought were pertinent (torqued them twice- now I understand I may have used the wrong torque value but there is a loooong thread on that which I am going through). Also clarified that my drive to work is very low stress- not rough roads or stop and go city traffic or interstate. As stated earlier, I appreciate the input and it’s why I posted up.
  10. Aug 20, 2018 at 8:25 AM
    Mountain Minstrel
    Prather, CA
    '17 DCSB MT INFERNO
    sigh...
  11. Aug 20, 2018 at 8:26 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    You are ok for now, for the street. Blue locktite will give you some peace of mind. Replace them with some immediacy, don't let it go.
    Running Board Man likes this.
  12. Aug 20, 2018 at 8:26 AM
    ZYBORG
    ZYBORG Let's roll...
    TX / S. FL
    3G TRD OR
    A little axle hop never hurt nobody!
  13. Aug 20, 2018 at 8:28 AM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    You're really not getting proper torque out of those no matter how many times you say you've torqued them. You don't even half half thread engagement in those nuts. I wouldn't even run that if the bolts were even with the face of the nut, and you've got even less than that.
    If you don't want input or people telling you it's not safe, don't make the thread.
    Pella, TacoCat and daddy_o like this.
  14. Aug 20, 2018 at 8:29 AM
    Pella
    Pella Well-Known Member
    Pella
    209
    SSMDCSBORFTMFW
    You have stretched the hell out of those bolts. You shouldn’t even really be reusing them in the first place, not to mention you don’t have enough threads.
    roguegs, daddy_o and DrFunker like this.
  15. Aug 20, 2018 at 8:29 AM
    #35
    ZYBORG
    TX / S. FL
    3G TRD OR
    Endo for the win!
    Pella likes this.
  16. Aug 20, 2018 at 8:34 AM
    #36
    elduder
    Van WA
    Agreed. OP is going to get a bunch of opinions, most non professional, meaning they don't get paid for mechanical work. I do get paid for this, which doesn't mean my opinion is the only one that matters, but I hope it would mean something. I wouldn't leave a nut threaded like this on any moving part, or any part either. Simply because I wouldn't want the responsibility for failure, which in this case will happen eventually. I'm simply saying don't run it from the point of view that as a mechanic something like this will eventually fail, the risk could potentially total the truck, and from personal experience of seeing moving part failures linked to improper mounting and fastening.
  17. Aug 20, 2018 at 8:34 AM
    #37
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    This!
    And not that OP is necessarily arguing, but isn’t listening to the legitimate points being made. He just wanted validation for his poor decision.
    Hobbs, tcjacado, CanisLupus and 2 others like this.
  18. Aug 20, 2018 at 8:38 AM
    #38
    bv8ma
    Bill
    MA
    2017 TRD OR
    But why not just remove the shim and know you are safe, it's only a couple days and the u-bolts are being replaced anyways. I just don't understand why you would even take the risk when you have an easy solution.
    goldentaco03, TexasTacoLT and Pella like this.
  19. Aug 20, 2018 at 9:37 AM
    #39
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    U are OK like this, just add some zip ties and duct tape.
    tcjacado, DrFunker and EatSleepTacos like this.
  20. Aug 20, 2018 at 9:42 AM
    #40
    D Soulman
    Dan
    Fargo, North Dakota
    LOL, true story. Thanks everyone!
