Scheduled maintainance timeline
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Radiolaria, Nov 10, 2018.
  1. Nov 10, 2018 at 6:44 AM
    Radiolaria
    Radiolaria [OP] Active Member
    2018 blue tacoma limited
    None
    I’m right at 4300 miles on truck. When is it early enough for the 5000 mile look over?
  2. Nov 10, 2018 at 6:51 AM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Anytime. Nothing happens at the 5k except them telling you they rotated the tires. That's my experience at least.
    shakerhood, BSFord and Vbpiper like this.
  3. Nov 10, 2018 at 7:53 AM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    I usually wait until the maint required soon alert starts popping up before I order the parts I need and pick a day to do it. All that is done at the 5k mark per the toyota maintenance schedule is check your floor mats, check your fluids, check your wiper blades, rotate tires, and visually insect the brakes.
  4. Nov 10, 2018 at 8:21 AM
    Rustytaco71
    Rustytaco71 Well-Known Member
    2018 4Runner
    I take mine in just as a check mark, because if something warranty related happens they can simply say you missed your check in and that could’ve caused whatever you issue you may have. They do nothing you can’t do, so it’s up to you if it’s worth going in for 1-2 hours to save yourself a potential headache down the road.
  5. Nov 10, 2018 at 8:30 AM
    Jerrfylube
    Jerrfylube Well-Known Member
    CA
    2004 X-Cab TRD 4x4 2017 DCSB TRD 4x4
    Grab a toolbox and go over all the hardware you can visibly see, specifically on the suspension and driveline. I found numerous loose nuts/bolts on mine and even silenced (mostly) some of the drive train chatter/rattle by torquing my rear leaf spring u-bolts to proper spec (they were approximately less than half of what they should have been!). Rotate your tires, drive another 5000 then change your oil and rotate the tires again. Done.
  6. Nov 10, 2018 at 8:31 AM
    Amanelot
    Amanelot Member
    Texas
    Hey man, whats the torque specs on the U-bolts? I need to check mine
  7. Nov 10, 2018 at 8:38 AM
    Jerrfylube
    CA
    I'd have to check the FSM, which I don't have access to at the moment... I believe it's 70-something ft lbs. 75 should be fine.
  8. Nov 10, 2018 at 8:40 AM
    skiploder
    skiploder Well-Known Member
    Somewhere NE of Kanab
    FZJ80/XJ LS swap
    How long have you had the truck?
  9. Nov 10, 2018 at 8:42 AM
    Amanelot
    Amanelot Member
    Texas
    I found the service manual. Under 4wd torque specs it shows this
    "Rear spring U-bolt x Spring U-bolt seat sub-assembly 37 ftlbs"
    That sound a little low...?
    hiPSI likes this.
  10. Nov 10, 2018 at 8:43 AM
    Clearwater Bill
    Billy
    Largo Florida
    Any actual examples to cite?
    I've never had any dealer service (on any vehicle) outside of recalls/service campaigns or warranty work, and never had an issue.
    shakerhood likes this.
  11. Nov 10, 2018 at 8:43 AM
    toyotatacomaTRD
    It's been long speculated it should read 73 instead of 37. I torqued mine to 70 and was surprised how many turns it took.
    Jerrfylube and AugustusJack like this.
  12. Nov 10, 2018 at 8:48 AM
    Slick Taco
    Slick Taco Id Rather Be Airborne
    Lost somewhere in the PNW
    Current vehicles: 2019 Rav4 Lunar Rock. 2018 TRD OR DCSB KD Max tuned. 2010 Tundra Limited Crew Max . 1991 4Runner Crawler. Ivan Stewart Edition
    KD Max Tune, King 2.5 coil overs T.C. UCA's, Deaver leafs, 17x9 Black Rhyno Warlords, 33" Toyo M/T's, Metal Tech rear bumper, Westin HDX drop steps with Bullet Liner coating, K&N CAI, Baja Designs fog pods, Rigid Midnight addition 3" pod ditch lights. Cali Raised brackets and 32" behind the grill mounted light bar, Southern Style Offroad Lopro Stage II front bumper, Warn winch, FACTOR 55 Ultra Hook, FACTOR 55 Hawes Fairleed, full debadge, Cosmetic goodies such as 15% carbon tint, matte black in channel rain guards, interior LED's, Teton Workshop shift knob, Inferno vinyl detailing on the interior, Cali Raised multi rocker switch cubby insert with Mc Tuning LED switches and a few other mods I've probably left out.
    I guess I'm lucky my local dealership offers free 2 year scheduled maintenance with the puchase of any vehicle. I usually do all my own fluid changes diffs, tranny, oil etc but will definitely be taking advantage of the freebie. Although I'm only averaging 300 miles a month (not my daily driver) so I have a feeling it wont be in much :rolleyes:
  13. Nov 10, 2018 at 8:48 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Never had any problems either, I check off everything in the book put date and mileage, when I happen to be near the Dealer I take the book in and they enter the info in the computer. I believe Toyota even has an Owners Website where you can enter your maintenance.
  14. Nov 10, 2018 at 8:49 AM
    MattEcho
    MattEcho Optimist
    CO
    2017 Silver Tacoma TRDOR DCSB AT (non-JBL Tech)
    Dealer called me at 3800 miles to schedule appt, I think it was 6 months. They checked fluids, rotated tires and applied the latest tranny TSB at the time. So not much, but I like taking it in regularly and here's why. 1. It allows me to talk to get to know the service advisors, see how much they know, care, etc. 2. Gives me a chance to address any "issues" with the truck.
    In almost 2 years, I've learned that your experience depends a lot on the advisor that you get. I know that sounds pretty obvious, but I had no idea what to expect going in. First new toyota and first with this dealer.
  15. Nov 10, 2018 at 8:49 AM
    Amanelot
    Amanelot Member
    Texas
    That makes sense, but it also lists the NM to be 50, which a little over 36 ftlbs. The listed KGCM matches up too, seems a little less likely to be a typo.
    Idk, not trying to start an argument, 37 sounds low, ill probably tighten mine up
  16. Nov 10, 2018 at 8:53 AM
    toyotatacomaTRD
    I've never known, but it seems like something that's not an issue over tight, but a dangerous one under.
    Amanelot[QUOTED] likes this.
  17. Nov 10, 2018 at 8:59 AM
    Amanelot
    Amanelot Member
    Texas
    I like how you think
  18. Nov 10, 2018 at 9:00 AM
    Jerrfylube
    CA
    I agree. It's gotta be a typo. 35 ft lbs on a fastener that large just isn't enough IMO--they made all kinds of noise when they were torqued that low from the factory.
    In fact, the dealer torqued them to at least 70 (I checked) when I had the TSB done for the rear end whine...
  19. Nov 10, 2018 at 9:20 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Also, manufacturing does not use the field service manual. Totally different documentation and procedures.
  20. Nov 10, 2018 at 9:35 AM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    You can easily get the toyotowners app or go online and input the maint. you have done. You put in the date and mileage and what you completed. I do it with our Rav4 and did it during the time of the Toyotacare. It keeps the record attached to your VIN, so when you need to prove something was done it easy to show.
    oconnor and shakerhood like this.
