SCBS Daria don't respond to wrong thread, thread.
Discussion in 'South East' started by Sandman614, Feb 25, 2013.
Thread Status:
Not open for further replies.
  1. Aug 26, 2015 at 8:54 AM
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    How much of spacer do you want.. mine is 10mm.. its all for sale
  2. Aug 26, 2015 at 8:55 AM
    ahspurlock
    ahspurlock The TW Mechanic
    Adam
    summerville.south Carolina
    08 T4R V8 Limited AWD on 37s
    Rear full long travel including upper and lower rear control arms. 37s Mickey Thompson Baja boss MT,
    thats about what im looking for
  3. Aug 26, 2015 at 8:58 AM
    Jeffvt0508
    Jeff
    Anderson, SC
    Did you really enjoy it?
  4. Aug 26, 2015 at 9:02 AM
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
    After I really broke in my Dakars and added all the weight from my bumper and tire carrier they ride fucking sweet
  5. Aug 26, 2015 at 9:02 AM
    Jeffvt0508
    Jeff
    Anderson, SC
    Yea I just didn't want to stress out my uppers and lowers as much as I did in my prerunner.. although I had 4.5 inches of lift on 885x
  6. Aug 26, 2015 at 9:05 AM
    Boogyman
    Phoenix
    Corpus Christi, TX
    What shocks did you run
  7. Aug 26, 2015 at 9:08 AM
    3milecreek
    3milecreek MtnGoat
    Stephen
    Barnwell SC
    Heavily Modified 94 Yota
    Never the same
    Mmmmmm
  8. Aug 26, 2015 at 9:08 AM
    ahspurlock
    Adam
    hey boogyman where you been hiding at
  9. Aug 26, 2015 at 9:08 AM
    Boogyman
    Phoenix
    Corpus Christi, TX
    Your closet
    ahspurlock[QUOTED] likes this.
  10. Aug 26, 2015 at 9:10 AM
    ahspurlock
    Adam
    lol
  11. Aug 26, 2015 at 9:12 AM
    Jeffvt0508
    Jeff
    Anderson, SC
    Anyone know if you can run billies with the trim packer I'm not using ome shocks since its a fifty fifty chance they wouldn't fit
  12. Aug 26, 2015 at 9:12 AM
    Boogyman
    Phoenix
    Corpus Christi, TX
    Doesn't fit. I read that awhile back when I was looking to do the same thing. You'll have to run top plate spacers
    Sandman614[OP] likes this.
  13. Aug 26, 2015 at 9:17 AM
    Jeffvt0508
    Jeff
    Anderson, SC
    Thanks... Trim packer was 5mm right.?
  14. Aug 26, 2015 at 9:19 AM
    Boogyman
    Phoenix
    Corpus Christi, TX
    Not sure. If your trying to counteract taco lean get the 1/4in top plate spacer
  15. Aug 26, 2015 at 9:22 AM
    ahspurlock
    Adam
    @Sctacoma4x4 your 10mm top plates will work what you want for them
  16. Aug 26, 2015 at 10:02 AM
    Jeffvt0508
    Jeff
    Anderson, SC
    Probably going to use ome shocks... Just got off phone with Marie at headstrong... She said if I went with billies I would have to pair with 6100 the extended shocks and extended brake lines as well as bump stops... So thinking that cutting the shock mount to fit ome is easier
  17. Aug 26, 2015 at 10:04 AM
    Jeffvt0508
    Jeff
    Anderson, SC
    If you want my top plate spacers you can have them... Also have top plate extended studs
    ahspurlock likes this.
  18. Aug 26, 2015 at 10:18 AM
    Jeffvt0508
    Jeff
    Anderson, SC
    So pretty much 884x if you don't want diff drop bracket ...885x recommend it
  19. Aug 26, 2015 at 10:28 AM
    ahspurlock
    Adam
    ok but remember im a prerunner so ok give price on every thing
  20. Aug 26, 2015 at 10:39 AM
    Hard Luck GraphiX
    Hard Luck GraphiX Well-Known Member
    Josh
    VA
    22 TRD Offroad
    Went to install my new tires & wheels only to find out they didn't send me enough lug nuts & then when I removed my rear tire noticed a really nice crack down through the middle of my lift block .
Thread Status:
