Scion xD headrest replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bishtacova, May 2, 2010.
  1. May 2, 2010 at 5:58 AM
    bishtacova
    bishtacova [OP] Don't buy a Ford
    2009 DC PreRunner V6
    4 leaf TSB, reflash ECM, Eurostyle antenna, thule roof rack, bed extender
    Has anyone swapped out their front active restraint headrest for a scion xD front headrest? If so, which Scion and model did you use or are they all the same stock?
  2. Sep 2, 2013 at 7:51 PM
    squatnbear
    squatnbear Well-Known Member
    TX pro MGM
    I have read somewhere around here its and 08 but cant be sure. I would like to change mine too but cant find info. Also seams as if 2008 MB 320 head rest fit too.
  3. Sep 9, 2013 at 8:41 PM
    squatnbear
    TX pro MGM
    I just ordered some they should be here Th. ill let you know how it works.
  4. Sep 10, 2013 at 7:23 AM
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    just put the stock ones in a bench vice and bend them back. this was the only way i could make my 2012 head rests comfortable. when you get your new headrests post up some photos, curious how adjustable they are and how they will look.
    racergrl and TRDSport10 like this.
  5. Sep 12, 2013 at 2:13 PM
    squatnbear
    TX pro MGM
    So Much better!!! I thought they were gray when ordered but I like them in black just can ever change my seat covers now lol. As far as adjustments go no real difference between the OEM head rest and new ones just gives you more neck room.
    racergrl likes this.
