Sched 40 sliders!?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlackTaco1014, Mar 21, 2015.
  1. Mar 21, 2015 at 4:48 PM
    BlackTaco1014
    BlackTaco1014 [OP] Well-Known Member
    Hey guys, wondering how strong schedule 40 pipe is compared to HREW or DOM for sliders. A guy around here will make them and install for 350 but they're made out of schedule 40 tubing so not too sure if that is strong enough for use as sliders.
    Thanks!!!
  2. Mar 21, 2015 at 4:53 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    1-1/2" sch40 is .145 wall thickness.
    What's normal slider material .120?
    I think sch40 will be thicker and heavier than normal.
  3. Mar 21, 2015 at 4:53 PM
    crolison
    crolison Well-Known Member
    Ar vah da, CO
    POS
  4. Mar 21, 2015 at 4:58 PM
    Pigpen
    Dan
    Northwest Montana
    OP said make and install for $350. If he orders, he'll have to pay shipping and install as well as purchase price.
  5. Mar 21, 2015 at 5:02 PM
    lovethetaco
    lovethetaco Hey hey hey !
    Uncle jeff
    texas
    14DCLB4x4
    Yes,
    Welcome to Tacoma world blacktaco. Take your time and compare from company to company. Also consider type of sliders (bolt on vs weld on), shipping, coating, and installation as well. Take your time with notes, and rule out companies as you go. Good luck sir!
  6. Mar 21, 2015 at 5:06 PM
    lovethetaco
    Uncle jeff
    texas
    14DCLB4x4
    Yes,
    Is said maker in his city? There might not be a charge if so. To me 350 sounds like a process is being skipped. (Price is low)
  7. Mar 21, 2015 at 5:18 PM
    CASTRATE
    CASTRATE Well-Known Member
    Gabe
    SW of Tulsa, OK
    2012 4x4 SR5 6spd
    If you just want them for looks & door ding defense, go for it. AS off-road protection, it's gonna be useless
  8. Mar 21, 2015 at 10:16 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    If said welder knows how to position the pipe for strength, I say go for it, the only draw back is they will be weigh more than your average sliders that cost more. That being said, they will take all the abuse that you can put them thru.
  9. Mar 22, 2015 at 12:16 AM
    CASTRATE
    Gabe
    SW of Tulsa, OK
    2012 4x4 SR5 6spd
    Pipe is not as strong as tube. I weld a shit ton of both for high pressure gas panels daily. Go with HREW at the minimum.
  10. Mar 22, 2015 at 11:33 AM
    BlackTaco1014
    Thanks guys, yeah he's in my city... Having to pay shipping/welders seperately is goona be around 600ish but figured for 350$, with kickout, installed seems like a very good price but just wasn't sure on the strength of the sched 40... I won't be going too hard offroad with my truck since its my daily too but will definately be hitting up some trails in he future
  11. Mar 22, 2015 at 1:14 PM
    BlackTaco1014
    He's got a good reputation around here too from the Toyota guys. Just can't find much on schedule 40 for sliders
