SCBS Daria don't respond to wrong thread, thread.
Discussion in 'South East' started by Sandman614, Feb 25, 2013.
Thread Status:
Not open for further replies.
  1. Jan 11, 2016 at 6:41 AM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Just giving you and @scottalot a hard time.
    scottalot and Acerwin[QUOTED] like this.
  2. Jan 11, 2016 at 6:41 AM
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Oh I know haha
  3. Jan 11, 2016 at 6:42 AM
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    You still going to hook up your blue sea?
    scottalot[QUOTED] likes this.
  4. Jan 11, 2016 at 6:45 AM
    jpneely
    jpneely Well-Known Member
    Charleston, SC
    2005 Land Cruiser, 2017 Land Cruiser
  5. Jan 11, 2016 at 6:48 AM
    jpneely
    Charleston, SC
    yep I was thinking there has to be a caulk filler that has a granite coloration /texture. they use it to caulk the edges of countertops right?
  6. Jan 11, 2016 at 6:49 AM
    TownvilleTim
    TownvilleTim Well-Known Member
    Tim
    Townville, SC
    07 ACLB SR5 2.7L 2015 DCSB SR5 V6 4x4
    TRD Pro Suspension, SOS sliders, SR8 Wheels, Duratracs, ARE shell
    That's a good one. I wonder why there's so much difference.
  7. Jan 11, 2016 at 6:49 AM
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    I have no clue on this stuff haha I always have these type questions myself
  8. Jan 11, 2016 at 6:50 AM
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Did you get your led pods to work right?
  9. Jan 11, 2016 at 6:58 AM
    864_scott
    864_scott Active Member
    Scott
    South Carolina
    2011 Tacoma 4x4 3''lift
    @Matic wasnt me I was still asleep but I do head that way normally for work
    Matic and scottalot like this.
  10. Jan 11, 2016 at 7:07 AM
    ahspurlock
    ahspurlock The TW Mechanic
    Adam
    summerville.south Carolina
    08 T4R V8 Limited AWD
    Front long travel and Rear long travel including upper and lower rear control arms. Running 456 gears with rear ARB locker . LFD full roof rack with clamshell RTT
    hey @Matic did you say you had some 10mm you were going to sell :popcorn:
    scottalot likes this.
  11. Jan 11, 2016 at 7:10 AM
    Acerwin
    Andrew
    South Carolina
    Toyota Tundra
    Sweet I lost that damn thing again if you have it I would gratefully appreciate it so I can order some :frusty:
    scottalot[QUOTED] and ahspurlock like this.
  12. Jan 11, 2016 at 7:24 AM
    jpneely
    Charleston, SC
    A couple of weeks ago I was driving down a forest service road and when I hit rougher patches, I could hear a thumping that I would normally attribute to some sort of bushing starting to go on me. it only happened 4 or 5 times that trip and since then I haven't heard it. it was driver side front and when I got out and looked around in there, I couldn't see anything obvious at all. steering isn't loose, theres not steering wheel vibes, it was just a noise I could hear and feel through the floorboards. it was a clearly audible "thump". any ideas on what I should be looking at? ive never messed with suspensions at all.
  13. Jan 11, 2016 at 7:28 AM
    Hard Luck GraphiX
    Hard Luck GraphiX Well-Known Member
    Josh
    VA
    22 TRD Offroad
    Let me know if you figure it out it sounds like the same thump I have in my front end but on the passenger side & can't find anything .
  14. Jan 11, 2016 at 7:29 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
  15. Jan 11, 2016 at 7:40 AM
    Sandman614
    Tim
    '06 SR5 Off Road
  16. Jan 11, 2016 at 7:40 AM
    SC2SC
    SC2SC Likes Pineapple on Pizza
    Jonathan
    South of Charlotte
    2014 DCSB MGM TRD OR 4X4
    Icon Custom Build Custom Exhaust • SOS Sliders• RokBlokz
    This could be a solution- if structural.
    Thank you! Unfortunately, I have a drop in "cooktop". I literally have a square hole in a granite counter top. Needs to support the entire weight.
    I wish I had a normal stove top/range!
    I wish this was my problem. o_O
    House came with a downdraft drop in cooktop- I am very limited. Nothing current fits- they all have smaller cutout requirements- even though they are all 30" cooktops. :mad:
    Me too! :p
    Just called a custom metal filler company- but they said its all non structural- only for appearance to even out slight cutout variations. :annoyed: I am screwed. I may end up having to reconfigure the base cabinet/cut granite for a slide in range oven or replace the granite with new cutout size- which could also lead to having to replace all my base cabinets. :frusty:
    Thanks for responses-
  17. Jan 11, 2016 at 7:44 AM
    jpneely
    Charleston, SC
    I have just over 83k on her. when I heard the noise I was thinking, well damn its about time something wore the fuck out! been a solid truck so far.
  18. Jan 11, 2016 at 7:48 AM
    TownvilleTim
    Tim
    Townville, SC
    We had a drop in oven/cooktop. When we went to replace it they were so much more expensive than the floor standing ones. We were doing new counter tops, so I put it the floor model instead. I take it yours is just the cooktop?
  19. Jan 11, 2016 at 7:49 AM
    jpneely
    Charleston, SC
    yea I just figured I would see a boot or bushing worn or dry rotted or wear marks on metal somewhere. anything out of the ordinary really. but nope. and I realllllllllllly don't want to take it anywhere and pay unneeded money for someone to look at the same shit ive already looked at and just say yea, your dohickeys look a little worn lets replace all these whatchamajjiggers and see if that solves the problem
  20. Jan 11, 2016 at 7:52 AM
    SC2SC
    Jonathan
    South of Charlotte
    Yes. Changing to a slide in may even effect flooring. Need to have a down draft too. All my appliances have failed inside of 10 years from my new construction home. Whirlpool Gold that builder used. I never even liked the stupid cooktop, lol!
Thread Status:
