Scheduled Maintenance (2nd gen) - 30,000 - 60,000 - 90,000 miles
Discussion in 'Technical Chat' started by harshest, Mar 19, 2009.
  1. Mar 12, 2019 at 7:02 PM
    #201
    Taco-Obsessed
    Stealer quoted me 1700 for 60k maintenance. I'm gathering supplies now. Figure it is not going to cost me more than 400 in supplies, I'll do the work myself with help of my Hayes manual, TW threads, and YouTube, and save 1400 smackaroos. Plus beautiful excuse to work on my rig that the wifey will agree with.
    700cinema, TOMB, 4WDTrout and 2 others like this.
  2. May 3, 2019 at 2:45 PM
    #202
    Taco-Obsessed
    Question - my hayes manual has a lot more required maintenance than what is listed in the link in first post. I am required to do alot of things that are listed as things to check. I got a 2015 and again this is per my hayes manual.
    I'm half way done and I am going to do it as directed in my manual. Curious where the discrepancy is though for the differences. Thoughts?
    My list at 60k is (alot is from the every 30k schedule)
    Fluid changes
    -front diff
    - transfer case
    -rear diff
    -transmission
    -oil
    -coolant
    -brake fluid
    Other
    Air filter
    In cab filter
    Spark plugs
    Throttle body/MAF cleaning
    -grease driveline zerks
    -retorque driveline bolts
    -check alot of various things
    TOMB likes this.
  3. May 4, 2019 at 8:16 PM
    #203
    la0d0g
    running for the hills
    For crawling not hauling
    I don't do the trans, brake fluid, or coolant.
    ready6delta likes this.
  4. May 4, 2019 at 8:21 PM
    #204
    Taco-Obsessed
    la0d0g likes this.
  5. May 4, 2019 at 8:34 PM
    #205
    Taco-Obsessed
    Our trucks come with 3 denzo spark plugs and 3 NGK spark plugs off the factory line. Not sure why, but I know Toyota dealers and parts department only carry denzo. So if they change them during servicing you end up with 6 denzo. My truck was still under warranty at 30k so I had the dealership do my 30k maintenance for free. I checked my records and this included a spark plug change as it should of per the service schedule by Toyota. Well today I changed my spark plugs for my 60k and there were 3 NGK still in there. Those fuckers did not change them at 30k.
    Also cleaned my throttle body and MAF .. plus new air filter. Did my diffs and tcase last weekend. Just got oil/filter, in cab filter, grease zerks, and retorque various bolts left.
    Soon I will have accomplished my 60k myself. I'm no mechanic but love working on my truck and learning as i go.
    4WDTrout and la0d0g like this.
  6. Jun 1, 2019 at 7:06 AM
    #206
    Gopher TRD
    Gopher TRD Well-Known Member
    Justin
    New Jersey
    2014 TRD Sport
    thank you for this very helpful.
  7. Jul 22, 2019 at 12:58 PM
    #207
    mayday
    mayday Well-Known Member
    Central Coast, CA
    99 5 speed 4x4 SR5 TRD Supercharged
    Great resource. Glad you posted this! Any additional info for high mileage would be great as well.
  8. Jul 25, 2019 at 1:50 PM
    #208
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    It’s unbelievable what dealerships get away with these days... I’ve had my share of dealing with their BS as well. Glad to hear you got it all taken care of and are seeing the light through their smoke. :thumbsup:
    Taco-Obsessed[QUOTED] likes this.
  9. Aug 28, 2019 at 4:43 AM
    #209
    bwrapped
    bwrapped Frequent Visitor
    Brad
    Indiana
    2011 Tacoma Sport DCLB
    Retrofit headlights, Wireless Charger, Power Rear Window
    just about to cross 50k, looking forward to doing my own maintenance at 60
  10. Sep 1, 2019 at 7:30 PM
    #210
    cuda2k
    cuda2k Well-Known Member
    Jon
    Allen, TX
    BRM 15 TRD Off Road 4wd
    LVL8 MK6 wheels,SOS Sliders,Smked 3rd Brake,Gibson Exhaust
    Finally caught up on my 60k maintenance this weekend except for the front diff. Didn't have a breaker bar long enough to break the drain plug free, seems my local Toyota dealership really torqued it down when I had it in for service shortly after I did the 30k work which required a fluid drain and refill up front. :annoyed:
  11. Sep 4, 2019 at 9:17 AM
    #211
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    You probably already know this, but be very careful not to strip the front drain plug. Really make sure your 10mm hex socket is deeply and squarely inserted into the drain plug hex hole (you may need to clean mud out of the hole). If it's crooked and/or not fully seated and you apply a ton of torque, that thing will strip.
    ready6delta and cuda2k[QUOTED] like this.
  12. Dec 17, 2019 at 9:14 AM
    #212
    ready6delta
    ready6delta REGULAR GUY
    JACOB
    Still in PNW but moved to Boise.
    Black pinstriped 2014 DCSB 4x4
    IT NEVER ENDS..........
    Same here, Just did most of my 60k myself over two weekends and upgraded the ECGS bearing. Will do the throttle body and MAF this weekend and change out all air filters. I will wait to do trans, brakes and coolant until 100k or when they show signs of issues whichever comes first.
    la0d0g[QUOTED] likes this.
  13. Mar 24, 2021 at 5:06 AM
    #213
    Inbred
    Inbred Well-Known Member
    Phinnius
    2nd generation euphoria
    The '14 Tacoma Sport has 57,200 miles on it and I'm gearing up the 60,000 mile service in the next few weeks. Assembling parts and tools now. This thread is golden when approaching the task. Glory be.
  14. Oct 25, 2021 at 5:35 AM
    #214
    cgm
    cgm Well-Known Member
    NBPT, MA
    2014 TRD Sport 6 Speed DCSB
    i'm at 94,xxx. time to do the 90k service.
    engine oil is done, so ill do
    the front dif https://www.youtube.com/watch?v=edw3x37qg-w
    rear diff https://www.youtube.com/watch?v=jNWzQ2MbcX0&list=PL-IN_9dyC2sCR7m7Ncz5ePnhGhXFpYZNu&index=2
    t case https://www.youtube.com/watch?v=zzBpnBU3yBE&list=PL-IN_9dyC2sCR7m7Ncz5ePnhGhXFpYZNu&index=13
    6 speed transmission fluid. https://www.youtube.com/watch?v=6tN7UErwDNM
    How do i know if i need to flush coolant or brake fluid?
    after that...
    clean maf?
    grease prop shaft?
    Is there anything else I am missing?
  15. Nov 1, 2021 at 12:05 PM
    #215
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    What’s the Maintenance for 200k?
  16. Nov 1, 2021 at 4:04 PM
    #216
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Same as 100k
    4WDTrout[QUOTED] likes this.
  17. Nov 12, 2024 at 6:02 AM
    #217
    MadDaddy
    MadDaddy Pork Rind Extraordinaire
    53 Miles West of Venus
    Many & varied
    250,000 maintenance? The original link is dead.
  18. Nov 12, 2024 at 10:18 AM
    #218
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    If you still have your original owners maintenance manual, everything repeats itself.
    Spark plugs: 30k
    AFR’s: 60k
    MAF n TB clean: 15k
    Engine air filter replace/clean: 15k
    Engine oil n filter: 5k
    Tire rotation: 5k
    Brake fluid flush: 30k
    P/S fluid flush: 30k
    Differentials n T-Case fluid: 30k
    Transmission drain n fill: 30k
    Coolant: 1st 100k then every 50k
    Lube drivetrain: 5k
    k = 1000 miles
    MadDaddy[QUOTED] likes this.
