+SconnieHailer's Build & BS+
Discussion in '2nd Gen. Builds (2005-2015)' started by SconnieHailer, Mar 24, 2013.
  1. Jul 16, 2015 at 6:39 AM
    #2181
    SconnieHailer
    SconnieHailer [OP] PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    I've definitely been lurking your build. I want the gears for crawling, right now my stock 1st low feels so fast with 33's.
    deadhed61[QUOTED] likes this.
  2. Jul 16, 2015 at 7:59 AM
    #2182
    BradyT88
    BradyT88 Well-Known Member
    When I went to 33's my rig wouldn't hold 5th gear at 75 mph unless I was going downhill... That was one of the biggest reasons I regeared. With 4.88's and 33's, I am so low geared in 4Lo and 1st that I can actually kill the motor in some rock crawling instances like a manual trans. It freaked me out the first few times. haha It will actually creep up hill a little on it's own which surprises me for an auto.
  3. Jul 16, 2015 at 9:00 AM
    #2183
    SconnieHailer
    Marc
    I'd go 488 if I was ever going 35s. But I dd my truck too much to go that big. I know lots of people do it and dd bit that's not for me. Plus 35's going fast in rough stuff like i frequently do I feel like would be too much extra torque on frame mounts that are meant to handle 31's... Not worried about my control arms or spindle its what they're attached to haha. Feel free to comment if you feel I should go 35's for some reason other than Montes favorite response..."BECAUSE 35'S!!!!!!"
    XPOTRON likes this.
  4. Jul 16, 2015 at 9:18 AM
    #2184
    BradyT88
    Well I am an auto so my overdrive is geared a bit higher than yours. 80 mph for me on 33's and 4.88's runs me at 285RPM, for you that would be almost 3400 RPM. I find anything over 3K unreasonable. I have a stock exhaust and above 3K you are getting to where the radio has a hard time drowning it out... I couldn't imagine having a louder aftermarket exhaust...
    I assume you are going with 4.56's? 35's get you at about 3K RPM at 80 mph (not sure if WY has bumped the speed limit up or not). Anything smaller than 35's and you will be cruising over 3K at 80 mph ;) and who couldn't use another inch of ground clearance ;) If you stay on the same wheels then you gain another inch of side wall to soak up the trail at speed as well as a tire that bridges the bumps better too.
    They make gussets for all those weak links you mentioned ;) Get a crossbar built for the coil buckets and weld some metal onto those LCA mounts ;)
  5. Jul 16, 2015 at 4:06 PM
    #2185
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Eh, i think you have the truck dialed for 33s. 35s would be awesome, but a lot more work. Id stay with 33s this next set of tires anyways. The next set maybe jump up to 305s or 315s.
    or do 305s now.
  6. Jul 17, 2015 at 6:29 AM
    #2186
    XPOTRON
    XPOTRON Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    I think this will be your best bet! Not that I don't like my 35s, but I understand what you're saying about all the extra stress. I actually have a semi cracked LCA mount that needs some serious gusseting soon!
  7. Jul 17, 2015 at 8:21 AM
    #2187
    SconnieHailer
    Marc
    Mine cracked too... I just had the guy welding on my cam gussets run a bead where it was cracked. I know trac makes a gusset. Gonna call them soon. That lower mount really bothers me. How's your frame man?
    XPOTRON likes this.
  8. Jul 17, 2015 at 8:38 AM
    #2188
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Have a picture of said gussets? Front is getting torn apart in the next week or two. Might as well reinforce those as well.
  9. Jul 17, 2015 at 8:48 AM
    #2189
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    I'm thrilled with how my 295/70R17 Cooper ST MAXX look! Always thought it would be awesome to have 35s, but I don't want to have to do all the cutting, bashing, and cutting (I know I said cutting twice) that goes into running them. I'm still touching my flares at stuff with the 295s! To me, going with this size makes the truck look badass!
  10. Jul 17, 2015 at 9:39 AM
    #2190
    SconnieHailer
    Marc
    Look at nfs's truck the lime green accent rig built by trac performance. I'm on my phone or I'd link his build. He's got the lower gussets.
    ckeene9[QUOTED] likes this.
  11. Jul 25, 2015 at 11:19 AM
    #2191
    SconnieHailer
    Marc
  12. Jul 25, 2015 at 12:08 PM
    #2192
    ckeene9
    Chesterfield, VA
    See Build Thread
    Just saw this! Thank you! Off to search for a bit.
  13. Jul 25, 2015 at 12:15 PM
    #2193
    Stubbs07Tacoma
    Stubbs07Tacoma Toyota Veteran
    Blake
    EXPO in the making All Pro Expo Leafs PelfreyBilt front bumper full hoops 20 Inch led bar in bumper AVEC pods for fogs Warn 9500 Front suspension currently being redone
    I really dont like you, this is the build thread that made me buy a pelfreybilt front bumper
    SconnieHailer[OP] likes this.
  14. Jul 25, 2015 at 12:17 PM
    #2194
    SconnieHailer
    Marc
    Haha sorry? :D
  15. Jul 25, 2015 at 12:18 PM
    #2195
    Stubbs07Tacoma
    Blake
    ill forgive you. but next time you make me drop 1000 bucks im gonna give you negative feedback!
  16. Jul 25, 2015 at 5:24 PM
    #2196
    Blackdawg
    Monte
    Wyoming/St. Louis
  17. Jul 25, 2015 at 7:47 PM
    #2197
    ckeene9
    Chesterfield, VA
    See Build Thread
    What length straps are you running up front?
  18. Jul 25, 2015 at 9:29 PM
    #2198
    SconnieHailer
    Marc
    9" with adjustable clevis'.
  19. Jul 25, 2015 at 10:40 PM
    #2199
    XPOTRON
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    Just saw this haha my bad, yea I should have done that too, when the frame work begins ill have them take a look. But otherwise the truck is back running with new 4.88s. TommyGun Fab will begin work on 8/29....doing alittle more than just fixing the frame too ;)
  20. Jul 26, 2015 at 12:19 PM
    #2200
    ckeene9
    Chesterfield, VA
    See Build Thread
    Where did you all crack them? After looking at NFS257's deal, that won't work with the alignment cams.
