SCBS Daria don't respond to wrong thread, thread.
Discussion in 'South East' started by Sandman614, Feb 25, 2013.
Thread Status:
Not open for further replies.
  1. Aug 4, 2014 at 8:34 PM
    SOS CONCEPTS
    SOS CONCEPTS Bumper builder
    SOS
    Laurens SC
    17 sos buggy, 09 taco(in pieces), 14ram 3500
    Rock bouncer
    lol. Its one of them. to go from that 3000sf building to that big ass one :thumbsup: thats what i need
  2. Aug 4, 2014 at 8:43 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    low country 4x4 was opened in 06, from what i found. dick hendrick toyota wasnt until after i moved here in 10. could have been other off chutes of dick hendrick though in the area at that time.
  3. Aug 4, 2014 at 9:07 PM
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
    One of my best friends works at Gerald and said he can't do it because he'd get fired
  4. Aug 4, 2014 at 9:31 PM
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    just buy some tire spoons and do it your self. Be prepared when you do a tail fix. Ive dismounted my monster tires before, what fun. just cause the local tire shops wont mess with my big tires
  5. Aug 4, 2014 at 9:38 PM
    Boogyman
    Phoenix
    Corpus Christi, TX
    Will they ticket me for driving on beadlocks? This is my DD...
  6. Aug 4, 2014 at 9:43 PM
    Boogyman
    Phoenix
    Corpus Christi, TX
    I just read AEVs page on beadlocks. Pretty informative lol
  7. Aug 4, 2014 at 11:35 PM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  8. Aug 5, 2014 at 6:28 AM
    TheGoat
    TheGoat Well-Known Member
    Justin
    Greenville, SC
    White 07 SR5 4x4 6spd
    OME 885 springs on 90000 shocks, sway bar removed 1.5" AAL on 285/75/16s
    I've got one of these, makes breajing the bead easy
  9. Aug 5, 2014 at 6:38 AM
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    If your going to run beadlocks you might as well learn to mount them
  10. Aug 5, 2014 at 6:40 AM
    Boogyman
    Phoenix
    Corpus Christi, TX
    Have you mounted your tires with this?
  11. Aug 5, 2014 at 6:40 AM
    Boogyman
    Phoenix
    Corpus Christi, TX
    I'd like to be able to do it at home but it seems like more of a pia than it's worth
  12. Aug 5, 2014 at 6:54 AM
    TheGoat
    Justin
    Greenville, SC
    yeah, mounting isn't that bad unmounting is the bitch. also better to use spoons or a screw drivers to unmount. that red bar puts a red ring around the rim. It just makes the process easier because the rim is held stable. Its still a bitch.
    I would pay the $40 just for the bead breaker though. I've had to break the beads twice to clean mud out, the beads were leaking bad because mud got in them.
  13. Aug 5, 2014 at 6:57 AM
    Boogyman
    Phoenix
    Corpus Christi, TX
    My plan was to send in my trd off road wheel to omf and get them bead locked and powder coated but now I'm thinking I'll just save up for some hutchingsons
  14. Aug 5, 2014 at 7:21 AM
    TheGoat
    Justin
    Greenville, SC
    they wouldn't be true bead locks anyway. a true bead lock has an insert inside the tire that holds the bead, its like a clamp that hold the tire on the rim. They would have to cut the bead rim off the outside of the wheel to make it a true bead lock.
  15. Aug 5, 2014 at 8:12 AM
    Boogyman
    Phoenix
    Corpus Christi, TX
    I just have an irrational fear of rolling a bead at low psi
  16. Aug 5, 2014 at 8:15 AM
    SOS CONCEPTS
    SOS
    Laurens SC
    Rock bouncer
    Are we doing this labor day at gulches?
  17. Aug 5, 2014 at 8:16 AM
    Boogyman
    Phoenix
    Corpus Christi, TX
    I'm already scheduled to work
  18. Aug 5, 2014 at 8:29 AM
    TheGoat
    Justin
    Greenville, SC
    Basically why I have the tire changer. I got mud in them at low Psi. You shouldn't have a problem rolling them off unless your going to 10psi or below. That's when bead locks are a must
  19. Aug 5, 2014 at 8:37 AM
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    For that price I might pick one up. That plus balancing beads means no more paying for mounting and balancing
  20. Aug 5, 2014 at 9:05 AM
    Boogyman
    Phoenix
    Corpus Christi, TX
    X2 it'll pay for itself with the first mount and balance
Thread Status:
