SCBS Daria don't respond to wrong thread, thread.
Discussion in 'South East' started by Sandman614, Feb 25, 2013.
Thread Status:
Not open for further replies.
  1. Feb 3, 2016 at 11:24 AM
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    [QUOTE="Boogyman, post: 11685268, member: 84975"It's late. I'm tired. But my lighting is perfect. Redid my floor board lighting that fades on/off with the dome. Wired my pods to a real harness and to an led halo switch that dims with the dash lights and wired up my led projector corner lights and put my halos on their own switch and cleaned up my retrofit wiring[/QUOTE]
    Could you help me wiring to the dome light? I want to hook rock lights and my map lights to the key fob. I am a wiring novice and would like to do this correct the first time.
    ahspurlock likes this.
  2. Feb 3, 2016 at 11:25 AM
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
    Could you help me wiring to the dome light? I want to hook rock lights and my map lights to the key fob. I am a wiring novice and would like to do this correct the first time.[/QUOTE]
    Are you local?
  3. Feb 3, 2016 at 11:42 AM
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    Are you local?[/QUOTE]
    No sir. Just did a search and found you post.
  4. Feb 3, 2016 at 11:52 AM
    Boogyman
    Phoenix
    Corpus Christi, TX
    No sir. Just did a search and found you post.[/QUOTE]
    Ah gotcha. I've got under dash lights hooked up to the dome. I know there's a write up on here on how to wire your map lights to your dome but for everything else run your positive and negative to the dome light and run the leads through the headliner and down the a pillar then wire the rock lights to those leads and then run a second positive and negative. Negative to a switch and positive to constant
  5. Feb 3, 2016 at 8:48 PM
    EODwick
    EODwick Fire In The Hole!
    Ed
    Box Elder, SD
    2013 TRD Sport
    Stuff I Think Makes it Better
  6. Feb 3, 2016 at 8:48 PM
    Boogyman
    Phoenix
    Corpus Christi, TX
    We have 2 threads now but glad your back!
  7. Feb 3, 2016 at 8:53 PM
    EODwick
    Ed
    Box Elder, SD
    2013 TRD Sport
    2 threads? Jesus is hard to keep up with one
    ahspurlock and NeedmoreTaco like this.
  8. Feb 4, 2016 at 3:18 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Morning. Happy Thursday!!:oldglory::jellydance::kona::drunk::burnrubber::bananadance:
  9. Feb 5, 2016 at 12:53 PM
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    Ordered a used transmission last night. Ill order the clutch kit this week. I'm chomping at the bit to put an FJ case and crawl box in ASAP. Need a complete overhaul of my suspension as well. Too bad it won't all be done before Gulches
    TownvilleTim, Acerwin and ahspurlock like this.
  10. Feb 5, 2016 at 12:54 PM
    ahspurlock
    ahspurlock The TW Mechanic
    Adam
    summerville.south Carolina
    08 T4R V8 Limited AWD on 37s
    Rear full long travel including upper and lower rear control arms. 37s Mickey Thompson Baja boss MT,
    about damn time :rofl:
    3milecreek likes this.
  11. Feb 5, 2016 at 1:11 PM
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    You have a 4x4 yet?
    Didn't think so. Now ease up off my nuts. :cool:
  12. Feb 5, 2016 at 1:19 PM
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    Gottem
  13. Feb 5, 2016 at 1:21 PM
    ahspurlock
    Adam
    :rofl:
    Acerwin likes this.
  14. Feb 5, 2016 at 1:22 PM
    ahspurlock
    Adam
    hell thats on hold now just had to fork out $400 for a damn fuel pump this morning :goingcrazy::frusty:
    scottalot and Acerwin like this.
  15. Feb 5, 2016 at 1:23 PM
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    That blows. You pulling the bed or dropping the tank to swap it?
  16. Feb 5, 2016 at 1:23 PM
    3milecreek
    3milecreek MtnGoat
    Stephen
    Barnwell SC
    Heavily Modified 94 Yota
    Never the same
    Are you actually coming to gulches?
  17. Feb 5, 2016 at 1:26 PM
    ahspurlock
    Adam
    i dropped the tank it only had 1/4 tank anyways
    scottalot likes this.
  18. Feb 5, 2016 at 3:15 PM
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    That's the plan.
    Acerwin likes this.
  19. Feb 5, 2016 at 3:16 PM
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    How long did that job take? I'm thinking about putting it on my preventive maintenance list since you're not the first person I know to have had to replace it and it could leave me stranded
    Jeffvt0508 likes this.
  20. Feb 5, 2016 at 4:13 PM
    ahspurlock
    Adam
    About a hour it wasn't to bad
Thread Status:
