School Me On Wheel Offset & Wheel Spacer Equivalents
Discussion in 'Wheels & Tires' started by Rx7turbo2, Dec 25, 2020.
  1. Dec 25, 2020 at 2:59 PM
    Rx7turbo2
    Rx7turbo2 [OP] Well-Known Member
    Canada
    2020 TRD OR DCSB (Current) 2005 TRD OR DCSB (Sold)
    2020 DCSB stock suspension
    I currently run stock Offroad Wheels ( 7” width +25 offset), I run them with a 1.25” (31.7mm) Spidertrax spacer. Running a 265/75/16 tire.
    I like the stance in this config, would like to replicate it on a set of SCS, or maybe Method rims not sure yet. Would like to stick with 16” and the 265/75/16 tire, but rim will likely increase to 8” width.
    Feel free to correct me if I’m off base here. Using the Spidertrax is giving me a -6.7mm equivalent offset?
    So if I go to an 8” wide rim I’d like to stick to a roughly 0mm offset, that should give me about the same “poke” in terms of stance, it’ll move the rim and tire 19mm closer to suspension components but should still clear as it’ll be 12mm further away than it is with stock rims and no 1.25mm spacer?
    Feel free to tell me I’ve completely bungled that lol.
  2. Dec 25, 2020 at 6:31 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Correct. The 7” wheel with the spacer has approx. a 4.75 backspace and the 8” will have a 4.5 backspace with a 0 offset wheel.
    Rx7turbo2[OP] likes this.
