Scheduled Maintenance on fluids questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dawgs1125mbsr, Dec 26, 2022.
  1. Dec 26, 2022 at 3:03 PM
    Dawgs1125mbsr
    Dawgs1125mbsr [OP] Well-Known Member
    Between the manuals and a service dealer saying different, guess I’m confused on when to change fluids and appreciate any input…2018 Tacoma 4x4 79500 miles. Never off road
    Front and rear differential
    Transmission
    Coolant
    Brake
    Any other fluids?
  2. Dec 26, 2022 at 3:10 PM
    Kyle_
    Kyle_ A guy and his expensive hobby
    Kyle
    SoCal (805)
    2021 TRD OFF-ROAD 4X4 DCSB
    @tacoma.kyle on IG
    Just my opinion but service reps can be and are wrong. The manual won’t be.
    soundman98, Tocamo, Chew and 2 others like this.
  3. Dec 26, 2022 at 3:16 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Follow Toyota's recommended service schedule as outlined by the website linked below... just enter your vehicle and mileage...
    The service writers are only concerned with how much money they can pry out of your wallet... not your vehicle service needs.
    https://www.toyota.com/owners/parts-service/maintenance-schedule
    RustyGreen, soundman98 and shakerhood like this.
  4. Dec 26, 2022 at 3:19 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The Dealership will recommend stuff to make money, just stick to the Manual.
    Chew, na8rboy and Speedfreak like this.
  5. Dec 26, 2022 at 3:22 PM
    Clearwater Bill
    Billy
    Largo Florida
    Go by the book. Just don't ignore the severe duty section, just in case it applies.
    Constant sort drive cycles like a couple miles to work each day is severe on engine oil IMHO
    Chew and shakerhood like this.
  6. Dec 26, 2022 at 3:32 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Owner’s manual’s job: to keep your truck in good working order
    service writer’s job: to keep his lake house mortgage current and his boat in good working order
  7. Dec 26, 2022 at 3:52 PM
    GoldenBrew
    GoldenBrew Insufficient Privilege
    Golden, Colorado
    Gen3 4X4 TRD OR AT - SOLD not Forgotten
    Can you do any of your own services? Two of the four noted are easy IMO (Differentials and Transmission), and if you can measure and replace what you drain/fill then you should be able to do 3 of 4. The brakes - I would have the dealer do. And while you are at it do the power steering fluid full flush and fill too - easy as checking your oil. Or just drive it and don't look back until you trade it in for something else (Tundra). :anonymous:
  8. Dec 26, 2022 at 3:57 PM
    Dawgs1125mbsr
    Lol , no not able to do it myself, never had the front, rear differential changed, or transmission, brake , power steering. At the dealer today for oil change and of course they mentioned to do front & rear differential, coolant change , brake flush. The manual really only states to check the front & rear diff @ 30,60,90 didn’t see a change. Truck is a pavement princess, never off road or tow
    TexasWhiteIce likes this.
  9. Dec 26, 2022 at 3:59 PM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    Brake fluid is 3 years tops.
    Trans is 60k miles
    Coolant is 7 years or 100k
    HisDad likes this.
  10. Dec 26, 2022 at 4:00 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Find a reputable independent mechanic and forget about the dealer. Do what you can yourself and take the truck to them for what you can't and tell them what you want done.
  11. Dec 26, 2022 at 4:03 PM
    GoldenBrew
    Golden, Colorado
    sounds like mine - but it can't hurt to change the fluids - just like oil changes. No judgement here, I get it and am lucky I have the time, tools, knowledge and resources to do services. I just changed the Power Steering fluid - was struck by the nasty fluid that came out at 60K and how easy and light the steering wheel turns now. If you were local I would help you out. That is what TW represents. GL.
  12. Dec 26, 2022 at 4:06 PM
    Dawgs1125mbsr
    Appreciate that
  13. Dec 26, 2022 at 4:17 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    For power steering fluid, just suck out what’s in the reservoir and replace that amount. Do it a few times over a few weeks and you’re good. Same with brake fluid.
    usmc2msu likes this.
  14. Dec 26, 2022 at 5:02 PM
    kfallsfunk
    kfallsfunk Member
    Joe
    2022 SR 4x4 V6 AT
    Running boards , under coating
    honestly the book sucks , really written for consumers report to show how cheap maintenance can be, but toyota list all fluids as inspection in most cases, so if someone actually checks them, they will find my list below is fairly normal.
    Here is what I have stuck to since 2008 for my toyota's at one point I had 3 with a total of 680,000 miles ( for all 3) so it seams to work just fine
    coolant, 5 years , 100k , after first change every 50k up to 4 years
    Brake fluid 2 years, funny a lexus of the same model will list it, but cheaper toyota's have no brake fluid interval listed?? ( new BMW's are now 3 years 1st time, then every 2 years... bet that is because the car comes with 3 years of included maintenance , so whose interest is being served )
    Transmission fluid ( any WS car/truck) 60,000 miles , non-tow or easy life car, 90k, then every 60k
    Diffs - even my 98 4 cy camry had a servable front diff ( AT only) every 30k , truck with lots of tow time--every 15k ( german rav4 show 15k!!)
    T-case - 30k , ( rav's highlanders, sienna , all the car based "all wheel drive" only hold a quart - do them , they also are the front diff in a since for those cars/suv)
    power steering at 60k, then every 30, unless dirty prior to 60k , then do it
    it all depends on how long you expect something to last - if you punt cars/trucks by 60k, or lease them, follow the manual, but actually follow the manual including reading the severe , almost everyone falls into that for one reason or the other.
    Engine oil, well 10k, just not into it, 6 months -- up to 7500 in most cases @ 6 months I am not even at 5k but over a 10 year period, an extra 1000$ on what may be unneeded oil changes... I don't care, I am doing it at least every 6 months!
    As a father son project, my son and I rebuilt a 1993 22re @ just under 300k, had been serviced similar all it's life - when I turned the engine on its side to push out the pistons , The first when went flying out and hit the ground, I was expecting the lip on the cylinder to cause some resistance.... The dam motor still had cross hatching and no ridge... ruined the piston that hit the floor so it got bored , balanced and a full build when it could have been ringed and gasketed!( new mechanical word I swear) why, this thing was maintained its whole life!
    To each his own, but I believe in fluids and the book being stupid if someone keeps a vehicle
    soundman98 likes this.
  15. Dec 26, 2022 at 5:36 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Regardless wether you off road or not, go by the manual! And as far as brake fluid, does anyone really change that????
  16. Dec 26, 2022 at 5:37 PM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    Never have... except during brake service work...:anonymous:
  17. Dec 26, 2022 at 5:42 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    Once the fluid in the reservoir takes a certain percent of water content, I for one absolutely change it.
    Tocamo[QUOTED] likes this.
  18. Dec 26, 2022 at 5:49 PM
    Benny22
    Benny22 Well-Known Member
    20Tacoma
    GL5 gear oil 90wt
    Toyota WS
    Toy pink
    Dot 3/4
    Transfer case, Redline 75wt https://www.redlineoil.com/mt-lv-70w75w
    power steering, https://www.redlineoil.com/power-steering-fluid
  19. Dec 26, 2022 at 5:51 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    lol, all the service writers i know have the job to keep their 1994 honda civic operational while paying child support to their ex-wife. i haven't met any service writers that can even afford a boat, let alone a lake house
    HisDad and Chew[QUOTED] like this.
  20. Dec 26, 2022 at 5:54 PM
    Benny22
    20Tacoma
    I do mine every 3 years. I'll need to buy a scan tool that will turn on the brake bleed option on the Tacoma.
