+SconnieHailer's Build & BS+
Discussion in '2nd Gen. Builds (2005-2015)' started by SconnieHailer, Mar 24, 2013.
  1. Feb 5, 2016 at 10:26 AM
    #2861
    SconnieHailer
    SconnieHailer [OP] PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    They've been great and taken a beating. There are some pretty big gashes in the outer edges of the wheel :oops: still going strong.
    Yes i have the 0mm offset and 4.5 bs. No i'm running 295/75/16 now. Yea you will notice a power decrease but not bad, it's mainly because of the weight of the tire if you go E rated. The countersteers help alot being only 18 lbs each though.
    I had to trim for 285 a bit in the back of the wheel well on the fender but thats it. I'm running about 3* caster so that helps. I also had to trim some of the fender on the top of the wheel well were it was rubbing under full stuff. Not something you can see from the outside though, just up under the fender. 285 is a great size!
  2. Feb 5, 2016 at 11:58 AM
    #2862
    copenhagen
    copenhagen Well-Known Member
    South Carolina
    2011 TRD OFFROAD 4x4 SIX SPEED MANUAL AC
    Thanks. I have K02 265 75 16s with about 10k or so on them. It hurts my feelings because I want new wheels and tires. How were the countersteers with your 265 75's? I'm thinking about getting them to correct my old man with false teeth removed look induced by my ome heavy lift, and then burning through my 265's before I get new tires... Hopefully the wheel bearings won't be terribly beat up by moving 3 measily little centimeters. Really if you count the extra 1/4 inch on each side, you are only moving the centerline of the wheel about 2.365cm out from the frame.
  3. Feb 24, 2016 at 2:41 AM
    #2863
    copenhagen
    South Carolina
    Did you die or something?
    Jeffvt0508 likes this.
  4. Feb 24, 2016 at 3:43 AM
    #2864
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    I just bought these wheels you speak of.. And I'm on 265/75.. So I can help answer this question soon
  5. Feb 24, 2016 at 5:40 AM
    #2865
    SconnieHailer
    Marc
    Haha sorry man didn't see this! Counters were great with 265. Hardly noticed a change.
  6. Feb 24, 2016 at 9:04 AM
    #2866
    copenhagen
    South Carolina
    Well I got em and 285 km2s, but I am going to have to do the cab mount.
  7. Feb 26, 2016 at 8:57 AM
    #2867
    copenhagen
    South Carolina
    Mr. Hailer, tell me about your Dirt King LCA's? I'm looking at them and at the Total Chaos "race series." I'm trying to understand why the Total Chaos's cost 390 more dollars. Any thoughts?
  8. Feb 26, 2016 at 9:49 AM
    #2868
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    The TCs come with the secondary shock mount standard, DKs come with just a limit strap tab now. DKs come with derin bushings which are a $200 upgrade for most arms. So, unless you are planning dual shocks, DK seems like a better choice to me. Myself, and many others have been very happy with the DKs.
    Sje1124 likes this.
  9. Feb 26, 2016 at 12:23 PM
    #2869
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Ha they added a limit strap tab? Thank goodness
  10. Feb 26, 2016 at 12:39 PM
    #2870
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Yeah, tab now standard.
  11. Feb 26, 2016 at 12:42 PM
    #2871
    Blackdawg
    Monte
    Wyoming/St. Louis
    Stole my idea!
    Jk
    Glad it's standard now. Makes these very competitive against the TC ones
    Pcyc likes this.
  12. Feb 26, 2016 at 1:12 PM
    #2872
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    I copied both of you :anonymous:
    12TRDTacoma and Blackdawg like this.
  13. Feb 26, 2016 at 3:08 PM
    #2873
    SconnieHailer
    Marc
    Hey now it was both our ideas :p
    Like wishbone said, those are likely the reasons. I'm not sure if TC uses different metal too? They've been great for me. I'd buy them again.
    Blackdawg[QUOTED] likes this.
  14. Feb 26, 2016 at 3:16 PM
    #2874
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea it was mostly yours. Haha I just did it.
  15. Feb 26, 2016 at 3:20 PM
    #2875
    SconnieHailer
    Marc
    Holding up like a champ! Was your idea to bend the tabs so it pulled straight with the top mount!
  16. Feb 26, 2016 at 3:57 PM
    #2876
    Blackdawg
    Monte
    Wyoming/St. Louis
    Fair enough haha glad it's still working..Id feel bad if something suddenly ripped a hole in your frame :anonymous:
  17. Mar 1, 2016 at 6:02 AM
    #2877
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    @SconnieHailer, saw you post in another thread about the KO2's in 295, I scrolled back a few pages and didnt see any pics, did you go through with it? Considering going up to 295's in the new KO2's for my next tire
    Edit: found the pics you posted, they look SICK, did you ever do the cab mount chop? I know you're front set up is very different than mine so its sort of comparing apples to oranges, but do you have any rubbing anywhere? just FYI im running ARB w/ warn m8000, OME 886's and OME struts on level 8 guardians w/ 4.5" BS, stock UCA's and no rubbing with 285's
  18. Mar 1, 2016 at 7:09 AM
    #2878
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    If its of any interest i ran the 315 ko2s on level 8 mk6 w/ 4.11" backspace and stock suspension all around for a week or two. CMC and some beating but i only rubbed full reverse lock (which i still do)
  19. Mar 1, 2016 at 7:25 AM
    #2879
    Toy Yoda
    Garrett
    06 DCLB
    Hey man, yeah i've crept through your build, those 315's on no lift were crazy, i think i'll be okay, just trying to avoid modifying the frame, even if it is just the cab mount
  20. Mar 1, 2016 at 7:35 AM
    #2880
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Ah i see what youre trying to get at now. Best of luck. :thumbsup:
