School me on aftermarket wheels.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bumrush, Oct 28, 2015.
  1. Nov 1, 2015 at 7:56 AM
    #41
    Mr. Torgue
    Mr. Torgue Explosions!!?!!?!?
    2016 7544HHBBP
    LED lighting
    Offset is 30mm, tire diameter is 31" not sure the width.
  2. Nov 1, 2015 at 8:03 AM
    #42
    Taco2k16
    Taco2k16 TRD_ShoreTrooper
    Danny
    Los Fresnos, Texas
    2017 TRD OffRoad 4x4 QuickSand DCSB
    Stock Tow Package Bed LEDs
    Sub'd
    hey guys i am also looking to get wheels and tires i drive a lil 2016 i4....i will not be using it for offroading or anything on that sort. Its my daily. But i am looking for a 3 inch leveling kit from toy tech.
    what would be the most "meatier" tires and best wheels set up i can go with without any modifications( no trimming, not removing the air dam etc..) Just looking to have a nice looking daily on the road. Thanks
    BTW i am fairly new to all this stuff its my first truck
  3. Nov 1, 2015 at 8:05 AM
    #43
    Mr. Torgue
    2016 7544HHBBP
    LED lighting
    I believe 33s with 8.5" width. Wider tires rub at full lock and bigger tires require trimming if I'm not mistaken.
  4. Nov 1, 2015 at 8:10 AM
    #44
    Taco2k16
    Danny
    Los Fresnos, Texas
    yeah not looking for anything crazy this is my work truck. Just looking for a nice little set up
  5. Nov 1, 2015 at 10:47 AM
    #45
    Bumrush
    Bumrush [OP] Well-Known Member
    Brian
    Middle TN
    16 TRD OR SB quicksand
    I don't understand the offset is 30mm? I don't see that as an option when purchasing these wheels.
  6. Nov 1, 2015 at 12:10 PM
    #46
    Mr. Torgue
    2016 7544HHBBP
    LED lighting
    Are they asking for back spacing instead? That's usually measured in inches instead of mm.
  7. Nov 1, 2015 at 12:34 PM
    #47
    Bumrush
    Brian
    Middle TN
    I'm confused
  8. Nov 1, 2015 at 12:40 PM
    #48
    TinSue
    TinSue Well-Known Member
    Check post #23 in this thread.
  9. Nov 1, 2015 at 1:08 PM
    #49
    Bumrush
    Brian
    Middle TN
    This helps, however I still need to know what will fit on my truck. I want the 9" wide wheel.
  10. Nov 1, 2015 at 2:04 PM
    #50
    Bumrush
    Brian
    Middle TN
    [​IMG]now I'm thinking about these because they are $124 ea vs $191. Anyone have these pro comps? Do you like em?
  11. Nov 1, 2015 at 3:47 PM
    #51
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    I would like to get these..and ditch my Konig Countersteers before I toast another one :rolleyes:
  12. Nov 2, 2015 at 4:25 AM
    #52
    BadBrains
    BadBrains Spreading the Aloha
    AL
    '07 Taco LT, '00 GS-R, '75 C10, '83 CJ-7, '19 T4R SR5
    King, TC +2"LT, 35's, Aluminum this and that.
    Right?
    You could also argue that all the added weight from armor is adding more stress on the bearings. You're really screwed now.:annoyed:
    Arailt likes this.
  13. Nov 2, 2015 at 5:21 AM
    #53
    SharkyPR
    SharkyPR Well-Known Member
    Central Florida
    2009 Civic Si
    All bolt ons + tuning solution. Capable of running high 13's.
    Is like cars.
    • Try as much as you can to keep the same factory wheels specs.
    • Go lighter if you can. Less rotating mass equals to less horsepower is used to move the wheels. In other words you can unleash a few ponies. (This has been proven many times, isn't a brainfart from me).
    • If you still want to use a setup with an outer diameter bigger than the factory one, consider to upgrade brakes and changing the differential ratio. If you dont do it, your truck will feel slower and it will be harder to stop it.
    EDDO and Derek G like this.
  14. Nov 2, 2015 at 5:58 AM
    #54
    pino
    pino Well-Known Member
    I have a question...
    Say the larger tire I'm buying is a 3.7% larger diameter than the stock tire size.
    Lets say I drive 300 mies per tank of gas with stock tires.
    With the new 3.7% larger tires, say I get 290 miles per tank now.
    Should I be multiplying 290 by 1.037 now for a more accurate idea of how many miles per tank I'm getting?
  15. Nov 2, 2015 at 6:12 AM
    #55
    SharkyPR
    Central Florida
    2009 Civic Si
    There is not a single multiplier in the world that will change the fact that you are getting 290 miles per tank.
  16. Nov 2, 2015 at 6:35 AM
    #56
    BadBrains
    AL
    He's trying to account for the speedo reading being off.:facepalm:
  17. Nov 2, 2015 at 6:38 AM
    #57
    SharkyPR
    Central Florida
    2009 Civic Si
    Oh my bad. :facepalm:
    BadBrains[QUOTED] likes this.
  18. Nov 2, 2015 at 6:39 AM
    #58
    Rippin101
    Rippin101 Well-Known Member
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
    Had them on my last Taco, loved em!
  19. Nov 2, 2015 at 6:45 AM
    #59
    Mr. Torgue
    2016 7544HHBBP
    LED lighting
    Yes, going from a 31 to a 33 is a 6.5% increase in diameter, this translates from a circumference going 97.4 to 103.7, also a 6.5%.
  20. Nov 2, 2015 at 6:48 AM
    #60
    SharkyPR
    Central Florida
    2009 Civic Si
    I guess that if he goes here https://www.tacomaworld.com/tirecalc.
    He can get the % of difference of MPH between his previous stock size vs the new size. That % is the one that he can use to get a better idea of how many miles he really traveled.
