SCBS Daria don't respond to wrong thread, thread.
Discussion in 'South East' started by Sandman614, Feb 25, 2013.
Thread Status:
Not open for further replies.
  1. Jul 11, 2014 at 9:50 AM
    Yellowplatypuss
    Yellowplatypuss Well-Known Member
    Columbia, SC
    2016 TRD Off Road
    Bilstein 5100 OME 888 & 5160 with AAL, SCS F5, Yokohama GEOLANDERS, morimoto hid and led fogs. Clazzio leather seat covers, ECGS bushing, TRD PRO Grill, Hondo Mount, Martin rack, Baja designs. Caliraised, Ov Tuned
    only issue is that im running 265/70/17s and with the 885's do you think that would look funny and i would need to upsize my tires? and i think the 886's would be too much lift for me... i just want everything to be a little higher, ride well, and look proportional
  2. Jul 11, 2014 at 9:56 AM
    tbturner47
    tbturner47 Well-Known Member
    '16 Barcelona Red TRD Off Road
    886's are the same size as the 885's. So it provides the same amount of lift. The spring compression is what makes the difference in the coils. Depending on which spring you choose and how much weight is on the front determines how much the spring compresses down and settles.
  3. Jul 11, 2014 at 10:10 AM
    HHIRunner
    HHIRunner Former Heep Traitor
    Jake
    ATX
    ‘20 Taco
    Negative offset sticks out of the fenders
  4. Jul 11, 2014 at 10:11 AM
    Hard Luck GraphiX
    Hard Luck GraphiX Well-Known Member
    Josh
    VA
    22 TRD Offroad
    Ok , that's what I thought but I wanted to check. Thanks
  5. Jul 11, 2014 at 10:16 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    Basically a bunch of legal mumbo jumbo as Cam said and 9 times out of 10...Most officers won't even give you a second look...HOWEVER I could pretty easily articulate a case and probably win (depending on the judge of course)...The likelihood of me making that case? slim to none
  6. Jul 11, 2014 at 10:21 AM
    slcsez2000
    slcsez2000 Well-Known Member
    St Aug, FL
    12 TRD Sport 4x4
    Exterior: -Current Suspension- Icon extended travel front struts w/ 700lb coils Icon extended travel Remote Resi rear shocks Dakar leaf pack Icon Tubular UCAs with covers Icon neoprene shock covers -OEM Roof Rack -2 fold down cup holders in bed -Bed bottle opener -Access lite rider roll up tonneau cover -AFE Prodry air filter -Pop and lock bed lock -Rear differential breather relocation mod (behind tail light) -Aeroturbine 2525XL Muffler Armor: -SOS Concepts bolt on sliders W/ kick out -SOS Concepts aluminum front bumper with full hoops -SOS Concepts Rear HC Bumper -SOS Concepts IFS/Mid skids
    Here is what mine looked like with 265/70/17 before and after I got my full OME lift with 885s, trim packer, PLUS 1/4 top spacers on each side and Dakar pack...LR UCAs too.
    Before: Stock (no lift) with 265/70/17:
    AFTER LIFT 265s
    AFTER the 285s installed:
  7. Jul 11, 2014 at 10:24 AM
    Yellowplatypuss
    Columbia, SC
    2016 TRD Off Road
    okay so its done. just ordered the 900021 shocks for a smoother ride (drive on the highway every day) also got the 885's since they will probably settle and sag down the road with the AAL as well. And rear shocks. OY $700 later... Not terrible..
  8. Jul 11, 2014 at 10:42 AM
    Yellowplatypuss
    Columbia, SC
    2016 TRD Off Road
    I opted out since I work at Firestone and could possibly use the coil tamer, also have my master mechanic helping me install
  9. Jul 11, 2014 at 10:52 AM
    TheGoat
    TheGoat Well-Known Member
    Justin
    Greenville, SC
    White 07 SR5 4x4 6spd
    OME 885 springs on 90000 shocks, sway bar removed 1.5" AAL on 285/75/16s
  10. Jul 11, 2014 at 10:56 AM
    slcsez2000
    St Aug, FL
    12 TRD Sport 4x4
    Exactly what I am going to do when I take the 885s off and put on the 886s. If I knew it were that easy I wouldn't have paid for assembly. I saw this video after I installed the lift already. lol
  11. Jul 11, 2014 at 11:01 AM
    EODwick
    EODwick Fire In The Hole!
    Ed
    Box Elder, SD
    2013 TRD Sport
    Stuff I Think Makes it Better
    Is the front top spacer something that is a necessity w/ the old man lifts? Like toytec says to get it using the 884/885 coils to get the full 3" lift, but if you're running 9000s and 885s, isn't that the same lift as running 9000s and 886s?
  12. Jul 11, 2014 at 11:21 AM
    SOS CONCEPTS
    SOS CONCEPTS Bumper builder
    SOS
    Laurens SC
    17 sos buggy, 09 taco(in pieces), 14ram 3500
    Rock bouncer
  13. Jul 11, 2014 at 11:30 AM
    ChamYota
    ChamYota Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    SWAG SWAG
  14. Jul 11, 2014 at 12:43 PM
    TheGoat
    Justin
    Greenville, SC
    top plates are basically the way to dial in an ome since its not adjustable. 884s give about 2 1/2 inches lift on a access or double cab but they give a regular cab with a 4cyl almost 3 inches.
    I've got 884s and top plates on. Got some 885s and I'm going to pull the top plates when I put them on. Lift should stay about the same.
  15. Jul 11, 2014 at 12:57 PM
    EODwick
    Ed
    Box Elder, SD
    2013 TRD Sport
    Oh awesome, thank you for the explanation. Wife said I get to buy the lift for the birthday, so trying to piece it all together
  16. Jul 11, 2014 at 1:21 PM
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
    What's the advantage of these hydro bump thingys
  17. Jul 11, 2014 at 1:42 PM
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    Doin work. My father in law didn't think I could pull this out. He has a Chevy 2500 2wd, and can't get this off the bottom of the driveway of the lot he is building on. The drive is rutted out, up hill.
    I told him I could do it, and he didn't believe.
    4 Hi, no problem. Over 2 ton of weight. Case 1840 skid steer on a 16ft trailer.
    I told him I would see him at the top!
    Now it's at my house. Truck did well pulling 45 mph down the road.
  18. Jul 11, 2014 at 1:43 PM
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Sorry for the sideways pic.
    Stupidphone.
  19. Jul 11, 2014 at 1:45 PM
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    The Dakars dropped MAYBE 1".
    Gotta love em!
  20. Jul 11, 2014 at 2:26 PM
    SOS CONCEPTS
    SOS
    Laurens SC
    Rock bouncer
Thread Status:
