School me on waterless wash products.
Discussion in 'Detailing' started by cvisinho, Jan 15, 2018.
  1. Mar 23, 2018 at 8:30 PM
    jdrop01
    jdrop01 Active Member
    Weatherford TX
    17 Tacoma DblCb SR5
    Used Optimum No Rinse Wash for years especially when I was stationed in Missouri! During the winter months I used hot water and always kept my vehicles clean and everyone wonder how! Then everyone jumped on board after that. I now use their Optimum No Rinse Wash with wax. Keeps the shine on vehicles going for bit after doing a full wax job.
  2. Mar 24, 2018 at 6:30 AM
    gorram
    gorram Well-Known Member
    2016 Limited
    Wolfgang Uber Rinseless Wash is a great one. Has multi uses as a wash, clay lube and detail spray. Mix up 3oz to a gallon of distilled water as a detail spray which you can also use to spritz on your drying towels to make them glide over the paint easier. A great rinseless method (though I still spray the truck down with hose or sprayer at a coin op) is to mix up the 1oz of Uber to 3 gallons of water. Throw 8-10 or more high quality microfibers like an eagle edgeless (the rag company) into that solution. Pull a towel out of the solution, ring out, fold into fours and proceed to make one pass per side of the towel starting at the top of the truck and continue down. If you have quality towels you should be able to get 8 sides out of each towel. Discard your dirty towels into another container to be washed, that way your first bucket solution should still be clean after removing the last towel. Here is where you can use a less fancy towels to wipe down the wheels.
    Work one panel at a time and use a high quality drying towel to dry each panel down before you proceed to the next. Use the Uber in it's detail spray form to assist in buffing off and drying each panel. If you can't do the rinse down ahead of time then definitely spray down with the Uber at least.
    Uber is super slick and your paint will feel nice and slick after you've wiped down.
  3. Mar 26, 2018 at 9:36 AM
    WebberLander
    WebberLander Well-Known Member
    Mark
    Colorado
    2011 SR5 4x4
    Overlanding Rig
    Same boat as many of you when it comes to Optimum No Rinse. Been using it for years in the two-bucket method and as well as a detail spray and clay-lube. I also use it for many other things ( cleaning windows, wiping down plastics inside the vehicle etc).
    Although we don't get winters like the rest of the country, on cold days I just use hot water so my hands don't get cold so quickly.
    I find that using the ONR with wax tends to flash rather quickly in the summer heat here in Texas so I rarely use it when its hot out. Overall ONR is great stuff.
  4. Mar 26, 2018 at 9:41 AM
    jdrop01
    Weatherford TX
    17 Tacoma DblCb SR5
    I love this stuff. If my vehicles are not heavily dirty I just use the ONR and then follow up with either a detail spray or spray on wax. My vehicles are all silver so keeping them looking clean is easy.
    WebberLander[QUOTED] likes this.
  5. Mar 27, 2018 at 11:18 AM
    killerken
    killerken Well-Known Member
    Philadelphia
    09 toyota tacoma dbl cab trd
    Access LE Cover Toyota Factory Nerf Bars Dynolock Tail Gate Lock
    Never used a waterless wash yet but if I was going to try a product, based on all my research I would try ONR.
    If you like AMMO NYC products (I swear by Reflex, skin and hydrate) Larry just launched his version of a waterless wash called
    AMMO FROTHE
    HOSELESS LIFT (CONCENTRATE)
    $35
    AMMO FROTHe Hoseless Lift is a 20x concentrate Humectant that creates a thick shaving cream-like foam to protect the surface of your paint from scratching during a hoseless wash. FROTHe can be use on wet OR dry paint and does not require a final rinse. The concentrated formula will create 30-35 hoseless washing per 16oz. bottle. Perfect for apartment dwellers, drought or water restricted areas, on the road with no hose, and winter cleaning.
    According to Larry you use Frothe with a Foam Pump Sprayer and wipe with microfiber towels.
    You can check him out using this product on his new R8 that he just recently purchased at the end of this video:
    https://youtu.be/MdB-VA5aa0M
  6. Mar 27, 2018 at 11:26 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  7. Apr 9, 2018 at 5:48 PM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    I came looking on here after I watched this video a few hours ago. Has anyone tried it?
    killerken[QUOTED] likes this.
  8. Apr 10, 2018 at 12:03 AM
    killerken
    Philadelphia
    I will be receiving everything today and I will test it out on my truck this weekend. Will either take photos or shoot a quick video.
    May do a panel or two on my wife’s RAV4 as her truck is black and has not been washed for a few weeks where my truck just got washed this past weekend and usually get washed once a week.
    Note: since the initial video Larry has launched two other videos on Frothe that you want to watch.
    113tac[QUOTED] likes this.
  9. Apr 10, 2018 at 3:35 AM
    113tac
    Stephen
    Northern Virginia
    Sweet! I’ll check out his other videos. The one I saw looked good but I wasn’t sure how much was really good marketing haha. It seems like the perfect setup for me living in an apartment.
  10. Apr 23, 2018 at 7:03 PM
    JMag
    JMag Well-Known Member
    Jonathan
    Baton Rouge
    2017 TRD Sport Blazing Blue Pearl
    Winter Is Coming!!! :rain:
  11. Apr 24, 2018 at 10:35 AM
    killerken
    Philadelphia
    Finally got a chance to use the system this weekend, unfortunately I was rushed so no video’s or photos from this wash.
    The system is supper easy to use. Due to the level of pollen on my truck I rinsed off the truck first then used Ammo Frothe to wash the truck followed by Ammo Hydrate.
    Zero scratching and the paint was super slick when I was done.
    Based on the amount of product I used I should get 30 washes out of one bottle of Ammo Frothe.
  12. Apr 24, 2018 at 10:45 AM
    hoverlover
    hoverlover Never pet a burning dog.
    C-137, Laniakea, Virgo, Milky Way, Earth, USA, TX
    Things. Stuff. Lots of bad decisions.
    Mostly Zip-Ties
    I use aircraft wash and wax on mine. It's good for plastic, glass, paint, whatever. There's also a degreasing version.
    I've found it works pretty good in direct sunlight when other brands would be a waste of time.
    E8F8F9BA-898A-4E59-842C-0E0885E602B3.jpg 1F049F07-5E99-4F1B-AEE4-49689B76576B.jpg
    I gave it a thorough wash before I started using this and now I just hit it once a week or so for the same shine.
  13. Apr 24, 2018 at 10:54 AM
    113tac
    Stephen
    Northern Virginia
    I might have to get some!
