+SconnieHailer's Build & BS+
Discussion in '2nd Gen. Builds (2005-2015)' started by SconnieHailer, Mar 24, 2013.
  1. Apr 6, 2015 at 7:54 PM
    #2001
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Mine are off the secondary mount haha I want to redo them though. Want clevis mounts. And thicker straps. Probably TG ones.
  2. Apr 6, 2015 at 7:57 PM
    #2002
    SconnieHailer
    SconnieHailer [OP] PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Yea, im using the clevis' from my pelfrey kit since i never needed to strap the rear. Yea TG makes the bomb ones. I went with Kar tek since I thought the super thick strap might cause a problem near the tie rod... can always pick those up if the kartek straps work well and leave room for bigger straps
  3. Apr 6, 2015 at 8:01 PM
    #2003
    Blackdawg
    Monte
    Wyoming/St. Louis
    I just know the TG straps have very little stretch over time.
    Hoping I won't have to strap my rear but if I do I'll definet get those too.
    My current ones I can't even remember what brand they are...ha
    Can you put the strap in the backside of the coilover so it's not in the way if the tie rid?
    Never mind..cv is there..ha
  4. Apr 6, 2015 at 8:03 PM
    #2004
    SconnieHailer
    Marc
    yup...
    I have a set of 16's that were for the rear if you need them when the time comes... May be too short for you :p
  5. Apr 6, 2015 at 8:06 PM
    #2005
    Blackdawg
    Monte
    Wyoming/St. Louis
    Won't be too short for this summers rear setup...I think. Id be amazed if I could pull that SOA haha no idea how that'll turn out anyways.
  6. Apr 6, 2015 at 8:10 PM
    #2006
    SconnieHailer
    Marc
    Yea be fun to see what you come up with!
  7. Apr 6, 2015 at 8:11 PM
    #2007
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea I have it all in my head..I just have no idea how well it'll actually work. And length of shock too. Whatever.
    :itllbuffout:
  8. Apr 6, 2015 at 8:22 PM
    #2008
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Good deal, I think just off the bolt should be good, seems like most run them like that. In researching, seems like a 10" was needed, once I get the bumps sorted out I'll let you know what I decide on. I have the TG clevis from Poly
    http://www.polyperformance.com/Trail-Gear-Limiting-Strap-Clevis-Kit
    Ahha! I thought you were on just one 3/8" spacer from wheelers. So, you are 9/8" which is just under what I came up with. Sounds like I need 4 of the 3/8", then fine tune with the washers I have.
    I thought I was loosing it, thanks!
  9. Apr 6, 2015 at 8:23 PM
    #2009
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Also, need a longer bolt, Ace had everything but the M10 1.25, oh well, ordered some from Fastenal.
  10. Apr 6, 2015 at 8:34 PM
    #2010
    SconnieHailer
    Marc
    Yea, go through fastenal and get the strongest you can.
  11. Apr 7, 2015 at 6:30 PM
    #2011
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    So, I think a 9" is going to be ideal, 10" placed the clevis a bit higher on the frame than I liked.
    Here is what I ordered from Fastenal for the lower mount, a few extra washers just in case.
    SKU Qty Description Qty\Pkg Price Ext. Price
    11113290 2 M14-1.5 x 80mm DIN 960 Class 10.9 Plain Finish Hex Cap Screw 1 $ 7.5800 $ 15.16
    11508310 2 M14 x 1.5 Zinc Plated Class 10 Steel DIN 985 Nylon Insert Lock Nut 1 $ 0.7284 $ 1.46
    11103711 8 M14 DIN 125 Steel Yellow Zinc 200 HV Flat Washer 1 $ 0.5000 $ 4.00
  12. Apr 7, 2015 at 8:27 PM
    #2012
    SconnieHailer
    Marc
    Nice! Glad we both thought the same about the 10". Plus you have to consider the stretch. I planned for .75" based on the 1" for 12" of strap rule.
    Looks good, 10nine is what i've got for my lower solid mount bolts going on this weekend. I've still have to visit my local fastenal for what you just ordered but it's likely they dont have what you got in stock for me...
    I'm pumped to get all my front end stuff finished up, im sure you are too!
    Also, just double checked my bump spacer situation. I have two wheelers 3/8" spacers under the DK steel spacer. For a total of 1.125" of spacer under the superbump. You may want to look at the wheelers spacers since they are wider and will prevent the super bump from squishing up around your washers, should help you run less spacer too since that squish is letting the bump compress further...
  13. Apr 7, 2015 at 8:57 PM
    #2013
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Yeah, the stretch sold me on 9" over 10, the clevis would be mounted dead center on the frame with 9", 10 put it a bit towards the top for my liking, not counting for stretch, so went for 9s, going to order them from Kartek tomorrow.
    Again, Ace didn't quite have what I needed for the bolts, they had 8.8s in the M14-1.5, but since I wanted 10.9, and I had to order the bolts for the bumps anyway, just got them all from Fastenal.
    Thanks for checking, I already bit the bullet and ordered 4 of the 3/8" from Wheelers, that squish was one thing I spent awhile thinking about as well, I can use the washers between the Wheelers spacer and the DK ones if needed. Excited to get this wrapped up and beat on it. I also did a full clearance check with the spring out, and everything is totally clear now!
  14. Apr 7, 2015 at 9:28 PM
    #2014
    SconnieHailer
    Marc
    Nice!!! It's a bit of work to do it but worth it!!
  15. Apr 9, 2015 at 7:30 PM
    #2015
    SconnieHailer
    Marc
    Thanks Kar Tek. Swag with an order is always a nice find in the box :cool: Straps and clevis mounts showed up today. Plus two snap koozies and the products catalog :spy:
    [​IMG]IMG_20150409_192304073 by sconniehailer, on Flickr
  16. Apr 10, 2015 at 10:27 AM
    #2016
    rl206
    rl206 Well-Known Member
    P-NW
    2012 Tacoma DCLB
    It's the little things in life...
  17. Apr 10, 2015 at 2:33 PM
    #2017
    joshipps
    joshipps Well-Known Member
    Josh
    Wyoming
    95 Tacoma 4x4
    Sick dent
    Truth :D
    I almost shit a brick when i opened my box of steering rack bushings from Wheelers Offroad and found a zip-lock bag with candy in it.:eek:
  18. Apr 10, 2015 at 2:36 PM
    #2018
    skygear
    skygear                    
    Where's your writeup on the heim joint adjustments?
  19. Apr 10, 2015 at 4:11 PM
    #2019
    SconnieHailer
    Marc
    Still using the cam adjustment on the lowers for alignment. That will change tomorrow :D Getting the lowers solid mounted and digging into the hiem alignment tomorrow. Currently the uppers are set at the adjustment equal to dirt kings bushing arms.
    Didn't know I was doing a writeup? did I post I was and forgot or do you want one :luvya:
    Gonna be pretty simple trial and error. Got some valuable info from Nick at DK who said 1/4 inch of threads is roughly equal to half a degree of caster adjustment. That should speed things up after the first round on the turntables.
  20. Apr 10, 2015 at 7:38 PM
    #2020
    skygear
    skygear                    
    I do not have that skill. where and how much were the tables? Would love to learn it myself.
    Forgive me for assuming. Thought you were or did do a write up. I would appreciate one to further my skill sets and self reliability with the maintenance on the truck.
    Should both sides have the same distance of him adjustments from what you were told?
    Set a web cam/ laptop up and do a google hangouts for all of us interested. ;) I'd tune in for the show. Beats the cherry blossom fest in DC the wife wants me to go to.
