+SconnieHailer's Build & BS+
Discussion in '2nd Gen. Builds (2005-2015)' started by SconnieHailer, Mar 24, 2013.
  1. Dec 18, 2015 at 9:23 AM
    #2741
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Had it been the 3" , I'd have made a suggestion.
  2. Dec 18, 2015 at 9:28 AM
    #2742
    SconnieHailer
    SconnieHailer [OP] PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
  3. Dec 18, 2015 at 12:13 PM
    #2743
    BajaRunner
    BajaRunner Rock magnet
    Drew
    Chino Hills, CA
    12 4wd DC Tacoma TRD OR
    Bypass is a whole other beast and they are amazing. You can do more fine tuning to the ride quality of the suspension with bypass. Bypass are usually $400 more per shock. The ICON 2.5 remote resi double bypass run $848 per shock and a double bypass would be more than sufficient. More required when you get in to triple and quad bypass. The ICON double bypass will mount in the stock location since with their design you can rotate the tubes to clear the tire and best of all they require no tools to adjust compression and rebound. If you can afford them, I recommend you go for it. I know I eventually will be running bypass front and rear on an MT setup.
    BrandonTRD and SconnieHailer[OP] like this.
  4. Dec 18, 2015 at 3:06 PM
    #2744
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    I knew what they did, just looking for opinions which makes it tough. Some people are satisfied with no bypasses, and some like them even more. My truck is 95% a pavement truck, but when it hits dirt i dont treat it very nicely either.
  5. Dec 18, 2015 at 3:16 PM
    #2745
    BajaRunner
    Drew
    Chino Hills, CA
    Well that's the beauty of the ICON bypass, you can tune them for the street and then adjust them when you hit the dirt. Would be some trial and error, but once you have the numbers that work you can switch them back and forth in a few seconds.
  6. Dec 18, 2015 at 4:37 PM
    #2746
    Sacrifice
    KS
    DCSB OR 4X4 LT
    I dont mind a harsh ride on the street. Just hard to say ill notice the difference in having bypasses at all since ive never ridden in a built truck anyways and have the comparison. Ya know? I guess its only $400 difference for triples in the rear which isnt crazy expensive either.
  7. Dec 18, 2015 at 5:08 PM
    #2747
    BradyT88
    BradyT88 Well-Known Member
    I regret not doing bypasses. Though I also regret not doing 3.0's... I'm spring under though...
  8. Dec 18, 2015 at 5:48 PM
    #2748
    BajaRunner
    Drew
    Chino Hills, CA
    There is a noticable difference. My previous builds had bypass and all I can say is they take something good and make it great.
    Sacrifice[QUOTED] likes this.
  9. Dec 18, 2015 at 8:32 PM
    #2749
    SconnieHailer
    Marc
    Someday.... Bypasses all around! :cool: for errbody. Lol
    BradyT88 and Sacrifice like this.
  10. Dec 19, 2015 at 6:49 PM
    #2750
    SconnieHailer
    Marc
    Photo DUMP.
    First, this is my rear up-travel. Sitting level on jack stands under the axle. Just about 2.5 inches before i get into the bumps. @dakotasyota
    [​IMG]2015-12-19_06-43-19 by Marc Mayer, on Flickr
    This is how i've got my front strapped @zscott you can see i've got about an 8th inch between misalignment and cage of upper arm.
    [​IMG]2015-12-19_06-43-48 by Marc Mayer, on Flickr
    [​IMG]2015-12-19_06-45-42 by Marc Mayer, on Flickr
    [​IMG]2015-12-19_06-45-52 by Marc Mayer, on Flickr
    Had fun with tires thismorning. My wifes Fiesta was a champ!
    [​IMG]2015-12-19_06-46-13 by Marc Mayer, on Flickr
    Clearance, 3 degrees caster. No CMC or other cutting than i did for 285's. This is just to get me through the winter, come spring i'll be cycling and cutting to clear at stuff.
    [​IMG]2015-12-19_06-46-25 by Marc Mayer, on Flickr
    [​IMG]1-2 by Marc Mayer, on Flickr
    [​IMG]1-3 by Marc Mayer, on Flickr
    [​IMG]1-4 by Marc Mayer, on Flickr
    [​IMG]1-5 by Marc Mayer, on Flickr
    [​IMG]1-6 by Marc Mayer, on Flickr
    [​IMG]1-7 by Marc Mayer, on Flickr
    NYCO, Mademan925 and dakotasyota like this.
  11. Dec 19, 2015 at 6:56 PM
    #2751
    BajaRunner
    Drew
    Chino Hills, CA
    Wow they look awesome and bigger! Expecting any rub issues? I'm actually considering BFG A/Ts again when my MTRs wear down or possibly sell them.
  12. Dec 19, 2015 at 7:02 PM
    #2752
    BradyT88
  13. Dec 19, 2015 at 7:02 PM
    #2753
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Look wider. Not really taller though. Still looking good!
  14. Dec 19, 2015 at 7:03 PM
    #2754
    SconnieHailer
    Marc
    Absolutely zero rubbing at 3 deg castor for normal driving. Once I get offroad and stuff a front tire it's gonna rub. I'll worry about trimming for that in the spring.
  15. Dec 19, 2015 at 7:07 PM
    #2755
    SconnieHailer
    Marc
    Definitely wider. Taller a bit, but only about a third of an inch..
  16. Dec 19, 2015 at 7:15 PM
    #2756
    Blackdawg
    Monte
    Wyoming/St. Louis
    So much ground clearance now :D
  17. Dec 19, 2015 at 7:18 PM
    #2757
    BajaRunner
    Drew
    Chino Hills, CA
    Interested to see what you think of them after you put some miles on them.
  18. Dec 19, 2015 at 7:20 PM
    #2758
    SconnieHailer
    Marc
    Lol :luvya:
  19. Dec 19, 2015 at 7:21 PM
    #2759
    SconnieHailer
    Marc
    Already have a few opinions but will hold them until I get a few days on them.
  20. Dec 19, 2015 at 7:23 PM
    #2760
    BajaRunner
    Drew
    Chino Hills, CA
    That doesn't sound promising. Hopefully your opinions are good.
