+SconnieHailer's Build & BS+
Discussion in '2nd Gen. Builds (2005-2015)' started by SconnieHailer, Mar 24, 2013.
  1. Nov 1, 2015 at 8:49 AM
    #2461
    SconnieHailer
    SconnieHailer [OP] PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Yea its why I haven't done them. I just wish I had a shop near me that could effectively do one for me... @Blackdawg If you want a project for your new bender :D
  2. Nov 1, 2015 at 4:19 PM
    #2462
    SconnieHailer
    Marc
    Jax and I got out for a swim and a hike today. Hit some dirt road to get there :) The truck is clean and the tent is off. Feels like a race car without that weight back there!
    [​IMG]t-ROD by Marc Mayer, on Flickr
    Brianawd, XPOTRON, rka and 2 others like this.
  3. Nov 1, 2015 at 4:59 PM
    #2463
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
  4. Nov 1, 2015 at 8:32 PM
    #2464
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Id be down. Want to do that to my own so let me practice first :p
  5. Nov 1, 2015 at 9:05 PM
    #2465
    SconnieHailer
    Marc
    :thumbsup:
    I wish it was as easy as cars... Just bolt one up!
    The recent header contact on the coil bucket makes me wonder if the passenger side is already bent in a bit...
  6. Nov 1, 2015 at 9:43 PM
    #2466
    Blackdawg
    Monte
    Wyoming/St. Louis
    Could be..but didn't you say the other guys does it too?
  7. Nov 1, 2015 at 10:07 PM
    #2467
    SconnieHailer
    Marc
    Yea, still wonder though. I should just cut the corner of the coil bucket off :rofl:
  8. Nov 1, 2015 at 10:11 PM
    #2468
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sounds safe! Haha
  9. Nov 2, 2015 at 4:52 PM
    #2469
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Lookin good Marc! Still sold on solid mount lowers and heim uppers? I am have another set of spindles that I will be gusseting and throwing on, going to pull the lowers and see how the derlin has held up to a year of being tacked in. Definitely think keeping things parallel down there is the way to go though. Have you rechecked your alignment since the initial setup?
  10. Nov 2, 2015 at 5:13 PM
    #2470
    SconnieHailer
    Marc
    Yea been great! Rechecked once early on and it was still the same numbers.
    I'm about due for a good once over on the front end, I'll do that when I get the motor mounts in. Yea the arm kept parallel in the mounts should really help bushing life!
  11. Nov 2, 2015 at 5:17 PM
    #2471
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Sweet, will probably trade my burg uppers for DK next spring.
  12. Nov 2, 2015 at 5:51 PM
    #2472
    SconnieHailer
    Marc
    I have rubbed on the dk upper on the front when the tire is turned all the way in. I just had to drop the caster a bit and its not rubbing. Also, the resi hose has been getting rubbed. Next time i rebuild the shocks i'm going to put a 90* bend so it doesnt rub anymore.
  13. Nov 2, 2015 at 6:22 PM
    #2473
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Were those nonissues with your last set of arms?
  14. Nov 2, 2015 at 6:47 PM
    #2474
    SconnieHailer
    Marc
  15. Nov 6, 2015 at 10:13 AM
    #2475
    SconnieHailer
    Marc
    Looking for some input. Ordering tires in the next week.
    Two options:
    BFG KO2 285/75/16 32.8" Diameter, 9" tread width
    BFG KO2 295/75/16 33.4" Diameter, 9.5" tread width
    My current Goodyear MTR's are 33.1" Diameter and 8.2" tread width for reference.
    I dont think the jump from 33.1 to 33.4 is going to be enough to really notice gearing wise? Width I'm going to have an issue with since I already rub a bit on my uca... nothing some small spacers cant fix. Going to probably have to trim fenders too since i like to go fast and stuff the tire alot :burnrubber: :p
    What you guys think? I think it just comes down to how much trimming and effort in alignment im up for haha.
  16. Nov 6, 2015 at 10:22 AM
    #2476
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    295's! :cool:
  17. Nov 6, 2015 at 10:41 AM
    #2477
    Blackdawg
    Monte
    Wyoming/St. Louis
    You know my answer...
    Wiiiiiddddeeeee :cool:
    2
    9
    5
  18. Nov 6, 2015 at 10:48 AM
    #2478
    Sacrifice
    KS
    DCSB OR 4X4 LT
    X2!
    Did they finally release the 295s?
  19. Nov 6, 2015 at 10:49 AM
    #2479
    Blackdawg
    Monte
    Wyoming/St. Louis
    Also I think just in terms if size you'll notice a difference for gears. But your over due firbthose anyways.
    Oooo! Let's do that over Xmas!
  20. Nov 6, 2015 at 11:00 AM
    #2480
    SconnieHailer
    Marc
    I was leaning towards 285 because I can just put them on and be done with it... But I should just not be lazy right... Haha
    Yea Monte gears should happen too... Would make crawling so much more enjoyable. Not sure how 4.56 would be with the 295's...
