+SconnieHailer's Build & BS+
Discussion in '2nd Gen. Builds (2005-2015)' started by SconnieHailer, Mar 24, 2013.
  1. Nov 15, 2015 at 1:47 PM
    #2541
    SconnieHailer
    SconnieHailer [OP] PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    Got out for a great hike this morning. Gorgeous weather here today, 50 degrees, calm and blue sky!
    Fam shot :p was using my phone for a remote. The wifi link goes pretty far! could still take pics about 100 feet away.
    [​IMG]Townsend-2 by Marc Mayer, on Flickr
    [​IMG]Townsend-4 by Marc Mayer, on Flickr
    [​IMG]Townsend-3 by Marc Mayer, on Flickr
    Torspd, BajaRunner and 92shawman like this.
  2. Nov 15, 2015 at 7:33 PM
    #2542
    SconnieHailer
    Marc
    Ok, so motor mount update time. Brett came over on Saturday to help out which was nice. Got the drivers side unbolted and the jack under the motor. Crawled under the truck with a light and realized there were lots of things in the way for the mount to come out easily. Got frustrated and just bolted the drivers side back together. Brett and I looked over the spot where the header has been hitting the coil bucket and it has definitly been self healing in a sense. The back of the bucket where it is contacting is a corner and could stand to be filed down some. I'm going to try and file it down a bit then paint the header and then see how it contacts.
    If there is another nice day this week i'll get both sides un-bolted, unbolt the trans and see if the engine will go up far enough for the mounts to drop out the bottom. Should be just enough. Ugh, first time i said screw it and didnt finish a project on the truck.
  3. Nov 15, 2015 at 9:12 PM
    #2543
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Did you try removing the single 17mm nut, which holds the two halves together? If not, i suggest doing that first. The engine will easily lift off of the stud. Then you can remove the two halves individually.
  4. Nov 15, 2015 at 9:14 PM
    #2544
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Man that pup has grown up, as well.
  5. Nov 15, 2015 at 9:25 PM
    #2545
    SconnieHailer
    Marc
    Yea I got an extension and socket down there from the top but it was too tight for the angle the swivel head was at. Also tried with a ratchet wrench from the wheel well but couldn't get enough torque to it. Gonna have to get creative for that one. Getting it separated like that would help getting the mount out past the diff for sure. It felt a bit loose in a 17mm wrench by the way?
    Yea jax is about 10 months and about 90# he's been such a great pup.
  6. Nov 15, 2015 at 9:44 PM
    #2546
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Haha
    Yea motor mounts suck
    Took me two days to do mine..
  7. Nov 15, 2015 at 9:54 PM
    #2547
    SconnieHailer
    Marc
    I'm glad you find it amusing :luvya:
  8. Nov 15, 2015 at 9:57 PM
    #2548
    Blackdawg
    Monte
    Wyoming/St. Louis
    I do..haha cause I knew exactly what you where getting yourself into haha :p
  9. Nov 18, 2015 at 2:21 PM
    #2549
    SconnieHailer
    Marc
    Crappy cell pic. Cap is on. In Casper for work, figured I'd pic it up! Already love it for work to lock everything up and have a clean/dry/ non windy space to setup from!
    zscott and Blackdawg like this.
  10. Nov 18, 2015 at 2:25 PM
    #2550
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Wow. Totally changes the look. I am about to put mine on too.
  11. Nov 18, 2015 at 2:45 PM
    #2551
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Did you trade-in on and '80's Toyota with camper shell? o_O.
    It is what comes to mind. Looks great. :thumbsup:
  12. Nov 18, 2015 at 2:50 PM
    #2552
    Nighthawk
    Nighthawk 'streme spoats
    Levi
    Casper Wyoming
    2008 Red TRD OR AC V6
    Bilstein 5100's w/ Eibach coil overs in front (set at 3" of lift). Front diff drop kit. Extended Bilstein 5100's in the rear. Deaver 2" AAL in rear w/ axle shims. 285 x 75 r 16 Goodyear Duratracks. Wheelers steelies type B, AFE cold air intake. Sway bar delete. All Pro Apex front bumper (rattle canned Rustoleum primer + flat black). Plasti-dipped emblems. Mud flaps removed.
    Thought I might have seen your truck today, were you on Wyoming Blvd at all?
  13. Nov 18, 2015 at 3:05 PM
    #2553
    SconnieHailer
    Marc
    Yep, as-builting the new bypass. If your around and want to catch dinner let me know :)
    Yea gonna have to get used to the look. But I like it!
    Haha, going for the mcfly look :p
  14. Nov 18, 2015 at 4:46 PM
    #2554
    BabyTaco
    BabyTaco Well-Known Member
    Wyoming
    2011 RC Tacoma
    Diggin the shell :thumbsup:
  15. Nov 18, 2015 at 7:27 PM
    #2555
    SconnieHailer
    Marc
    Thanks man, can't wait to see that softtopper on BT!
  16. Nov 18, 2015 at 7:46 PM
    #2556
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    Needs rack.... lol. Looks great. You will love having it.
  17. Nov 18, 2015 at 7:50 PM
    #2557
    SconnieHailer
    Marc
    Sure would look good with one of your racks @zscott :) hopefully by spring I can make something happen :thumbsup:
    Already thoroughly enjoying it.
  18. Nov 18, 2015 at 7:51 PM
    #2558
    zscott
    Zach
    Utah
    I bet the pup loves it too. Lots of new real estate for him.
  19. Nov 18, 2015 at 8:01 PM
    #2559
    SconnieHailer
    Marc
    Will find out tomorrow, just picked it up today. Gotta wire it up yet and clean it up. Should be great for the pup. Really glad I got the opening windows, already used them today.
  20. Nov 18, 2015 at 10:14 PM
    #2560
    Blackdawg
    Monte
    Wyoming/St. Louis
    My dads became a dog fur infested area with our labs haha does Jax shed bad?
