Scepter Jerry cans - new stock 7/10/2018
Discussion in 'Buy / Sell / Trade - Other' started by TinkyWinky, Apr 27, 2015.
  1. Sep 6, 2017 at 6:20 AM
    #401
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Use a gasket from an oil filter to seal the male adapter onto the gas can. That worked for me.
  2. Sep 6, 2017 at 6:24 AM
    #402
    Madjik_Man
    Colorado Front Range
    The male adapter has tapered threads. Wouldn't even come close to mating with the spout surface of the MFC.
    Tacofart likes this.
  3. Sep 6, 2017 at 6:30 AM
    #403
    ramonortiz55
    Ramon
    Texas
    stock
    ooo... ouch
  4. Sep 6, 2017 at 10:30 AM
    #404
    Steve In 29
    Steve In 29 Member
    The tapered adapter is to increase sealing against the threads absent a gasket. However if a non tapered piece was used instead then the spout could be screwed down until the o-ring sealed the connection.
    The internal threads are designed into the MFCs so that they were backwards compatible with previous generations of spouts already in the military system. When I was in we were still using the clamp-on spouts a decade after the MFCs were introduced.
    None of the military spouts depend on the threads to seal and have some type of gasket in them. The old GI screw-on spouts used a flat gasket to seal, while the clamp-on ones had the aforementioned expanding rubber plug. Even the current issue, exterior screw-on spouts have an internal o-ring to seal it.
    The military went to the external type as it is exponentially easier to get tight and to loosen afterwards (without a tool) then the internal screw-on's ever were.
  5. Sep 6, 2017 at 11:15 AM
    #405
    Tacofart
    Tacofart Well-Known Member
    Brennan
    San Diego
    04 3.4 4x4 Dual cases/ Lockers
    Anyone got a link to the external spouts?
  6. Sep 6, 2017 at 11:20 AM
    #406
    TinkyWinky
    TinkyWinky [OP] Well-Known Member
    rob1208 likes this.
  7. Sep 6, 2017 at 11:26 AM
    #407
    Madjik_Man
  8. Sep 6, 2017 at 11:27 AM
    #408
    Madjik_Man
    Good to know about the clamp on style. Like I said I'd like to test it out for S&Gs.
  9. Sep 6, 2017 at 11:29 AM
    #409
    TinkyWinky
    I found this yesterday browsing Amazon, this is 1" valve, not sure if the hose will fit into the filler neck restrictor.
    But I know what you mean, make it nice and quick to just dump it in.
    Unfortunately, I'm a lazy ass, I don't want to undo my ratchet strap that holds the gas can on the basket.
    https://www.amazon.com/gp/product/B01N7PD5YX/ref=ox_sc_act_title_2?smid=A1B7M9EQGNCLQA&psc=1
  10. Sep 6, 2017 at 12:45 PM
    #410
    Steve In 29
    Steve In 29 Member
    Search ebay and Amazon. Or do a google search. They run about $25 or so.
    The mil-surp externals will not work with modern vehicles unless they are diesel fueled as the spout is too big to fit. You might be able to source an external to fit a gasoline powered car from Canada though. Or rig up an end of spout adapter.
  11. Sep 6, 2017 at 12:57 PM
    #411
    Steve In 29
    Steve In 29 Member
    Something for people to keep in mind, using that tapered adapter and screwing it down tight to avoid leaks will eventually ruin the threads on the MFC. The plastic of the spout is stronger then the poly of the can and each time it gets screwed down tight it reams out the threads in the hole ever so slightly. That is why the use of a straight adapter that incorporates an o-ring or gasket of some kind for sealing is a better option in the long run.
  12. Sep 9, 2017 at 8:12 PM
    #412
    FiReBReTHa
    FiReBReTHa Member
    plasti Dip all around
    wanted to ask, how much is typically shipping for a couple of cans? (Im in IL).
    Budgeting for my next set of shenanigans :)
  13. Sep 11, 2017 at 11:42 AM
    #413
    Steve In 29
    Steve In 29 Member
    Cans arrived today and despite looking beat up on the outside (which I expected as I ordered his less pretty cans) they all seem serviceable and have complete, unbroken caps. Very pleased with cans and the fast shipping.
  14. Sep 22, 2017 at 11:18 AM
    #414
    TinkyWinky
    I have 6 tan cans that have more scratches but 100% functional. $40 each plus shipping.
  15. Sep 22, 2017 at 12:41 PM
    #415
    Taco Addiction
    Taco Addiction We found Jimmy
    Houston, TX
    2004 Black TRD Offroad
    Kings, SCS Wheels and other mall crawling crap
    Tinky, any water cans my man?
  16. Sep 24, 2017 at 8:12 AM
    #416
    TinkyWinky
    not yet bro, maybe soon.
    MonkeyProof and stphnman20 like this.
  17. Sep 25, 2017 at 7:27 AM
    #417
    TinkyWinky
    All sold out. I will update when I get more.
  18. Sep 28, 2017 at 8:08 PM
    #418
    d.shaw
    d.shaw Well-Known Member
    2012 Silver TRD-OR
    Vagabond Drifter, King 2.5 coilovers, King 2.5 rear, Pelfreybilt front / rear bumpers and skids, rock sliders, Safari snorkel, Smitybilt winch, Baja designs 20in, wide cornering spots, S2 rear. Deaver expedition series stage 3 rear leaf.
  19. Oct 3, 2017 at 7:36 AM
    #419
    TinkyWinky
    Bump for new batch.
  20. Oct 3, 2017 at 7:38 AM
    #420
    RCRcer
    RCRcer Well-Known Member
    2015 OR DC
    What's in he new batch?
